Tailwheel endorsement
Old December 9th 03, 04:28 PM
Robert M. Gary
Cub Driver wrote in message . ..
Well, I am not looking to the side when I land the Cub (Super Cub,
Husky, Great Lakes). Seems to me it's done with peripheral vision.
Of course, the fields in New England are mostly bordered by pine
trees. I admit this was much more of a challenge when I had to do it
in Arizona (Super Cub, Great Lakes). But I still don't think I
actually turned my head and looked to the side.
Your right, and perhaps I didn't describe it correctly. In the J-3
(the Super Cub is different because you are in the front seat) I
"crane" my head to the side but look forward around the cylinders on
the side. So I'm looking forward, but my head to hanging around the
side.
Old December 9th 03, 08:18 PM
Cub Driver
I
side.
I suppose this is one reason I like to slip it in. You get to see the
runway that way.
all the best -- Dan Ford
email:
see the Warbird's Forum at
www.warbirdforum.com
and the Piper Cub Forum at www.pipercubforum.com
Old December 9th 03, 08:35 PM
EDR
If you use the "look to the side method", how do you correct for drift?
How far away from the aircraft do you look?
Do you look at the upwind or downwind side?
Old December 10th 03, 05:37 PM
Robert M. Gary
EDR wrote in message ...
Depends on the plane. In the J-3 I keep the center line under the main
at all times. Its kind of my personal challenge, to always have the
main in the middle of the painted center line. I usually just slip it
until I get down to about 2 feet, so its really only the flare that
I'm concerned with.
Not sure I understand the question. I usually have 1/2 a face full of
cowling and 1/2 a face full of runway ahead of me with cylinders
somewhat in the way.
Depends on which side is most likely to have something jump out in
front of me. I'll use either side.
In most of these planes, if you don't bring them in too hot, the flare
only lasts a couple seconds at most.
Old December 10th 03, 11:48 PM
Michael
In most of what planes? In the Cub, I agree with you. It CAN be
landed by looking out the side, and in fact that's how I was taught to
land it. In the Cub, you can actually see the main gear by looking
out the side.
Basically, there are the "Look to the side" people and the "Look
straight ahead and use peripheral vision" people. I've been taught
both ways (with the "Look to the side" method being taught first),
have used both ways, and I'm now squarely in the "Look straight ahead
and use peripheral vision" camp. One particular airplane made me a
believer.
That airplane was the Starduster Too. Due to the mission as well as
some design quirks (it's a homebuilt) it needed to come down final at
90-95 mph. Touchdown would occur around 70-75 (my best guess) in the
three point attitude. Wheel landings were impossible - even if you
pushed the stick full forward, the tailwheel would still come down
immediately. Full stall in free air was just over 60 mph.
The first instructor to try to check me out in the plane was of the
"Look to the side" school, and tried to teach me that way. All he
really succeeded in doing two hours was convincing me the plane was
unsafe. I took another shot with another instructor a while later,
and he taught me the "Look straight ahead and use peripheral vision"
method. In 90 minutes I soloed the airplane.
He also explained that looking out to the side does work with some
taildraggers, but not others. For example, (at least according to
him) nobody lands a Pitts by looking out to the side.
I tried looking out the side of teh 'Duster a couple of times on
landing, and discovered that it just doesn't work. You can't get
enough attitude and altitude cues to flare properly. Visibility is
terrible - there is no way to see the main gear, or much of anything
else.
I suppose that without that airplane (and the instructor who taught me
to fly it) I would still be looking out to the side - but I now
consider it to be an inferior method of limited application.
Michael
Old December 12th 03, 01:48 PM
Rocky
(Michael) wrote in message . com...
out the side.
believer.
Michael
Your post indicates obvious experience with a number of aircraft. But,
it also sounds like you are using both "straight ahead, and peripheral
vision" methods. Even if unconciously?
As with any flight instruction, there are those who have their own
tried and true method that works for them but in many cases it is
fairly restricted either by aircraft type or pilot experience.
Just as a WAG (wild assed guess) I've flown 20-30 different types of
tailwheel aircraft with more than casual or courtesy flights. Read
that as "worked" them. Each of them required their own particular
techniques as you point out. You can't just point it ahead and hope!
A number of the aircraft I've flown are radial engined which means a
lot of iron and aluminum out in front and restricting view on the
ground. Once that tail comes up, the view improves but not always a
lot?! When you operate off a strip that is barely as wide as your
landing gear track you simply have to be good or you end up in the
bushes/trees/rocks/buildings/water/etc,etc.
Like you say, there is no one way to do it. Anyone who argues with
that is a fool and headed for disaster.
12,000 doing crop duster work and another 10,000 doing other stuff.
else.
Michael
Tailwheel ID R. Mueller Aviation Marketplace 2 February 5th 08 10:25 PM
Tailwheel question Steve B Aerobatics 4 January 30th 04 03:35 AM
Advice on flying Pitts with Haigh Locking Tailwheel Ditch Home Built 19 January 4th 04 10:18 PM
Tailwheel tires Dan Thomas Piloting 10 November 26th 03 02:53 PM
homebuilt tailwheel Del Rawlins Home Built 7 November 9th 03 02:34 AM
