Bill,
I love questions like this, you've already done the heavy lifting and pretty much nailed the merits. The merits start to look even better when you examine the possibilities of putting a clutched shaft on your existing turbo and electrically spin the compressor side as required (reduces weight, gains you the HP that is always being sucked up by the blower which is compressing air at a much lower efficiency than the turbo, etc.) There are also a mess of other possibilities that while more complex from an engineering standpoint offer "better" solutions for certain mission profiles. These include compressed air starts, fully electrical turbos, clutched superchargers, centrifugal or screw compressor supercharges instead of roots type, the list goes on. The selection of our current solution was a combination of the desire for mechanical redundancy, the use of off the shelf parts (off the shelf 5 years ago mind you), and the need for something that didn't require a huge amount of engineering effort to shoe horn into our package. That said, undoubtedly this is one of the areas that will see modification as time passes, and it wouldn't surprise me in the least if 5 years from now there is a DeltaHawk model that in addition to the electric turbo has full FADEC fuel control, an electric water pump, and an integrated starter/generator. Imagine what that will do to the weight and fuel efficiency. Additionally, due to the modular design of all of these components on the DeltaHawk, all of these items are a external to the engine case and for the most part are a bolt on proposition. Dave Driscoll DeltaHawk LLC Bill Daniels wrote: Dave, I like the Deltahawk package the way it is, but I do have a hypothetical question. What are the merits, of lack thereof, of using an electrically boosted turbocharger to supply combustion air for starting or flight idle? It would seem, at first glance, to be a simpler and lighter solution than using both a roots supercharger and a turbo in series. Bill Daniels "Dave Driscoll" wrote in message ... All, In addition to being an lurker and occasional poster on RAH, I also happen to be one of the engineers responsible for the DeltaHawk (or the sole reason the engine hasn't been in full production for the last 3 years according to the marketing guy). In any case, as this is one of my few areas of RAH expertise, I'd be happy to answer any questions that people may have regarding the project. The web site www.deltahawkengines.com is generally pretty up to date, but there are certainly always specific questions that a FAQ won't answer. Dave Driscoll DeltaHawk LLC geo wrote: Here's an interesting new diesel engine with much lower operating costs. Looks like it would fill the bill for a Glass Goose (which I'm considering) very nicely. Waddya think? http://www.deltahawkengines.com/object00.htm |
Thanks for the nice reply. Now I have another question that, while it is about engineering, also relates to a market opportunity. First a bit of background - forgive me if you already know all this.
I fly gliders which are most often hauled into the air by a tow plane. Now glider tugs belong to the same engineering category as tractors used for tractor pull competitions - brute force and not much sophistication. For spark ignition, air cooled engines, glider towing is brutal work - red line temps followed by rapid chill down five or six times an hour. Sometimes, the tug is asked to tow a 1300 pound glider into a mountain wave at 15,000 feet which can really tax the engine's cooling capacity as well as high altitude performance. A Piper Pawnee with a 260 HP Lycoming O-540 has enough power for the job but, without some VERY careful operating techniques, overhauls come up often. Fuel consumption on a Lyc O-540 runs over 20 GPH. All this makes glider tows far more expensive than they should be. A Pawnee with a standard 2-blade prop is also noisy enough to prompt airport neighbor complaints. A glider tug tows at about 65 knots and speeds above that are unimportant. The power package needs to produce maximum thrust for the HP at that airspeed. This fact suggests that a large, slow turning prop or perhaps a ducted fan could do the same job with much less horsepower - and noise. A 160 - 200 HP Deltahawk looks like a perfect match for the job if it were matched to the correct prop. Would you please comment on this application? Bill Daniels "Dave Driscoll" wrote in message ... Bill, I love questions like this, you've already done the heavy lifting and pretty much nailed the merits. The merits start to look even better when you examine the possibilities of putting a clutched shaft on your existing turbo and electrically spin the compressor side as required (reduces weight, gains you the HP that is always being sucked up by the blower which is compressing air at a much lower efficiency than the turbo, etc.) There are also a mess of other possibilities that while more complex from an engineering standpoint offer "better" solutions for certain mission profiles. These