Mike Fitzgerald wrote:
"Charlie England" wrote in message ... John Bundy wrote: What size air compressor do I need for building my RV-10? I don't know about rivets and air tools. My experience is mostly carpentry. I may be interested in spraying some primer in interior areas but that's about as far as I'd go with painting. Go to: http://www.matronics.com/search & get as many opinions as you can stand about air compressors directly from RV builders. If all you do is rivet & don't try to use spray guns or air powered die grinders (air drills are ok), a little 5 hp unit with 10-15 gal tank would be adequate. Type of compressor gets important if you don't care for noise (oilless is bad; old style piston type with oil in the crankcase is good). ... forget about hp... it means NOTHING. That is why Campbell Hausfeld and other compressor companies have the lawyers swarming over them at the moment. I repeat: horsepower ratings for (most) compressors is bulls*hit and most people know that. Also, giving absolute numbers of XX gal size tank is also not useful information without knowing what tools you will be using. How to select a compressor: Find your most air hungry tool. Buy a compressor with more CFM than required at the PSI required for that tool. And then figure out how frequently that tool will run when selecting tank size. Continuous use tools like paint guns and die grinders would require a larger tank than 10-15 gal. HVLP guns typically require at least 13-15 CFM although there are a few low CFM HVLP guns available (Sharpe Platinum is one such gun). Or, just go with a conventional gun. I agree - get an oil lubed compressor simply due to the noise. And the oilless compressors do not last as long. Anyway: select the tools, then select the compressor. You are absolutely correct about the way to select a compressor & about the HP myth. Everything you said (and a LOT more) is in the Matronics RV-list archives link I provided. For instance, what external accessories you will need if you paint using an oil-type compressor. |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 2nd 04 11:41 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 09:02 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
