On Fri, 26 Mar 2004 22:26:50 -0600, Dave Driscoll
wrote: I'd be happy to answer any questions that people may have regarding the project. Hi Dave How do you get a diesel restarted in the air if you happen to have multiple fuel tanks and run one dry so the injection system gets air in it? Is there a way around this problem? Jim |
Jim,
The engine is designed to be fairly fault tolerant of air bubbles in the low pressure fuel lines (the returns from the pump element gallery are positioned above the high pressure gallery inlet etc.) and will continue to deliver solid fuel through the high pressure lines even with bubbles in the low pressure ones. It will also repurge the high pressure lines even in the event that you run them completely dry. You simply have to reintroduce fuel to the system and keep spinning the prop at greater than 150 rpm. How long it takes for a restart is based upon how dry the system was and how fast you can spin the prop. This however is not a good practice as the high pressure pumps will be operating without lubrication on the top side until the fuel is reintroduced. The collective thoughts of the group are that you can certainly get away with it a couple of times, but better be thinking about inspecting the high pressure plungers after the 2nd full dry restart. Dave Driscoll DeltaHawk LLC jpollard###mnsi.net wrote: On Fri, 26 Mar 2004 22:26:50 -0600, Dave Driscoll wrote: I'd be happy to answer any questions that people may have regarding the project. Hi Dave How do you get a diesel restarted in the air if you happen to have multiple fuel tanks and run one dry so the injection system gets air in it? Is there a way around this problem? Jim |
On Sun, 28 Mar 2004, Dave Driscoll wrote:
This however is not a good practice as the high pressure pumps will be operating without lubrication on the top side until the fuel is reintroduced. The collective thoughts of the group are that you can certainly get away with it a couple of times, but better be thinking about inspecting the high pressure plungers after the 2nd full dry restart. Most of my diesel experience is with engines using Stanadyne DB2 injection pumps. Stanadyne makes what they call an "Arctic kit" for this pump that makes it insensitive to fuel lubricity by, if I understand correctly, changing the material of some parts so any fuel, even gasoline, can be used without damage to the injection pump. I've always wondered why they don't make all the pumps that way to begin with; maybe there's a downside I'm not aware of. Why doesn't DeltaHawk set up the injection pump that way? Speaking strictly as a layman, it seems it would solve the run-dry damage problem, as well as providing some emergency fuel flexibility. -Dan |
Dan,
The DB2 is a little different animal than what we use on the DeltaHawk. The DeltaHawk uses an independent, high pressure, plunger style pump element for each cylinder. These run at significantly higher pressure than the DB2 and also allow for redundancy in that the failure of a single pump element will only take out a cylinder not the entire fuel system. While in the DeltaHawk application there are some significant advantages to the plunger style pump, what is commercially available in this style of pump is not as fault tolerant to fuel lubrisity as the DB2. However, although we currently use an off the shelf element, there are some improvements that can be realized when volumes will allow us to create a high pressure injection pump tailored to our specific application. The long and short of things, with the current pump is that while repriming once or twice isn't going to destroy the engine, it isn't something that should become routine. Dave Driscoll DeltaHawk LLC Dan Youngquist wrote: On Sun, 28 Mar 2004, Dave Driscoll wrote: This however is not a good practice as the high pressure pumps will be operating without lubrication on the top side until the fuel is reintroduced. The collective thoughts of the group are that you can certainly get away with it a couple of times, but better be thinking about inspecting the high pressure plungers after the 2nd full dry restart. Most of my diesel experience is with engines using Stanadyne DB2 injection pumps. Stanadyne makes what they call an "Arctic kit" for this pump that makes it insensitive to fuel lubricity by, if I understand correctly, changing the material of some parts so any fuel, even gasoline, can be used without damage to the injection pump. I've always wondered why they don't make all the pumps that way to begin with; maybe there's a downside I'm not aware of. Why doesn't DeltaHawk set up the injection pump that way? Speaking strictly as a layman, it seems it would solve the run-dry damage problem, as well as providing some emergency fuel flexibility. -Dan |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 2nd 04 11:41 PM |
Accident Statistics: Certified vs. Non-Certified Engines | Ron Wanttaja | Home Built | 23 | January 18th 04 05:36 PM |
Diesel Jodel information..........and .........diesel plane groups | Roland M | Home Built | 1 | January 4th 04 04:04 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 09:02 PM |
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot | Roland M | Home Built | 3 | September 13th 03 12:44 AM |
