On Tue, 23 Dec 2003 16:51:25 +0930, David Pears
wrote: On Mon, 22 Dec 2003 23:15:49 GMT, (Bruce Hamilton) wrote: I hope this post doesn't sound impolite or abusive to you, as you obviously wanted to add some data, but the storage constraints on Avgas mean it has to be regularly retested before it can be accepted as fuel for aircraft. Avgas is usually more stable than Mogas, but it still has to be within a current test period. I though gas turbines (as used in aircraft engines) would run on just about any old liquid, as long as it has a hint of hydrocarbon in it? Yes and no, as Air New Zealand discovered. Many gas turbines have other components like fuel pumps that turn out to be quite sensitive to the lubricating properties of the fuel. The lubrication properties of Avgas/Mogas are near nil. Jet A is actually pretty slippery stuff. So while you can burn just about anything in the turbine, you have to make sure that doing so doesn't damage something else... David |
![]() "matt weber" wrote in message reply::: I though gas turbines (as used in aircraft engines) would run on just about any old liquid, as long as it has a hint of hydrocarbon in it? Yes and no, as Air New Zealand discovered. Many gas turbines have other components like fuel pumps that turn out to be quite sensitive to the lubricating properties of the fuel. The lubrication properties of Avgas/Mogas are near nil. Jet A is actually pretty slippery stuff. So while you can burn just about anything in the turbine, you have to make sure that doing so doesn't damage something else... David We had Garrett turbines powering 60Hz alternators at the Cooby Creek Tracking Station at Toowoomba in the late 60's and found the FCU's chewing up their internal bearings like crazy until we got an anti-static additive put in the ATK. Electrostatic corrosion. -- JW˛ Norton AntiVirus 2003 installed ************************************ |
David Pears wrote:
I though gas turbines (as used in aircraft engines) would run on just about any old liquid, as long as it has a hint of hydrocarbon in it? The problem is that turbine fuel ( effectively an aviation kerosine ) has to also satisfy several requirements, both with regard to engine performance and safety. The fundamental ones are flash point ( temperature at which the fuel will give off sufficient vapours to ignite if a flame is applied ) and freezing point ( engines tend to stop when fuel turns to sludge ). Avgas has suitably low freezing point, but the flash point is far lower than the fuel systems on a commercial Jet A1 fuelled airliner are designed to cope with. Military airliners often use a wide cut kerosine with a flash point well below airfield ambients. If a plane is carrying passengers, it's usually running on Jet A1, a narrow cut fuel with a flash point above most airfield ambient temperatures ( 38C ). Flash point is also the easiest method of detecting whether a kerosine has been contaminated by a gasoline. The 1997 explosion of the "empty" centre tank in TWA Flight 800, has reignited interest in fuel flammability issues. Kerosines tend to have more lubricity than gasolines ( higher sulphur and viscosity ) but high pressure hydrotreating and hydrocracking have made fuels "harder" ( less lubricity ), and NZ aviation authorities have convinced other countries to include a lubricity specification in DefStan 91-91 but, AFAIK, it's not yet in the more common ASTM D1655. Note that refractory elements ( silicon, calcium, potassium, vanadium etc ) will erode-deposit on turbine blades, and they are present in higher boiling fractions such as diesel ( which wouldn't pass the freezing point requirement - but is used on ship and power-station gas turbines ). Fuels for gas turbines tend to ensure such elements aren't present, even though falling out of the sky isn't an option, as overhauls are very expensive. There are a whole heap of other criteria for Jet fuels associated with cleanliness, corrosivity, combustion properties, stability and approved additives that mean than commercial aircraft tend to use a well defined narrow cut kerosine fraction. Bruce Hamilton |
Another C-17 On The Way | John A. Weeks III | Military Aviation | 10 | February 24th 04 05:22 PM |
Grandmother Goes Down at the Pole | BJ | Home Built | 66 | January 13th 04 04:10 PM |
Hotbeef owns the air with his pole vault .... | The Injector | Owning | 0 | December 22nd 03 07:51 PM |
