28 volt pitot heat
Old April 8th 04, 05:06 AM
Paul Lee
I made my own heated pitot with aluminum tubing and a 12V Cessna pitot
heater element. You can see the details at http://www.abri.com/sq2000/18.html
(about 5 frames from the bottom). The total cost was about $40 - and it's
"new".
Paul Lee, SQ2000 canard www.abri.com/sq2000
(B2431) wrote in message ...
Will running a 28 volt pitot tube heat on 12 volts heat it enough to use? I
keep seeing 28 volt pitot tubes on e-bay and was wondering if they would do the
job.
Dan, U.S. Air Force, retired
Old April 17th 04, 12:13 PM
B2431
Date: 4/7/2004 11:06 PM Central Daylight Time
Message-id:
"new".
I
job.
I like it. Mind if I swipe the idea?
Old April 17th 04, 03:25 PM
dave
Hi all,
Can the standard heated pitot tube element be changed?
I have looked at mine and can't figure how to get it apart.
I believe its the standard 5812-12v type.
Thanks
Dave
Message-id:
"new".
I
job.
Heat treating wing ribs Holger Stephan Home Built 13 February 3rd 04 11:59 PM
Pitot and static couplings for a TTU-205 B2431 Home Built 0 August 15th 03 07:25 AM
Pressure Differential in heat Exchangers Bruce A. Frank Home Built 4 July 3rd 03 05:18 AM
