I have flown a Seminole over the Cascades with three adult passengers, and
it was a dog. Tops were at 12000 and I was in and out, unable to climb much higher. I am not proud of my decision to go that day. Insofar as the HTML question is concerned, I'm not computer savvy enough to know what I am doing wrong. Why has this question just popped up, after the many, many times I have posted without changing any settings?? Bob Gardner "Peter Duniho" wrote in message ... "Maule Driver" wrote in message r.com... "Jay Honeck" wrote in message news:5KDJb.738451$Fm2.658693@attbi_s04... Weird. Bob's post appeared normally on my PC. Same here. No crap. That's because you are all using a newsreader that interprets HTML, which is what Bob's original post was written in. He shouldn't have used HTML (nor should anyone be posting to a newsgroup like this one using HTML), and Robert wound up suffering because he did. Most people don't, just because their newsreader is hiding poor posting practices from them. (Actually, the truth is that if you're paying attention, even in Outlook Express or other HTML-aware newsreaders, the HTML posts look different. The poor posting practice isn't so much hidden, as it is made less obvious to those not aware of the issue). As for the topic at hand, I don't know much about the Seminole, but without knowing the weights of the four people in the plane, I don't see how Bob can say that it's "not a real four passenger airplane". I'm not a small person (200 pound-ish), and I've flown a 172 with all four seats occupied with adults, and legally so at that. Seems to me it's a little premature to be making conclusions about the cause of the accident. Could easily be that the aircraft load had *nothing* to do with the crash. Pete |
"Bob Gardner" wrote in message
news:b_EJb.49247$I07.150198@attbi_s53 Insofar as the HTML question is concerned, I'm not computer savvy enough to know what I am doing wrong. Why has this question just popped up, after the many, many times I have posted without changing any settings?? Perhaps because nobody chose to mention it before. ![]() If you're interested in correcting the issue, click on Tools | Options, the click the Send tab. At the bottom of the page will be a section for "News sending format". Click the "Plain text" option and you're all set. As a point of netiquette, all news postings should be in plain text to reach the largest audience possible and to greatly reduce bandwidth requirements. HTML adds significant transmission overhead to the actual message. FWIW, Outlook Express 6 (SP1?) offers the option to display all messages as plain text regardless of sending format. I strongly encourage users to enable this option to greatly reduce the possibility of accidental viral infection. This may be set by clicking Tools | Options, then the Read tab and check the option for "Read all messages in plain text." -- John T http://tknowlogy.com/TknoFlyer http://www.pocketgear.com/products_s...veloperid=4415 ____________________ |
On 2004-01-03 11:46:15 -0800, "Bob Gardner" said:
Insofar as the HTML question is concerned, I'm not computer savvy enough to know what I am doing wrong. Why has this question just popped up, after the many, many times I have posted without changing any settings?? It's just the last couple of posts you've made that had the HTML. The posts are first plain text, then have an HTML version tacked on the end. -- Larry Fransson Seattle, WA |
Larry Fransson wrote
It's just the last couple of posts you've made that had the HTML. The posts are first plain text, then have an HTML version tacked on the end. That's the way they have appeared in "Xnews". Bob Moore |
news:b_EJb.49247$I07.150198@attbi_s53... I have flown a Seminole over the Cascades with three adult passengers, and it was a dog. Tops were at 12000 and I was in and out, unable to climb much higher. I am not proud of my decision to go that day. Still, I fail to see what relevance to the accident in question that has. All airplanes have a service ceiling, and the "trick" is to plan the flight so as to not need to climb above that. Even IFR over the Cascades, there's no need to go higher than 12000' absent bad weather conditions (icing, convection, high winds, etc.). MEAs are significantly lower than that. If there was something wrong with your decision to fly that day, it would have had something to do with the weather, or the weights of your passenger (if you flew overgross), or something along those lines. I don't see anything inherently wrong with flying an airplane at or near maximum gross weight, and certainly having all the seats full does not necessarily mean the airplane was over the max gross weight, nor would it necessarily have contributed anything to the accident in question. If by "the Seminole is not a real four passenger airplane any more than a Cessna 172 is", what you meant was "the Seminole can carry four passengers just fine, depending on their weight", then I misunderstood, and you can ignore all that I wrote. Insofar as the HTML question is concerned, I'm not computer savvy enough to know what I am doing wrong. Why has this question just popped up, after the many, many times I have posted without changing any settings?? Not sure. I haven't been paying close attention, but perhaps your newsreader is set to post in HTML, but does so only when you are posting a message that is *not* a reply, using instead the previous post's formatting (which is almost always plain text) when you are replying. In other words, when you start a thread, it winds up HTML. When you reply to a plain text message, it winds up plain text. Could that be the difference? Pete |
Homebuilt Airplane Crash | Harry O | Home Built | 1 | November 15th 04 03:40 AM |
Bizzare findings of Flight 93 crash in PA on 9-11 | Laura Bush murdered her boy friend | Military Aviation | 38 | April 12th 04 08:10 PM |
AF investigators cite pilot error in fighter crash | Otis Willie | Military Aviation | 0 | January 9th 04 09:55 PM |
Sunday's Crash in LI Sound | Marco Leon | Piloting | 0 | November 5th 03 04:34 PM |
Homemade plane crash | Big John | Home Built | 9 | October 17th 03 06:45 PM |
