Yes. I go by tach time anyway and can peg fuel consumption
pretty close. "Yossarian" wrote in message . .. I understand that functional fuel gauges are required equipment for day VFR flight. Yesterday during my preflight in a 172 I saw that the right gauge was functioning intermittently--it would show full, flicker down to zero, bounce around, etc. Tank was visually confirmed full. Mechanic messed around with it for a while to no effect. Would you fly this airplane? |
On Sat, 15 Nov 2003 13:40:58 -0600, "Roger Tracy"
wrote: Yes. I go by tach time anyway and can peg fuel consumption pretty close. Spoken like a high winger. For us low wing types we have to know how much fuel is in each tank. Since climb, cruise, and descent all use different amounts of fuel it is hard to know how much is left in each tank. Sooner or later we come to the point when the POH says switch to the fullest tank. We need the gauges to know which one that is. |
![]() "ArtP" wrote in message ... Sooner or later we come to the point when the POH says switch to the fullest tank. You always know which one is fullest after you run one dry. |
Two watches will do that. Or a double timer like I use.
mike regish "ArtP" wrote in message ... On Sat, 15 Nov 2003 13:40:58 -0600, "Roger Tracy" wrote: Yes. I go by tach time anyway and can peg fuel consumption pretty close. Spoken like a high winger. For us low wing types we have to know how much fuel is in each tank. Since climb, cruise, and descent all use different amounts of fuel it is hard to know how much is left in each tank. Sooner or later we come to the point when the POH says switch to the fullest tank. We need the gauges to know which one that is. |
![]() "mike regish" wrote in message news:R%xtb.161414$275.497496@attbi_s53... Two watches will do that. Or a double timer like I use. There are a number of reasons why you might be using fuel FASTER than you are timing it. Let me tell you a few stories. A few years ago we got the Navion back from annual. The IA had signed off on it, and another A&P, Margy, and I put the plane back together. The A&P and I took it up for a test flight and after immediately opened her up to inspect for leaks and all looked good. The next morning we take off for Oshkosh with Margy in the left seat. She's negotiating with Approach for FF and a Class B clearance. I'm looking at the fuel guage and thinking "I'm pretty sure I topped the thing off, but we're down gas." I tell Margy and I tell I'll keep an eye on it. As it is, we've got over 80 gallons left on board. The downward trend continues. Just at this time approach calls back with oru clearance. We're about midway between two airports, we tell Dulles that we're going to Leesburg, they offer assistance. Get down on the ground, find a mechanic, find that a fuel line is loose and spraying fuel all over the inside of the engine compartment. I do a quick calculation and determine that we have used 20 gallons in a 20 minute flight. That is 60 GPH! Another long time rec.aviator put his Cardinal down on a road because he ran out of fuel due to a higher than predicted fuel burn. Was found that his carburator was leaking. Another rec.aviator ran out of fuel IFR. Nobody yet knows what happened, but he ran out way ahead of what preflight planning predicted. ****ty as your average light plane fuel guages are, they are NOT superfluous. |
I know if it's at all bumpy and the tanks are anything below full, my gages
are useless. They swing all over the place. Why can't they be damped like car gages? I suppose they would stay pinned at 0 when the tank was actually empty. Barring leaks, I trust my timers. Between 3 and 5 thousand feet at 2200 rpm I get 2 hours 28 minutes and change out of each tank. I can get another 6 or 7 minutes by slipping with the empty tank on the high side. I also know that I really have to rock all the bubbles out of the tanks to get the full 18 gallons in each. mike regish "Ron Natalie" wrote in message . .. "mike regish" wrote in message news:R%xtb.161414$275.497496@attbi_s53... Two watches will do that. Or a double timer like I use. There are a number of reasons why you might be using fuel FASTER than you are timing it. Let me tell you a few stories. A few years ago we got the Navion back from annual. The IA had signed off on it, and another A&P, Margy, and I put the plane back together. The A&P and I took it up for a test flight and after immediately opened her up to inspect for leaks and all looked good. The next morning we take off for Oshkosh with Margy in the left seat. She's negotiating with Approach for FF and a Class B clearance. I'm looking at the fuel guage and thinking "I'm pretty sure I topped the thing off, but we're down gas." I tell Margy and I tell I'll keep an eye on it. As it is, we've got over 80 gallons left on board. The downward trend continues. Just at this time approach calls back with oru clearance. We're about midway between two airports, we tell Dulles that we're going to Leesburg, they offer assistance. Get down on the ground, find a mechanic, find that a fuel line is loose and spraying fuel all over the inside of the engine compartment. I do a quick calculation and determine that we have used 20 gallons in a 20 minute flight. That is 60 GPH! Another long time rec.aviator put his Cardinal down on a road because he ran out of fuel due to a higher than predicted fuel burn. Was found that his carburator was leaking. Another rec.aviator ran out of fuel IFR. Nobody yet knows what happened, but he ran out way ahead of what preflight planning predicted. ****ty as your average light plane fuel guages are, they are NOT superfluous. |
one watch and pencil and paper..
"mike regish" wrote in message news:R%xtb.161414$275.497496@attbi_s53... Two watches will do that. Or a double timer like I use. mike regish "ArtP" wrote in message ... On Sat, 15 Nov 2003 13:40:58 -0600, "Roger Tracy" wrote: Yes. I go by tach time anyway and can peg fuel consumption pretty close. Spoken like a high winger. For us low wing types we have to know how much fuel is in each tank. Since climb, cruise, and descent all use different amounts of fuel it is hard to know how much is left in each tank. Sooner or later we come to the point when the POH says switch to the fullest tank. We need the gauges to know which one that is. |
ArtP wrote in message . ..
On Sat, 15 Nov 2003 13:40:58 -0600, "Roger Tracy" wrote: Yes. I go by tach time anyway and can peg fuel consumption pretty close. Spoken like a high winger. For us low wing types we have to know how much fuel is in each tank. Since climb, cruise, and descent all use different amounts of fuel it is hard to know how much is left in each tank. Sooner or later we come to the point when the POH says switch to the fullest tank. We need the gauges to know which one that is. We do? I just use my watch and some scratch paper on my kneeboard. That gives me a pretty good idea as to which tank has more fuel. The different fuel burn in climb and descent tend to cancel each other out. When refueling, I regularly guess the amount required to fill each tank by 1/2 gal. I just base it all on the average cruise fuel burn. I'm sure someone will mention the possibility of a mechanical problem causing a higher than normal fuel burn. To cover that, my tank switching methodology works so that if one runs dry prematurely, I'll still have plenty of gas in the other tank to go to an alternate. That said, I do use my gauges when I fly, but I don't depend on them. They're only there to alert me to a possible problem which will be confirmed by a) one tank running out of gas earlier than expected or b) verifiying the fuel burn at the next refueling stop. John Galban=====N4BQ (PA28-180) |
Ultralight Club Bylaws - Warning Long Post | MrHabilis | Home Built | 0 | June 11th 04 05:07 PM |
Mountain flying instruction: McCall, Idaho, Colorado too! | [email protected] | General Aviation | 0 | March 26th 04 11:24 PM |
Progress on Flying Car | Steve Dufour | General Aviation | 5 | December 19th 03 03:48 PM |
FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING | The Ink Company | Aviation Marketplace | 0 | November 5th 03 12:07 AM |
the thrill of flying interview is here! | Dudley Henriques | Piloting | 0 | October 21st 03 07:41 PM |
