Overweight takeoff / flight
Old November 26th 03, 08:07 PM
Peter Duniho
"Greg Esres" wrote in message
a specific Va is valid only at a specific weight, with
Show me a Part 23 requirement that says so.
Part 23 isn't what makes an airplane fly. Aerodynamics are. And those
aerodynamics clearly show that at a given weight, a slower airspeed is
required in order to limit acceleration to a given number.
Oddly enough, many aircraft manuals bear this out, providing lower Va speeds
for lower weights.
Todd Pattist has lectured on this a couple of times, and he's right.
I seriously doubt Todd has told you that Va remains the same regardless of
aircraft weight. You obviously misunderstood him.
Pete
Old November 26th 03, 09:19 PM
Greg Esres
The definition of Va in Part 23 is clear. It has nothing to do with
control surfaces and everything to do with stall speed and load
factor.
Then you haven't read Part 23.
Let me point out the sections to you:
-------------snip------------------
Horizontal Stabilizing and Balancing Surfaces
§ 23.423 Maneuvering loads.
Each horizontal surface...must be designed for the maneuvering loads
imposed by the following conditions:
(a) A sudden movement of the pitching control, at the speed VA...
(b) A sudden aft movement of the pitching control at speeds above
VA...
Vertical Surfaces
§ 23.441 Maneuvering loads.
(a) At speeds up to VA, the vertical surfaces must be designed to
withstand the following conditions....
Ailerons and Special Devices
§ 23.455 Ailerons.
(a) The ailerons must be designed for the loads to which they are
subjected -
(i) Sudden maximum displacement of the aileron control at VA. Suitable
allowance may be made for control system deflections.
Now, the section that may be misleading you is this
§ 23.335 Design airspeeds.
(c) Design maneuvering speed VA. For VA, the following applies:
(1) VA may not be less than VS * sqrt(n) where -
Note that it says MAY NOT BE LESS THAN... In other words, it can be
more.
Va speeds for lower weights.
Oddly, you didn't read what I wrote.
The point is that at Part 23 doesn't require this. And not all
aircraft publish such variations.
does not mean that the maximum speed at which you can fly
and be assured of not overstressing the airplane does not go down as
weight is reduced.
Again, you didn't read what I wrote. I said it doesn't scale UP.
Flying over max gross may increase maneuvering speed, but it doesn't
increase VA, because the increased weight won't protect control
surfaces from failure.
Even your control surface tangent isn't really relevant to this
particular thread
Tangent? It's the essence of what Va is.
regardless of aircraft weight. You obviously misunderstood him.
Ok, you read what he wrote and tell me:
----------------snip----------------------
Note that this is a minimum Va ("no less than"). Thus the
designer can specify a higher Va and then protect the tail
surfaces by limiting stick throw, or by making the required
force at the stick to produce a damaging load on the
protected structure higher than a standard pilot could
exert. Note also that the regulatory definition of Va
*requires" that it be computed only at a stalling speed "at
the design weight" , i.e. max gross. Thus any lower speed,
or any lower weight cannot be Va as defined.
Old November 27th 03, 12:40 AM
Peter Duniho
news
Yes, I have.
Those sections stipulate, given an existing Va, how the control surfaces
must be designed. They do not in any way define Va.
You are still hung up thinking that Part 23 is what makes airplanes fly.
In this context "maneuvering speed" is synonymous with "Va". Yes, you're
right, there is only ONE Va. But in the world of piloting, we commonly
understand the shorthand "Va" to mean "maneuvering speed at a given aircraft
weight" where the weight is changeable.
Not in this context it's not.
If you think that he was explaining the aerodynamics of maneuvering speed,
you misunderstood him. If you don't think that he was explaining the
aerodynamics of maneuvering speed, then your comments based on that quote
are irrelevant to this thread.
Pete
Old November 27th 03, 02:08 AM
Greg Esres
we commonly understand the shorthand "Va" to mean "maneuvering speed
at a given aircraft weight" where the weight is changeable.
Then what is commonly understood is not correct, because that's not
how Va is *necessarily* determined.
PARTICULARLY in this context. The control surfaces were designed with
withstand full movements at PUBLISHED Va, not his new, derived, HIGHER
Va.
Old November 27th 03, 07:32 AM
Peter Duniho
Va.
There are any number of structural issues raised by overgross flight. It
was clear to me which one he was asking about, and the control surfaces
ain't it.
RAF Blind/Beam Approach Training flights Geoffrey Sinclair Military Aviation 3 September 4th 09 06:31 PM
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk Jehad Internet Military Aviation 0 February 7th 04 04:24 AM
