(Koopas Ly) wrote
Agreed. This may sound like a stupid question, but how do you define "gross weight"? Ah yes...a grossly misused term and.....one not used in the FAR. Section 23.25: Weight limits. (a) Maximum weight. The maximum weight is the highest weight at which compliance with each applicable requirement of this part (other than those complied with at the design landing weight) is shown. The maximum weight must be established so that it is -- However a web search shows that "gross weight" is used mainly by state motor vehicle codes as follows: Gross Vehicle Weight or GVW The combined weight of a commercial vehicle and its load. And the military: Definition of: gross weight (DOD, NATO) 1. Weight of a vehicle, fully equipped and serviced for operation, including the weight of the fuel, lubricants, coolant, vehicle tools and spares, crew, personal equipment, and load. 2. Weight of a container or pallet including freight and binding. See also net weight. Using "gross weight" for aircraft can be misleading....for example: The Boeing-707 had a maximum "taxi weight" of 336,000 lbs, and a maximum "takeoff weight" of 333,100 lbs. And....its maximum takeoff weight might be limited to the maximum landing weight plus the weight of the fuel burned during the flight or to the maximum weight that would allow compliance with the second segment climb requirements. What was its "gross weight"? Pilots who use the term "gross weight" aren't very well versed in the FARs. Bob Moore |
Landing and T/O distances (Was Cold War ALternate Basing) | Guy Alcala | Military Aviation | 3 | August 13th 04 12:18 PM |
Space Elevator | Big John | Home Built | 111 | July 21st 04 04:31 PM |
Va and turbulent air penetration speed. | Doug | Instrument Flight Rules | 70 | January 11th 04 08:35 PM |
Va and turbulent air penetration speed. | Doug | Owning | 69 | January 11th 04 08:35 PM |
New Film: The Need For Speed - Going to war on drugs | Phil Carpenter | Military Aviation | 0 | July 23rd 03 07:43 AM |
