#121
![]() "khobar" wrote in message news:_7iJb.16944$7D3.30@fed1read02... C J Campbell wrote in message ... | | What bullets, if any, possess sufficient energy to penetrate an airliner | window and would that airliner window spider or would said bullet simply | leave a small hole? We already know that an adult PAX will, apparently, fit | through a typical airliner window. | We do not really know any such thing. If the passenger is bigger than the window he simply cannot be pulled through it any more than he can sucked up through a vacuum cleaner hose. http://aviation-safety.net/database/1973/731103-0.htm "As a result, the cabin depressurized and one cabin window, which was struck by a fragment of the fan assembly, separated from the fuselage. The passenger who was sitting next to that window was forced through the opening and ejected from the aircraft." http://www.super70s.com/Super70s/Tech/Aviation/Disasters/73-11-03(National). asp "According to a witness, the occupant of the seat was partially forced through the window opening and was temporarily retained in this position by his seatbelt. Efforts to pull the passenger back into the airplane by another passenger were unsuccessful, and the occupant of seat 17H was subsequently forced entirely through the cabin window." Paul Nixon No doubt the pax in ? departed through the hole left by the "window". "Windows for AC" are essentially like those used in houses, in that they are "Prefab Units" of a specified size installed/secured in the structure of the house or A/C. Just as with a window in a house, there is a vast difference in the size hole remaining between the glass being broken out, compared to the entire Prefab Unit being forced from the structure. The "Prefab Window" departing the A/C structure surely weakened the A/C structure surrounding the "Departed Window". In 1 of the above references, it is stated, the pax that lost was sitting in seat 14L. #'s 1 & 2 engines were damaged by FOD from the #3 engine, plus assorted damage to wings & their components. It would be interesting to know if the engine fragment that caused the "Window Failure" struck the window/window frame structure from inside or outside. Most uncontained engine failures result in damage to the A/C in patterns at/near 90 degrees to the engine components "plane of rotation" for the failed components. Anyone know the angle between the "plane of rotation" for the "fan assembly" of the #3 engine & engines #'s 1 & 2. Ralph Nesbitt Professional FD/CFR/ARFF Type |
#123
Ralph Nesbitt wrote in message
m... I have no experience with "A/C Window Bullet Impact". Have seen "Spidering due Debris" from "uncontained engine failures. Have seen, dealt with the aftermath of encounters between fighter type A/C & large birds such as "Buzzards, Eagles, or other large carrion Feeders. I have seen some of those. They make quite a mess. The "Windshields of Southern 232", a DC-9, were broken out along with "Catastrophic Engine Damage" by hail at altitude resulting in a catastrophic incident. Many "Hail Stones of ~3" Diameter were in the cockpit when we arrived on scene within ~ 7 minuets of the incident. There were substantial "Dents/Dings" in the rear cockpit bulkhead from the "Hail Stones". You've probably seen the Easyjet pics: http://www.zap16.com/Easyjet%20out%20of%20hail.htm Paul Nixon |
#124
![]() "Mary Shafer" wrote in message | | Langeweische wrote, in his article about the ValuJet accident, that no | passenger had ever been saved by cabin O2. I don't know where he got | that information, but he's pretty good about checking statements like | that. He is probably right. At the altitudes airliners fly the partial pressure of oxygen is too low to be absorbed by the bloodstream. You could fill the entire cabin with pure oxygen and everybody would still suffocate. Those little masks are not pressurized. Even if they were, the little elastic thingies that hold the mask on would not maintain the required pressure. The crew, of course, have pressurized masks. On the other hand, it would take some time for people to start dying or suffering permanent brain damage from lack of oxygen. The frail would be most vulnerable, but a healthy passenger would at worst just pass out until the airliner descended into breathable air. |
#125
"C J Campbell" wrote;
....... At the altitudes airliners fly the partial pressure of oxygen is too low to be absorbed by the bloodstream. You could fill the entire cabin with pure oxygen and everybody would still suffocate. Those little masks are not pressurized. If that were true, why would mountain climbers take little bottles of O2 with them when climbing Everest (and other 20K ft. and up mountains)? -- Marc J. Zeitlin http://marc.zeitlin.home.comcast.net/ http://www.cozybuilders.org/ |
#126
