The wording of the FAR is indeed confusing. However, the PTS for
flight instructor (airplane) clearly states that a commercial/instrument or ATP is a prerequisite for the checkride. I know that the PTS is not regulatory, but if you don't satisfy the PTS requirements you won't pass the checkride regardless of what you think the FAR says. Also, I believe that only an airplane or airship instructor rating requires an instrument rating. In that context, the wording "OR privileges on that person's pilot certificate that are appropriate to the flight instructor rating sought" starts to make some sense. "Chris" wrote in message ... I'm glad I'm not the only one who thinks the "OR" in that regulation is alittle wordy. -Chris "Peter Duniho" wrote in message ... "Larry Fransson" wrote in message news:2003112817560816807%larry@larryandjennynet... For a flight instructor certificate with an airplane rating, you must have a commercial certificate with an instrument rating. If you're going for a helicopter CFI, you don't need the instrument rating. I have to admit, I understand why Chris could not parse 61.183(c)(2). It says a person needs "an instrument rating, OR privileges on that person's pilot certificate that are appropriate to the flight instructor rating sought". If you're not trying to get qualified to instruct instrument flight, why would you need an instrument rating, assuming you had all the other necessary privileges on your pilot certificate? What does "privileges on that person's pilot certificate that are appropriate to the flight instructor rating sought" actually mean? I'd never actually looked at this particular line that closely, and had always assumed you are required to have an instrument rating to get a flight instructor certificate. But now I don't see how the regulation specifically says this (though I admit, the regulation is worded so oddly, I'm not really sure what it DOES say ![]() an instrument rating, but does not clarify what the reasoning behind that conclusion is. They seem to think the regulation is clear as written. Pete |
"Andrew Sarangan" wrote in message
om... Also, I believe that only an airplane or airship instructor rating requires an instrument rating. In that context, the wording "OR privileges on that person's pilot certificate that are appropriate to the flight instructor rating sought" starts to make some sense. Since the clause containing the "or" applies only to ratings for which an instrument rating is required, I don't follow your logic there. I just don't see why the regulation is written that way. It could be MUCH clearer, and your suggestion doesn't cause it "to make some sense" in my opinion. Pete |
On 2003-11-30 13:38:20 -0800, "Peter Duniho" said:
Since the clause containing the "or" applies only to ratings for which an instrument rating is required, I don't follow your logic there. I just don't see why the regulation is written that way. It could be MUCH clearer, and your suggestion doesn't cause it "to make some sense" in my opinion. You don't actually need an instrument rating for all of the ratings listed. Here's how 61.183(2) reads: (2) An instrument rating or privileges on that person's pilot certificate that is appropriate to the flight instructor rating sought, if applying for-- (i) A flight instructor certificate with an airplane category and single-engine class rating; (ii) A flight instructor certificate with an airplane category and multiengine class rating; (iii) A flight instructor certificate with a powered-lift rating; or (iv) A flight instructor certificate with an instrument rating The "or" may make sense when you think of ratings in a broader sense, encompassing all flying machines, not just airplanes. I previously mentioned the example of a multiengine rating restricted to VFR. That would certainly seem to exclude "instrument privileges" in the case of (ii), where the pilot might have an instrument rating, but no instrument privileges in multiengine airplanes. If we take a broader look, you might think about a pilot who has a commercial certificate with an airplane single engine rating, a rotorcraft helicopter rating, and an instrument helicopter rating. Obviously, that pilot has an instrument rating, but it certainly does not include instrument privileges for any airplane ratings. Does that begin to make some sense? |
news:2003113014312075249%lfransson@comcastnet... You don't actually need an instrument rating for all of the ratings listed. I know. That was my point. The "or" may make sense when you think of ratings in a broader sense, encompassing all flying machines, not just airplanes. How so? The regulation you quoted clearly restricts the "or" clause to airplanes, powered-lift aircraft (which are basically airplanes, and it's because of that they are included with airplane-related regulations), or instrument instruction in any aircraft. That's my whole point. Andrew's statement was to the effect that the "or" is there for aircraft other than airplanes. My reply was that the "or" specifically applies only to aircraft like airplanes. I honestly have no idea what YOUR point is here. [...] If we take a broader look, you might think about a pilot who has a commercial certificate with an airplane single engine rating, a rotorcraft helicopter rating, and an instrument helicopter rating. Obviously, that pilot has an instrument rating, but it certainly does not include instrument privileges for any airplane ratings. Does that begin to make some sense? It in no way explains why the clause beginning with "or" is present in the regulation. Pete |
RAF Blind/Beam Approach Training flights | Geoffrey Sinclair | Military Aviation | 3 | September 4th 09 06:31 PM |
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk | Jehad Internet | Military Aviation | 0 | February 7th 04 04:24 AM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
