Dr. George O. Bizzigotti wrote:
"G.R. Patterson III" wrote: Basically, the pilots need to get their masks on and get the plane down below 25,000' as rapidly as it can possibly be done. The descent to 10,000' can be made a little more leisurely, but not much - there's always someone in the cattle section who panicked and isn't wearing a mask. One aspect that I have not seen addressed in this thread is the fact that most oxygen systems can provide supplemental oxygen for a few minutes only (I dimly recall figures like 3-5 minutes, but that may be inaccurate). The pilots also need to get down to 10,000 feet within that time before everyone's oxygen generators run out. How could an SST like the Concorde get from cruising altitude down to 10,000 feet in 3-5 minutes? |
Easily. My MU-2 can descend 10,000fpm. Any jet can easily do it.
Mike MU-2 "Scott M. Kozel" wrote in message ... Dr. George O. Bizzigotti wrote: "G.R. Patterson III" wrote: Basically, the pilots need to get their masks on and get the plane down below 25,000' as rapidly as it can possibly be done. The descent to 10,000' can be made a little more leisurely, but not much - there's always someone in the cattle section who panicked and isn't wearing a mask. One aspect that I have not seen addressed in this thread is the fact that most oxygen systems can provide supplemental oxygen for a few minutes only (I dimly recall figures like 3-5 minutes, but that may be inaccurate). The pilots also need to get down to 10,000 feet within that time before everyone's oxygen generators run out. How could an SST like the Concorde get from cruising altitude down to 10,000 feet in 3-5 minutes? |
![]() "Scott M. Kozel" wrote in message How could an SST like the Concorde get from cruising altitude down to 10,000 feet in 3-5 minutes? I'd guess about 3-4 minutes from FL600 to 10K. Just my guess, never read up on the craft. But 12-15 K ft/m would not be unusual in an emergency descent. Regards, John Gaquin B727, B747 |
![]() "Scott M. Kozel" wrote in message ... How could an SST like the Concorde get from cruising altitude down to 10,000 feet in 3-5 minutes? Push the yoke forward :-) |
On Wed, 31 Dec 2003 at 11:53:49 in message
, Scott M. Kozel wrote: How could an SST like the Concorde get from cruising altitude down to 10,000 feet in 3-5 minutes? I believe with the two inboard engines on reverse thrust the outer two on idle. On my only Concorde flight (a test with volunteer passengers) we descended from cruise height with two engines on reverse thrust. All I remember was that the clouds below seemed to come up very fast! -- David CL Francis |
![]() "Scott M. Kozel" wrote in message ... How could an SST like the Concorde get from cruising altitude down to 10,000 feet in 3-5 minutes? Easy, it's called an Emergency Descent. Power to idle, spoilers/speedbrakes deployed, maybe gear extended (depends on aircraft), then dive at redline speed. The airplane I fly (Lear 60) it takes an initial deck angle of ~ 20 degrees nose down to obtain redline, then ~ 10-12 degrees to hold it there. We practice it every time we have a simulator check. Never takes more than 3 mins to get from FL450 to 10,000 ft. Mish |
Mish
Do you have enough bleed air with throttles at idle? Thrust curve is not linear with throttle position so some rpm above idle might be required in some birds??? Change in time down to 18K or so would not be much different. I used a figure of 18K as a target alt to get on the safe side in a emergency descent. USAF set 34K (cockpit altitude) as the point to go to pressure breathing. Easy to suck in and fill lungs and hard to breath out (open exhaust valve). This assisted the lungs to get enough oxy. Took a while to accustom to blowing out with each breath against valve but soon became routine. Big John Pilot ROCAF On Mon, 05 Jan 2004 18:38:52 GMT, "Gary Mishler" wrote: "Scott M. Kozel" wrote in message ... How could an SST like the Concorde get from cruising altitude down to 10,000 feet in 3-5 minutes? Easy, it's called an Emergency Descent. Power to idle, spoilers/speedbrakes deployed, maybe gear extended (depends on aircraft), then dive at redline speed. The airplane I fly (Lear 60) it takes an initial deck angle of ~ 20 degrees nose down to obtain redline, then ~ 10-12 degrees to hold it there. We practice it every time we have a simulator check. Never takes more than 3 mins to get from FL450 to 10,000 ft. Mish |
"Big John" wrote in message
... Do you have enough bleed air with throttles at idle? Thrust curve is not linear with throttle position so some rpm above idle might be required in some birds??? The Lear 60 has big Pratts on it so it does have enough bleed air to run everything at idle. The 50 and 30 series Lears I flew didn't usually have enough bleed air at idle to run both pressurization and anti-ice. Like you said above, on those planes you had to have some power greater than idle to hold the cabin with anti-ice on. Now on the old 20 series lears I hear you had to have the rpm up just to hold cabin altitude. Hope that answers your question, Mish |
Dr. George O. Bizzigotti wrote: "G.R. Patterson III" wrote: Basically, the pilots need to get their masks on and get the plane down below 25,000' as rapidly as it can possibly be done. The descent to 10,000' can be made a little more leisurely, but not much - there's always someone in the cattle section who panicked and isn't wearing a mask. One aspect that I have not seen addressed in this thread is the fact that most oxygen systems can provide supplemental oxygen for a few minutes only (I dimly recall figures like 3-5 minutes, but that may be inaccurate). The pilots also need to get down to 10,000 feet within that time before everyone's oxygen generators run out. How could an SST like the Concorde get from cruising altitude down to 10,000 feet in 3-5 minutes? emergency descent, throttles set, dirty up, hold pitch. regularly practiced procedure. the express elevator down. |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
Order your FREE Small Blue Planet Toys Christmas Catalog before Oct 20th! | Small Blue Planet Toys | Aviation Marketplace | 0 | October 15th 03 05:26 PM |
Invest small Earn Large ($20 000+) | promethean | General Aviation | 0 | October 3rd 03 06:08 AM |
Small Blue Planet Toys goes Postal !! Economy Shipping Options now availalble | Small Blue Planet Toys | Aviation Marketplace | 0 | July 11th 03 04:00 PM |
