"karl gruber" wrote in message
... ******Not necessarily. Depends whether you fly a low or high wing aircraft.**** Not necessarily. The old Piper Cherokee wing pitches down with flaps. The newer Warrior wing pitches up with flaps. Has NOTHING to do with wing placement!! Well, actually... It has a little to do with the wing placement in that wing placement certainly can affect whether flaps cause a nose-up or nose-down trim change. Other factors are involved as well, so knowing the wing placement alone won't tell you what flaps will do. But certainly, all else being equal, moving the wing can change the way flaps affect trim. Now, all that said...I don't think that's what Larry was talking about. The trim change is usually a result of a combination of things, including airflow over the horizontal stabilizer and elevator. But if I recall correctly, flaps extended below the wing *also* create a pitching down moment, always. This moment may be enhanced or obscured by other factors, but it always exists. Since trim changes often become negligible at lower airspeeds, this moment can become more significant during the flare, even if the net trim change at the normal flap extension speed would be nose-up. At least, I think that's the point Larry was trying to make. I could very well be wrong about what point he was trying to make, and I might have misremembered this particular aspect of the aerodynamics of flaps. Pete |
***** Has NOTHING to do with wing placement!!
Well, actually... It has a little to do with the wing placement in that wing placement**** So true. I must remember, the words "nothing, always, never,...Etc" don't get very far on usenet. Best |
On 2003-11-14 21:55:21 -0800, "Peter Duniho" said
At least, I think that's the point Larry was trying to make. I could ver well be wrong about what point he was trying to make, and I might hav misremembered this particular aspect of the aerodynamics of flaps That was my point exactly |
Dennis Fetters Mini 500 | EmailMe | Home Built | 70 | June 21st 04 09:36 PM |
So Who Has More Military Command Experience, Bush Or Kerry? | W. D. Allen Sr. | Military Aviation | 11 | April 22nd 04 01:27 AM |
So Who Has More Military Command Experience, Bush Or Kerry? | W. D. Allen Sr. | Naval Aviation | 11 | April 19th 04 05:12 PM |
Forward Swept Wings | Canuck Bob | Home Built | 16 | October 3rd 03 05:50 PM |