include compressed air starts, fully electrical turbos, clutched superchargers, centrifugal or screw compressor supercharges instead of roots type, the list goes on. The selection of our current solution was a combination of the desire for mechanical redundancy, the use of off the shelf parts (off the shelf 5 years ago mind you), and the need for something that didn't require a huge amount of engineering effort to shoe horn into our package. That said, undoubtedly this is one of the areas that will see modification as time passes, and it wouldn't surprise me in the least if 5 years from now there is a DeltaHawk model that in addition to the electric turbo has full FADEC fuel control, an electric water pump, and an integrated starter/generator. Imagine what that will do to the weight and fuel efficiency. Additionally, due to the modular design of all of these components on the DeltaHawk, all of these items are a external to the engine case and for the most part are a bolt on proposition. Dave Driscoll DeltaHawk LLC Bill Daniels wrote: Dave, I like the Deltahawk package the way it is, but I do have a hypothetical question. What are the merits, of lack thereof, of using an electrically boosted turbocharger to supply combustion air for starting or flight idle? It would seem, at first glance, to be a simpler and lighter solution than using both a roots supercharger and a turbo in series. Bill Daniels "Dave Driscoll" wrote in message ... All, In addition to being an lurker and occasional poster on RAH, I also happen to be one of the engineers responsible for the DeltaHawk (or the sole reason the engine hasn't been in full production for the last 3 years according to the marketing guy). In any case, as this is one of my few areas of RAH expertise, I'd be happy to answer any questions that people may have regarding the project. The web site www.deltahawkengines.com is generally pretty up to date, but there are certainly always specific questions that a FAQ won't answer. Dave Driscoll DeltaHawk LLC geo wrote: Here's an interesting new diesel engine with much lower operating costs. Looks like it would fill the bill for a Glass Goose (which I'm considering) very nicely. Waddya think? http://www.deltahawkengines.com/object00.htm |
Bill,
Tailor made application for the DeltaHawk. The liquid cooling will do wonders for evening out the thermal loading, our flight testing indicates full power to beyond 18,000 feet, and the engines flat torque profile "should" take care of your HP needs at lower airspeeds. I say "should" because we won't really know, without taking a much closer look at your application. However, the 160 HP DeltaHawk performs exactly the same as a 200 HP IO-360 in takeoff and climb out in a side by side comparison using the identical aircraft with different engine installations (two Velocity RG's). Based upon that empirical data, I'd venture that the 200 HP DeltaHawk will compare quite favorably performance wise with the Lycoming and further bring both significant weight (50-70 lbs.) and fuel savings to the table. Dave Driscoll DeltaHawk LLC Bill Daniels wrote: Thanks for the nice reply. Now I have another question that, while it is about engineering, also relates to a market opportunity. First a bit of background - forgive me if you already know all this. I fly gliders which are most often hauled into the air by a tow plane. Now glider tugs belong to the same engineering category as tractors used for tractor pull competitions - brute force and not much sophistication. For spark ignition, air cooled engines, glider towing is brutal work - red line temps followed by rapid chill down five or six times an hour. Sometimes, the tug is asked to tow a 1300 pound glider into a mountain wave at 15,000 feet which can really tax the engine's cooling capacity as well as high altitude performance. A Piper Pawnee with a 260 HP Lycoming O-540 has enough power for the job but, without some VERY careful operating techniques, overhauls come up often. Fuel consumption on a Lyc O-540 runs over 20 GPH. All this makes glider tows far more expensive than they should be. A Pawnee with a standard 2-blade prop is also noisy enough to prompt airport neighbor complaints. A glider tug tows at about 65 knots and speeds above that are unimportant. The power package needs to produce maximum thrust for the HP at that airspeed. This fact suggests that a large, slow turning prop or perhaps a ducted fan could do the same job with much less horsepower - and noise. A 160 - 200 HP Deltahawk looks like a perfect match for the job if it were matched to the correct prop. Would you please comment on this application? Bill Daniels "Dave Driscoll" wrote in message ... Bill, I love questions like this, you've already done the heavy lifting and pretty much nailed the merits. The merits start to look even better when you examine the possibilities of putting a clutched shaft on your existing turbo and electrically spin the compressor side as required (reduces weight, gains you the HP that is always