![]() "Marc J. Zeitlin" wrote in message news ![]() | "C J Campbell" wrote; | | ....... At the altitudes airliners fly the partial pressure of | oxygen is too low to be absorbed by the bloodstream. You could fill | the | entire cabin with pure oxygen and everybody would still suffocate. | Those | little masks are not pressurized. | | If that were true, why would mountain climbers take little bottles of O2 | with them when climbing Everest (and other 20K ft. and up mountains)? | Airliners fly a lot higher than 20,000 feet. Those bottles are pressurized and regulated as well. Climbers who use the oxygen usually only take a breath or two when they need it. Although the masks are not very good, they are better than the passenger masks on airliners. A lot of the oxygen is still wasted, though. There are climbers who manage to make it up Everest without any supplemental oxygen at all. Granted, they have had time to acclimatize themselves, but even so it supports the idea that passengers are not going to instantly die if the airplane depressurizes. |
#127
![]() "Bob Gardner" wrote in message news:QODIb.85072$VB2.187788@attbi_s51... No way. You start off at sea level, of course, and they pump the chamber pressure down to 25000 feet with masks on...then they do some experiments with a few of the pilots taking their masks off, just to show how severely their abilities are affected. Then comes the explosive decompression, which takes the chamber from 25K back down to sea level in a second or two. SIlly question but ... Why would "they" pressurize the aircraft to sea level? Why not some compromise "pressure" like that equivalent to, say, 6,000 or 8,000 feet? EMWTK |
#128
![]() "khobar" wrote in message news:LvlJb.16967$7D3.16664@fed1read02... Ralph Nesbitt wrote in message m... I have no experience with "A/C Window Bullet Impact". Have seen "Spidering due Debris" from "uncontained engine failures. Have seen, dealt with the aftermath of encounters between fighter type A/C & large birds such as "Buzzards, Eagles, or other large carrion Feeders. I have seen some of those. They make quite a mess. The "Windshields of Southern 232", a DC-9, were broken out along with "Catastrophic Engine Damage" by hail at altitude resulting in a catastrophic incident. Many "Hail Stones of ~3" Diameter were in the cockpit when we arrived on scene within ~ 7 minuets of the incident. There were substantial "Dents/Dings" in the rear cockpit bulkhead from the "Hail Stones". You've probably seen the Easyjet pics: http://www.zap16.com/Easyjet%20out%20of%20hail.htm Paul Nixon Have seen the Easy et Pic's. Was FD/CFR/ARFF Officer in Charge/On Scene Commander at the Southern 232 incident. Ralph Nesbitt Professional FD/CFR/ARFF Type |
#129
![]() "Mike Rapoport" wrote in message hlink.net... "Ralph Nesbitt" wrote in message gy.com... "Mike Rapoport" wrote in message hlink.net... "Ralph Nesbitt" wrote in message m... Hopefully all realize when referring to "Air Pressure" at altitude this is an "absolute" pressure value inside the fuselage irrespective of ambient. When referring to air pressures at ground level the pressure reading is above unadjusted ambient barometric pressure. This is incorrect, pressurization is the differential between ambient and cabin preasure. Mike MU-2 Please reconsider your statement above as it applies to pressurization of A/C cabins at altitude. At altitude A/C cabins are like a pressure vessel. A/C cabins are pressurized to maintain ~ 12 PSI Gauge, ~ the same as normal atmospheric pressure @ 11,000' ASL, in the cabin irrespective of altitude above 11,000' ASL. Ralph Nesbitt Professional FD/CFR/ARFF Type No, the cabin is not at a constant preasure above 11,000' (and the number that you are looking for is 8,000') unless the rate controller is set to a rate greater than the climb rate of the aircraft (which is never done). If what you say were true then the cabin altitude would not climb with the airplane above 11,000' (8,000') which it clearly does. If you doubt this, go buy an altimeter watch and see for yourself. Or you could buy a pressurized airplane. OK, I'll bite. Just how does the psia in the cabin track the psia "ambient." |
#130
John Gilmer wrote:
SIlly question but ... Why would "they" pressurize the aircraft to sea level? Why not some compromise "pressure" like that equivalent to, say, 6,000 or 8,000 feet? Typically, they start at whatever the local pressure altitude happens to be (which of course may or may not be sea level, depending on where you happen to have the chamber). Also, I've never experienced in any altitude chamber ride a rapid REcompression down to sea level- it strikes me as a good way to have sinus or ear problems. Mike |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
Order your FREE Small Blue Planet Toys Christmas Catalog before Oct 20th! | Small Blue Planet Toys | Aviation Marketplace | 0 | October 15th 03 05:26 PM |
Invest small Earn Large ($20 000+) | promethean | General Aviation | 0 | October 3rd 03 06:08 AM |
Small Blue Planet Toys goes Postal !! Economy Shipping Options now availalble | Small Blue Planet Toys | Aviation Marketplace | 0 | July 11th 03 04:00 PM |
