Question about epoxy resin chemistry..
Old April 10th 04, 02:58 AM
Blueskies
Me thinks the 'panels' are riveted on semi-cured because in the good ol' days when resins cured they were brittle. These
are simply skins on the wing and they are not adhered via the resin; the resin is supposed to be slightly green to allow
it to conform to the airfoil without cracking.
Lay out the panels on a big piece of glass and it will be pin hole free when you pull it off. The panel can be trimmed
to size while still on the glass. How many layers of what kind of glass are used in the lay-up? How sharp is the
tightest bend?
Dan D.
"Corky Scott" wrote in message ...
On Fri, 09 Apr 2004 15:37:51 GMT, Ernest Christley
Corky Scott wrote:
Ernest, I'm not sure I understand the problem. Most kits that require
fiberglass supply the recommended type of resin. If you are doing
something other than buiding a kit, you could just look at what the
kits supply and use that, couldn't you?
Why is this so difficult? Are you designing your own airplane?
Thanks, Corky Scott
Hey, Corky! I believe you were involved in the most informative thread
I found as I was searching the archives of this group.
Let me see if I can convey a least part of my confusion. The Dyke Delta
JD-2 is a plans built craft...ie, no kit. The plans specify that the
composite wing skins be laid up on a flat table and then wrapped and
riveted to the stainless steel ribs before it is fully cured.
I'm at work, so don't have the plans in front of me, but the instruction
read something like:
The prototype uses polyester vinyl resin. Other types of resins are
available. Follow resin manufacturer's instructions.
May not be the exact wording, but that is the gist of it. John Dyke has
had a lot of problems over the years with the resin continuing to
shrink, exposing the weave, etc. So I want to avoid those problems.
That's the start of the confusion.
Ah, got it. The only suggestion I can make would be to speak to the
folks who supply the plans materials and see what type of resin they
are now offering. Perhaps it's different from the one originally
called for by John Dyke.
If that doesn't give you satisfaction, I think I'd speak to the
manufacturers of the various resin systems and ask the opinion of the
experts there. Explain what it is you are trying to do and why you
are asking for their opinion.
The covering process sounds complex: you have to allow the cloth to
semi cure, and then lay it one such that it bonds in place. Man, that
sounds like a narrow window.
Saw one of those things zipping by at a Waco fly-in in Ohio back in
'93 or so. It was FAST.
Corky Scott
Old April 11th 04, 03:43 AM
Ernest Christley
tightest bend?
Wow. Big piece of glass. The skins will be a triangle with 8ft sides.
The plans specify two layers of 7.5 or 10oz glass. They extend up to
the 1" radius of the leading edge, but don't actually go around it.
http://www.ernest.isa-geek.org/
"Ignorance is mankinds normal state,
alleviated by information and experience."
Veeduber
Old April 13th 04, 12:56 AM
Blueskies
Yes, I guess that would be a big piece of glass (don't take anything out of context here!). Do the plans/instructions
have any other suggested way to lay up the panels?
As far as bending the finished panels, a two layer lay-up will be quite flexible, even fully cured, and as long as you
don't have to wrap around the LE I'm sure you will not have any problems with cracking. Have you looked at the
http://www.westsystem.com/ site? Good stuff...
Dan D.
"Ernest Christley" wrote in message om...
These
allow
trimmed
tightest bend?
Veeduber
Old April 13th 04, 03:28 AM
Richard Lamb
Dan D.
I've been told that West does indeed make a laminating resin,
but this isn't it.
West 105/205 is absolute best stuff I've ever used - on wood.
It will probably be great on wood/foam structures.
But it's not what I ever use (again) for laminating glass fabrics.
I used to use Dow 330 / 147(?) but my source quit carrying it
(because I was the only one buying it?)
My impression is that resins like 330 that don't use MDA (Methyl
Diethel Amines???) share a common "problem". At low temperatures
they tend to "separate out". The resin has an odd lumpy look on
the surface and there will be a lump of soft rock candy in the center.
It is real simple to correct by immersing the resin container in hot
water for a while. When the soup is clear again, it's ready to use.
But if the resin is at all "crystallized", it won't completely set -
ever.
It even says so in the directions!
For those who read such things...
Got AeroPoxy(?) last resupply to make a new cowling for Leo's
Super Zodiac. I've used it before, no complaints (other than the
MDA toxicity?).
So, what is it that you are building?
Richard
Old April 13th 04, 05:52 PM
Ernest Christley
Dan D.
but this isn't it.
ever.
MDA toxicity?).
Richard
Dyke Delta JD-2. http://www.ernest.isa-geek.org for the whole story.
The skins, turtleback and cowling are all fiberglass. Some builders
have also glassed the belly, tailfin and control surfaces (plans call
for fabric there).
Veeduber
Old April 14th 04, 01:14 AM
Richard Lamb
Dan D.
but this isn't it.
ever.
MDA toxicity?).
Richard
for fabric there).
Veeduber
I remember now, Earnie. Sorry.
What you really need is a store window that you can make up some
flat glass panel stock on.
I've never done one that size before, but I've laid up light flat
stock on the glass patio door...
Advice? CLEAN it first! Sterile is good.
Then spray a coat of PVA, and slap it up there.
I used a 5 mill plastic cover over the wet fiberglass,
and a piece of plywood for a pressure plate
Vacuum would work better, of course, but I couldn't hook
the TV up to the glass door (TV sucks, doesn't it!)
So what did Dyke recommend?
Richard
Old April 14th 04, 04:30 AM
Ernest Christley
Richard
He's at Sun'n'Fun. Waiting for him to check back in to our email list.
I do like the store glass window idea, though. I have an uncle who
'collects' that sort of thing. Time to investigate.
Veeduber
Old April 13th 04, 06:07 PM
Ernest Christley
The directions say to lay it up on a couple pieces of MDF laid
side-to-side, with a piece of tape down the center. I have to cut forms
for the stainless steel ribs, so I thought an improvement on this
technique might be to use the forms to shape the MDF so that the
resulting layup is nearly the correct shape already. Very little
bending==very little built up stress.
The biggest improvement would be not to have to make the skins at all.
I've looked at G-10 and FR4, and have found several manufactures with
lots of data sheets. Reading them, I keep hearing that eerie refrain,
"You are in a maze of rooms, all slightly different..."
Looked there. Good stuff...IF you're building a boat, or a trailer, or
a chair. Goes back to what I said before. Every manufacturers claim
that what they have is good for whatever you're doing. While that just
may be true, but I don't trust it to be, and it is so much unfamiliar
territory that I just keep getting lost. What I need is a map to help
seperate the hype from the information.
Veeduber
Tecumseh Engine Mounting Question jlauer Home Built 7 November 16th 03 01:51 AM
Vacuum Baggin vs. Resin Infusion Steve Home Built 0 August 21st 03 05:25 AM
Fiberglass Vacuum Bagging Technique...Resin Infusion Steve Home Built 5 August 8th 03 06:10 PM
question: differences between epoxy layup and plaster Morgans Home Built 3 August 6th 03 04:46 AM
