"Koopas Ly" wrote in message
om... I would think that the only source of increased drag from a forward c.g. condition is profile drag due to a more nose-up elevator trim tab or elevator. There are several factors that translate into increased drag: * Drag from the trim, if used (as you noted) * Drag from the elevator itself (as you noted) * Increased induced drag from the horizontal stabilizer/elevator due to increased lift on that airfoil * Increased induced drag from the wings since the increase in lift on the horizontal stabilizer translates into added weight for the aircraft, which has the exact same increase in induced drag that adding physical weight to the aircraft would have How do you see a forward c.g.'s extra drag translating into premature airspeed bleeding? Sink rate and angle of descent would increase...but airspeed? I'm not sure I understand your question. Is this a continuation of the "why is there increased drag?" question? Or are you asking, even if one assumes increased drag, why does the airspeed bleed off quicker? If the former, I hope my earlier bullet points answer your question. If the latter, that should be obvious. For a given configuration, deceleration is strictly related to the net difference between thrust and drag. When thrust is greater than drag, you accelerate. When thrust is less than drag, you decelerate. Furthermore, the rate at which you decelerate is directly proportional to that net difference. For a given thrust, more drag means a greater rate of deceleration. Moving the CG doesn't affect thrust, but it does affect drag. Moving CG forward increases drag (as noted above) and thus increases the deceleration rate. Pete |
Pete,
Comments in your text. I would think that the only source of increased drag from a forward c.g. condition is profile drag due to a more nose-up elevator trim tab or elevator. There are several factors that translate into increased drag: * Drag from the trim, if used (as you noted) * Drag from the elevator itself (as you noted) * Increased induced drag from the horizontal stabilizer/elevator due to increased lift on that airfoil * Increased induced drag from the wings since the increase in lift on the horizontal stabilizer translates into added weight for the aircraft, which has the exact same increase in induced drag that adding physical weight to the aircraft would have Agreed. How do you see a forward c.g.'s extra drag translating into premature airspeed bleeding? Sink rate and angle of descent would increase...but airspeed? I'm not sure I understand your question. Is this a continuation of the "why is there increased drag?" question? Or are you asking, even if one assumes increased drag, why does the airspeed bleed off quicker? If the former, I hope my earlier bullet points answer your question. If the latter, that should be obvious. For a given configuration, deceleration is strictly related to the net difference between thrust and drag. When thrust is greater than drag, you accelerate. When thrust is less than drag, you decelerate. Furthermore, the rate at which you decelerate is directly proportional to that net difference. For a given thrust, more drag means a greater rate of deceleration. Moving the CG doesn't affect thrust, but it does affect drag. Moving CG forward increases drag (as noted above) and thus increases the deceleration rate. I agree that your deceleration is equal to (Thrust - Drag)/mass. Even though the airplane momentarily decelerates due to the increased drag, I ideally presume that the airplane's trimmed angle of attack has not changed (if you consider that the forward c.g. shift occured in flight). The assumption is probably invalid since, as you mentioned in your last point, the wing needs to develop more lift to offset the increase in tail downforce. The differential lift would require a change in either trimmed speed or angle of attack. However, ignoring this fact, if the airplane was originally trimmed for level flight, I contend that you would only start experiencing a slight descent rate at an airspeed no different than prior to the forward c.g. shift. Your thoughts? Have a good weekend, Alex |
rate at an airspeed no different than prior to the forward c.g. shift...Your thoughts? Very good! How about this: since the increased drag leads to an increased descent rate with the power off, you will have to increase your angle of attack at a greater rate during your flare in order to maintain a constant altitude above the runway. Since you're increasing your AOA more rapidly, your airspeed will be falling more rapidly. |
om... However, ignoring this fact, if the airplane was originally trimmed for level flight, I contend that you would only start experiencing a slight descent rate at an airspeed no different than prior to the forward c.g. shift. If you ignore that fact, sure. But you can't ignore that fact and still have a correct understanding of the situation. I fail to see the relevance of a hypothetical situation in which things aren't as they actually are in real life. It won't help you understand what's happening in real life. It's like saying "if you ignore the fact that there's gravity, we could fly with a lot less power required than we do now". Sure, it's a true statement, but it's not terribly useful. Pete |
Pete,
I can see where I set myself up nicely for your latest moral redressing. My previous description pertaining to constant airspeed with a sink rate after the forward c.g. shift was valid only if you didn't touch any controls. If I understand your assertion, you want to maintain altitude without augmenting power so I concur that you would have to reduce your airspeed through a control input to meet the higher drag. I note that the above would be invalid on the backside of the power curve since the increase in angle of attack further compounds the drag accumulation. In such case, only a power augmentation could be the remedy. Can we agree on this? Alex |