being sucked up by the blower which is compressing air at a much lower efficiency than the turbo, etc.) There are also a mess of other possibilities that while more complex from an engineering standpoint offer "better" solutions for certain mission profiles. These include compressed air starts, fully electrical turbos, clutched superchargers, centrifugal or screw compressor supercharges instead of roots type, the list goes on. The selection of our current solution was a combination of the desire for mechanical redundancy, the use of off the shelf parts (off the shelf 5 years ago mind you), and the need for something that didn't require a huge amount of engineering effort to shoe horn into our package. That said, undoubtedly this is one of the areas that will see modification as time passes, and it wouldn't surprise me in the least if 5 years from now there is a DeltaHawk model that in addition to the electric turbo has full FADEC fuel control, an electric water pump, and an integrated starter/generator. Imagine what that will do to the weight and fuel efficiency. Additionally, due to the modular design of all of these components on the DeltaHawk, all of these items are a external to the engine case and for the most part are a bolt on proposition. Dave Driscoll DeltaHawk LLC Bill Daniels wrote: Dave, I like the Deltahawk package the way it is, but I do have a hypothetical question. What are the merits, of lack thereof, of using an electrically boosted turbocharger to supply combustion air for starting or flight idle? It would seem, at first glance, to be a simpler and lighter solution than using both a roots supercharger and a turbo in series. Bill Daniels "Dave Driscoll" wrote in message ... All, In addition to being an lurker and occasional poster on RAH, I also happen to be one of the engineers responsible for the DeltaHawk (or the sole reason the engine hasn't been in full production for the last 3 years according to the marketing guy). In any case, as this is one of my few areas of RAH expertise, I'd be happy to answer any questions that people may have regarding the project. The web site www.deltahawkengines.com is generally pretty up to date, but there are certainly always specific questions that a FAQ won't answer. Dave Driscoll DeltaHawk LLC geo wrote: Here's an interesting new diesel engine with much lower operating costs. Looks like it would fill the bill for a Glass Goose (which I'm considering) very nicely. Waddya think? http://www.deltahawkengines.com/object00.htm |
On Sat, 27 Mar 2004 13:39:39 -0700, "Bill Daniels"
wrote: Thanks for the nice reply. Now I have another question that, while it = is about engineering, also relates to a market opportunity. First a bit = of background - forgive me if you already know all this. I fly gliders which are most often hauled into the air by a tow plane. = Now glider tugs belong to the same engineering category as tractors used = for tractor pull competitions - brute force and not much sophistication. = For spark ignition, air cooled engines, glider towing is brutal work - = red line temps followed by rapid chill down five or six times an hour. =20 Sometimes, the tug is asked to tow a 1300 pound glider into a mountain = wave at 15,000 feet which can really tax the engine's cooling capacity = as well as high altitude performance. =20 A Piper Pawnee with a 260 HP Lycoming O-540 has enough power for the job = but, without some VERY careful operating techniques, overhauls come up = often. Fuel consumption on a Lyc O-540 runs over 20 GPH. All this = makes glider tows far more expensive than they should be. A Pawnee with = a standard 2-blade prop is also noisy enough to prompt airport neighbor = complaints. A glider tug tows at about 65 knots and speeds above that are = unimportant. The power package needs to produce maximum thrust for the = HP at that airspeed. This fact suggests that a large, slow turning prop = or perhaps a ducted fan could do the same job with much less horsepower = - and noise. =20 A 160 - 200 HP Deltahawk looks like a perfect match for the job if it = were matched to the correct prop. Would you please comment on this = application? Bill Daniels Bill, I have a question for you: Why is the O-540 overheating? You are climbing using full rich aren't you? If you are, then the engine should not be overheating. Full rich for takeoff and climb is called for so that the overly rich mixture burns slow enough to allow the Peak Pressure Point to occur around 16 degrees past top dead center. As long as the timing of the magnetos is properly set and the mixture valve is working properly, it would be nearly impossible for the engine to overheat. It does use a lot of fuel with that setting though. You might be interested in the Ford powered Pawnee developed by Dave Sharples in Australia. It's been running for about six years now since they installed it to replace the O-540. Swings the same prop at the same rpm but uses a lot less fuel. The engine took a long time for them to sort out, but once they got it running the way they thought it should, they've bascally forgotten about it, other than routine oil changes and spark plug changes. They developed it strictly for glider tug duty. They were very much hoping to reduce the overhaul costs for the Lycoming. They managed to do that. Corky Scott |
