![]() "Teacherjh" wrote in message ... I suppose, but what right-minded controller would plant a 737 on a runway to wait for an IFR clearance? In my mind, an ex-controller, or a =very= unusual circumstance. It was a 747. The controller didn't plant him on the runway so that he could wait for an IFR clearance, he was taxiing for takeoff while the clearance was on request. Nor did he wait on the runway for his IFR clearance, he was issued the IFR clearance and still had to wait for the runway to become available for his takeoff. |
![]() Nor did he wait on the runway for his IFR clearance, he was issued the IFR clearance and still had to wait for the runway to become available for his takeoff. Ok, I thought he got his IFR clearance while in position... implying he was on the runway without an IFR clearance at least for some point. Jos -- (for Email, make the obvious changes in my address) |
![]() "Teacherjh" wrote in message ... Ok, I thought he got his IFR clearance while in position... implying he was on the runway without an IFR clearance at least for some point. He did get his IFR clearance while on the runway, but that did not delay his departure. Being on the runway without an IFR clearance is not a problem. |
.... unless you can't take off without an IFR clearance, and there's incoming. But I suppose the controller would take care of that when it happened. It just seems that the end of the runway is a bad place to be unless you're ready to go. Jose -- (for Email, make the obvious changes in my address) |
... ... unless you can't take off without an IFR clearance, and there's incoming. But I suppose the controller would take care of that when it happened. Ninety-nine times out of a hundred, sure. Who wants to be the hundredth? It just seems that the end of the runway is a bad place to be unless you're ready to go. It is. And no controller can make you sit there. They don't fly the plane. You do. Pete |
... Being on the runway without an IFR clearance is not a problem. ... unless you can't take off without an IFR clearance, and there's incoming. But I suppose the controller would take care of that when it happened. It just seems that the end of the runway is a bad place to be unless you're ready to go. Not sure why there's such a strong aversion to this. In Europe at least, the rate-limiting step is often coordination with the facility that will control after departure. The clearance is not issued until that has been done, and the window that that facility wants to open up is usually quite short. Hence it's not unusual at a quiet controlled airport to be given the IFR clearance while lined up on the runway, and a take-off clearance immediately afterwards. If the clearance were given at the hold, it could take minutes to backtrack the runway and get airborne -- it's not unusual to get such a clearance a couple of minutes before the end of a flow management slot. Julian Scarfe |
"Julian Scarfe" wrote in message
... Not sure why there's such a strong aversion to this. Well, for one, because nearly all fatal collisions between transport aircraft occurred on a runway. [...] Hence it's not unusual at a quiet controlled airport to be given the IFR clearance while lined up on the runway, and a take-off clearance immediately afterwards. I don't think anyone stipulated the "quiet controlled airport". "Controlled" is implied, of course. But this "quiet" was never stated. In the US, "quiet controlled airport" is either an oxymoron by definition, or a relative term applicable to airports where there's still a fair amount of traffic. If the clearance were given at the hold, it could take minutes to backtrack the runway and get airborne -- it's not unusual to get such a clearance a couple of minutes before the end of a flow management slot. Minutes? I've never seen an airport where an airplane would take more than ten or fifteen seconds to get lined up and take off. Not saying they don't exist, of course, but surely it makes more sense to think about the typical case here when talking about general procedures. Pete |
... Not sure why there's such a strong aversion to this. "Peter Duniho" wrote in message ... Well, for one, because nearly all fatal collisions between transport aircraft occurred on a runway. That's fair enough. I think there have been at least two landing vs position-and-hold collisions, though I don't think either of them involved waiting for an IFR clearance -- but I take the point. [...] Hence it's not unusual at a quiet controlled airport to be given the IFR clearance while lined up on the runway, and a take-off clearance immediately afterwards. I don't think anyone stipulated the "quiet controlled airport". "Controlled" is implied, of course. But this "quiet" was never stated. In the US, "quiet controlled airport" is either an oxymoron by definition, or a relative term applicable to airports where there's still a fair amount of traffic. Well Tenerife was pretty quiet that day until the collision! It's difficult to tell as I have limited experience of flying in the US, but it didn't seem unusual for minutes to go by without the runway being in use. My last flight in the US involved an unscheduled stop at PAE after a door came open in flight. We landed on the runway and instead of asking us to vacate we got to stop, fix the door and then backtrack on the runway to the end. Does Paine Field count as quiet? If the clearance were given at the hold, it could take minutes to backtrack the runway and get airborne -- it's not unusual to get such a clearance a couple of minutes before the end of a flow management slot. Minutes? I've never seen an airport where an airplane would take more than ten or fifteen seconds to get lined up and take off. Not saying they don't exist, of course, but surely it makes more sense to think about the typical case here when talking about general procedures. Again I can only think of specific cases -- I guess concrete is cheaper in the US. :-) At my home base of Cambridge in the UK, the last paved taxiway to/from the apron is about 2/3 of the way down the 6500 ft runway 05. Thus the 747s that come in for maintenance end up taxying more than 4000 ft on the runway, and they don't like doing that very quickly. It's more common than not for them (and the rest of us for that matter) to get a clearance while backtracking. Julian Scarfe |
Associate Publisher Wanted - Aviation & Business Journals | Mergatroide | Aviation Marketplace | 1 | January 13th 04 08:26 PM |
Associate Publisher Wanted - Aviation & Business Journals | Mergatroide | General Aviation | 1 | January 13th 04 08:26 PM |
MSNBC Reporting on GA Security Threat | Scott Schluer | Piloting | 44 | November 23rd 03 02:50 AM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
