John Gilmer wrote:
SIlly question but ... Why would "they" pressurize the aircraft to sea level? Why not some compromise "pressure" like that equivalent to, say, 6,000 or 8,000 feet? Typically, they start at whatever the local pressure altitude happens to be (which of course may or may not be sea level, depending on where you happen to have the chamber). Also, I've never experienced in any altitude chamber ride a rapid REcompression down to sea level- it strikes me as a good way to have sinus or ear problems. Mike |
Michael Williamson wrote in message ...
John Gilmer wrote: SIlly question but ... Why would "they" pressurize the aircraft to sea level? Why not some compromise "pressure" like that equivalent to, say, 6,000 or 8,000 feet? Typically, they start at whatever the local pressure altitude happens to be (which of course may or may not be sea level, depending on where you happen to have the chamber). Also, I've never experienced in any altitude chamber ride a rapid REcompression down to sea level- it strikes me as a good way to have sinus or ear problems. Mike nope. when the doors on an aircraft are shut the pressure is ambient. thats it. when bleed air pressures the cabin its noramlly to about 8000ft. |
running with scissors wrote:
Michael Williamson wrote in message ... John Gilmer wrote: SIlly question but ... Why would "they" pressurize the aircraft to sea level? Why not some compromise "pressure" like that equivalent to, say, 6,000 or 8,000 feet? Typically, they start at whatever the local pressure altitude happens to be (which of course may or may not be sea level, depending on where you happen to have the chamber). Also, I've never experienced in any altitude chamber ride a rapid REcompression down to sea level- it strikes me as a good way to have sinus or ear problems. Mike nope. when the doors on an aircraft are shut the pressure is ambient. thats it. when bleed air pressures the cabin its noramlly to about 8000ft. While the final (steady state) pressure of the aircraft (as determined by the cabin pressurization controller) will end up at its cruise setting, the aircraft is pressurized from takeoff and the cabin altitude will typically climb slowly toward its set value (about 8,000' in this case) rather than follow ambient- the pressurization system is indeed pressurizing the aircraft its initial field elevation up to the cruise pressurization setting. In addition, my above response was poorly worded and I actually was commenting on the pressurization of the altitude chamber- which begins at whatever the ambient pressure happens to be. My bad for not reading the question closely enough. Mike |
running with scissors wrote: Michael Williamson wrote in message ... John Gilmer wrote: SIlly question but ... Why would "they" pressurize the aircraft to sea level? Why not some compromise "pressure" like that equivalent to, say, 6,000 or 8,000 feet? Typically, they start at whatever the local pressure altitude happens to be (which of course may or may not be sea level, depending on where you happen to have the chamber). Also, I've never experienced in any altitude chamber ride a rapid REcompression down to sea level- it strikes me as a good way to have sinus or ear problems. Mike nope. when the doors on an aircraft are shut the pressure is ambient. thats it. when bleed air pressures the cabin its noramlly to about 8000ft. While the final (steady state) pressure of the aircraft (as determined by the cabin pressurization controller) will end up at its cruise setting, the aircraft is pressurized from takeoff and the cabin altitude will typically climb slowly toward its set value (about 8,000' in this case) rather than follow ambient- the pressurization system is indeed pressurizing the aircraft its initial field elevation up to the cruise pressurization setting. In addition, my above response was poorly worded and I actually was commenting on the pressurization of the altitude chamber- which begins at whatever the ambient pressure happens to be. My bad for not reading the question closely enough. Mike ditto, my bad for not reading closely. although you used the words cabin pressurization, you did use the word chamber too ! |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
Order your FREE Small Blue Planet Toys Christmas Catalog before Oct 20th! | Small Blue Planet Toys | Aviation Marketplace | 0 | October 15th 03 05:26 PM |
Invest small Earn Large ($20 000+) | promethean | General Aviation | 0 | October 3rd 03 06:08 AM |
Small Blue Planet Toys goes Postal !! Economy Shipping Options now availalble | Small Blue Planet Toys | Aviation Marketplace | 0 | July 11th 03 04:00 PM |