![]() "Corky Scott" wrote in message ... On Sat, 27 Mar 2004 13:39:39 -0700, "Bill Daniels" wrote: Thanks for the nice reply. Now I have another question that, while it = is about engineering, also relates to a market opportunity. First a bit = of background - forgive me if you already know all this. I fly gliders which are most often hauled into the air by a tow plane. = Now glider tugs belong to the same engineering category as tractors used = for tractor pull competitions - brute force and not much sophistication. = For spark ignition, air cooled engines, glider towing is brutal work - = red line temps followed by rapid chill down five or six times an hour. =20 Sometimes, the tug is asked to tow a 1300 pound glider into a mountain = wave at 15,000 feet which can really tax the engine's cooling capacity = as well as high altitude performance. =20 A Piper Pawnee with a 260 HP Lycoming O-540 has enough power for the job = but, without some VERY careful operating techniques, overhauls come up = often. Fuel consumption on a Lyc O-540 runs over 20 GPH. All this = makes glider tows far more expensive than they should be. A Pawnee with = a standard 2-blade prop is also noisy enough to prompt airport neighbor = complaints. A glider tug tows at about 65 knots and speeds above that are = unimportant. The power package needs to produce maximum thrust for the = HP at that airspeed. This fact suggests that a large, slow turning prop = or perhaps a ducted fan could do the same job with much less horsepower = - and noise. =20 A 160 - 200 HP Deltahawk looks like a perfect match for the job if it = were matched to the correct prop. Would you please comment on this = application? Bill Daniels Bill, I have a question for you: Why is the O-540 overheating? You are climbing using full rich aren't you? If you are, then the engine should not be overheating. Full rich for takeoff and climb is called for so that the overly rich mixture burns slow enough to allow the Peak Pressure Point to occur around 16 degrees past top dead center. As long as the timing of the magnetos is properly set and the mixture valve is working properly, it would be nearly impossible for the engine to overheat. It does use a lot of fuel with that setting though. You might be interested in the Ford powered Pawnee developed by Dave Sharples in Australia. It's been running for about six years now since they installed it to replace the O-540. Swings the same prop at the same rpm but uses a lot less fuel. The engine took a long time for them to sort out, but once they got it running the way they thought it should, they've bascally forgotten about it, other than routine oil changes and spark plug changes. They developed it strictly for glider tug duty. They were very much hoping to reduce the overhaul costs for the Lycoming. They managed to do that. Corky Scott As I obliquely mentioned, you need to be VERY careful with the Lyc's operating procedures. Running rich of best power is one of them. Unfortunately, that cuts climb performance which can lead to other dangers such as taking the glider out of gliding range of the runway during the initial climb. It also washes oil from the cylinder walls accelerating cylinder wear, fouls plugs and contaminates the oil among other bad things. In addition to running rich, there is a cool-down protocol after the glider releases. All of this helps engine life at the cost of fuel consumption and the number of revenue tows per hour. Mess up the engine operating protocol just once and the life of the engine is compromised. Economically, glider towing teeters on the brink of being a big money loser. Profits are very elusive and disaster is always close. If an operator is smart enough to make money at it, he's probably smart enough to get seriously rich doing something else. Yes, I am aware of Sharples Ford powered tug. I think it's an all-round great idea. I just wish the FAA would open a loophole in the regs to permit that kind of experimenting here. Unfortunately, the FAA considers a glider tug a "for-hire" commercial operation and damn near enforces Part 135 regs. The Deltahawk seems to have even more advantages than Sharples Ford plus it will be certificated which will satisfy the Feds. Bill Daniels |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 2nd 04 11:41 PM |
Accident Statistics: Certified vs. Non-Certified Engines | Ron Wanttaja | Home Built | 23 | January 18th 04 05:36 PM |
Diesel Jodel information..........and .........diesel plane groups | Roland M | Home Built | 1 | January 4th 04 04:04 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 09:02 PM |
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot | Roland M | Home Built | 3 | September 13th 03 12:44 AM |