om... I can see where I set myself up nicely for your latest moral redressing. Not sure what you mean. My previous description pertaining to constant airspeed with a sink rate after the forward c.g. shift was valid only if you didn't touch any controls. My previous comments were with respect *only* to the increase in drag, and resulting increase in deceleration rate. Constant airspeed and sink rate are irrelevant to those comments. If I understand your assertion, you want to maintain altitude without augmenting power so I concur that you would have to reduce your airspeed through a control input to meet the higher drag. Not sure where you got the impression that I "want to maintain altitude". All I "want" to do is explain why airspeed scrubs off more quickly when the CG is farther forward. I note that the above would be invalid on the backside of the power curve since the increase in angle of attack further compounds the drag accumulation. In such case, only a power augmentation could be the remedy. No, a decrease in angle of attack in that situation would reduce drag. Can we agree on this? We can agree on any number of things. But you would need to stay on topic and not make up purely hypothetical but physically impossible situations for us to do so, at least in this thread. Pete |
redressing. Not sure what you mean. What I mean are your consistent unfriendly didacticisms. The defensiveness you've displayed in your last posts is unwarranted, as is your gratuitous stern tone. I am neither attempting to provoke you nor challenge your knowledge. In fact, I respect it. However, for reasons unbeknownst to me, you've set upon a course to systematically dismiss every one of my comments without the least consideration for merit. The gist of your reply revolves around the irrelevance of my comments with respect to the deceleration due to drag with a forward c.g. condition. In contrast, I believe that my subsequent comments are very much relevant digressions that expound upon your original thread. My previous description pertaining to constant airspeed with a sink rate after the forward c.g. shift was valid only if you didn't touch any controls. My previous comments were with respect *only* to the increase in drag, and resulting increase in deceleration rate. Constant airspeed and sink rate are irrelevant to those comments. Constant airspeed and sink rate are in fact relevant to those comments, as they succeed the latter. With no control inputs after the forward c.g. shift, you will experience a lower pitch attitude and a subsequent sink rate at constant airspeed. If I understand your assertion, you want to maintain altitude without augmenting power so I concur that you would have to reduce your airspeed through a control input to meet the higher drag. Not sure where you got the impression that I "want to maintain altitude". All I "want" to do is explain why airspeed scrubs off more quickly when the CG is farther forward. I was wrong. I assumed that you wanted to maintain altitude, and I am sure you know what happens when you assume. I note that the above would be invalid on the backside of the power curve since the increase in angle of attack further compounds the drag accumulation. In such case, only a power augmentation could be the remedy. No, a decrease in angle of attack in that situation would reduce drag. A decrease in angle of attack would change your altitude, an excursion I was trying to prevent. Can we agree on this? We can agree on any number of things. But you would need to stay on topic and not make up purely hypothetical but physically impossible situations for us to do so, at least in this thread. Pete |
experience a lower pitch attitude and a subsequent sink rate at constant airspeed. Moving the CG forward, with no control inputs, will change the equilibrium lift coefficient for the aircraft, making it smaller. The aircraft's velocity will increase, using gravity for thrust. You can see this in a 152. Both pilots lean forward, and the aircraft descends and speeds up. Both pilots lean back, and the aircraft climbs and slows down. If you move the CG forward, and want to keep the same airspeed, you will have to increase the tail down force, i.e., nose up trim. In this scenario, you will have the same airspeed, but slightly higher drag and will incur a slight descent. |
om... What I mean are your consistent unfriendly didacticisms. The defensiveness you've displayed in your last posts is unwarranted, as is your gratuitous stern tone. I submit that you may want to find a different forum, if you have found my posts defensive or gratuitiously stern. You appear to be far too sensitive for strictly textual communications to participate in Usenet. I have simply attempted to answer the original question, while correcting elements of your posts that were not true. It is unreasonable of you to post your hypothesis, ask whether your hypothesis is valid, and then get offended when you are told it is not. Pete |
Dennis Fetters Mini 500 | EmailMe | Home Built | 70 | June 21st 04 09:36 PM |
So Who Has More Military Command Experience, Bush Or Kerry? | W. D. Allen Sr. | Military Aviation | 11 | April 22nd 04 01:27 AM |
So Who Has More Military Command Experience, Bush Or Kerry? | W. D. Allen Sr. | Naval Aviation | 11 | April 19th 04 05:12 PM |
Forward Swept Wings | Canuck Bob | Home Built | 16 | October 3rd 03 05:50 PM |
