Flying Restricted Airspace
Old November 17th 03, 02:47 AM
Jessica Core
A Lieberman wrote:
H.J. wrote:
If I want to fly in some restricted airspace - nevermind the reason - how is
that done?
The chart says the controlling authority is ZLC Center. That's Salt Lake
ARTCC, right?
So if I'm flying VFR, what do I do?
Do I find any low alt freq to the SLC ARTCC in the AF/D and call "Salt Lake
Center. 1234X Request transition through R12345"
If you're lucky the chart might even have a frequency to get the green light
through the restricted airspace. But, yes contact the facility responsible for
the airspace at the frequency appropriate for the location/altitude you are at.
Oh yeah, how do we know you are not a terrorist *smile*.
Or work for a terrorist that doesn't want to fly....
I would suspect the area would be restricted for photo opportunities as
well, so taking snapshots may be one of the reasons for restricted
airspace.
Why would you suspect that? If "taking snapshops" was to be avoided, the
airspace would be prohibited, although you'd have to prohibit awfully darn high to
be meaningful in an age with quality telephoto lenses and even satellite
photography. Restricted areas many times are areas where there is a lot of
military training activity and/or parachuting, mortar firing, etc. (MOAs have
activity too but are not restricted). If the danger is not present at the moment,
("not hot") you can often get approval to fly through.
Why else would you want to overfly a restricted area? Inquiring minds
like to know....
Because it lies between Point A & Point B where you are trying to travel?
Old November 17th 03, 05:05 AM
A Lieberman
If the area is restricted and hot ATC will not issue a clearance. Go to
http://hal9000.inetstrat.com/airspace/SpecialUse.htm for special use
airspace. Website also provides the AIM chapters as appropriate.
The restricted airspace I have encountered was a military installation.
I'd suspect that the military may not want planes loitering overhead
when there may be sensitive operations on the ground that may be
subjected to photographs.
Most of these restricted areas "may" take you a couple of miles out of
your way. Plan far enough ahead, and maybe a change of 10 degrees in
your heading before getting to the restricted airspace will circumvent
the area and then after passing, adjust the other direction. Really not
that hard to do. Situational awareness is the key.
Allen
Old November 17th 03, 03:26 AM
Jessica Core
That's why the chart lists a facility that handles the particular restricted area so you
can call them, find out if its actually currently hot, and get permission to transit the
airspace if available.
Again, contact the listed facility and give them your intentions. They will tell you if
you can transit that airspace.
your way.
Or they may be larger.
Or just call the facility in charge of that airspace to see if you can enter. They are
typically quite nice and polite about it. Really. No need to be afraid of doing this.
Reading the information on the chart and communication is the key.
AOPA Sells-Out California Pilots in Military Airspace Grab? Larry Dighera Instrument Flight Rules 12 April 26th 04 06:12 PM
Mountain flying instruction: McCall, Idaho, Colorado too! [email protected] General Aviation 0 March 26th 04 11:24 PM
Flying in the Presidents Airspace PaulaJay1 Instrument Flight Rules 3 March 12th 04 03:11 PM
Violating Airspace with GPS John Bell Piloting 57 November 5th 03 08:25 PM
FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING The Ink Company Aviation Marketplace 0 November 5th 03 12:07 AM
