On Sat, 03 Jan 2004 22:41:13 +0000, Ben Jackson wrote:
It does have a Hobbs meter. But plane costs are mostly in units of Tach time. At a towered airport you (probably?) spend more time taxiing and therefore accumulate more Hobbs time per unit Tach. I assume you mean maintenance since that's about all done with tach time, where rentals are usually based on Hobbs time, if the plane has one of those. The reason is that the rental makes more money since the Hobbs will indicate a higher number than the tach. This is a benefit when it comes to paying for your maintenance. I've almost never rented a plane based on tach time unless the Hobbs was not working right, but then most of the planes I rent have a Hobbs meter and you can see why they'd want to use it's figure. You're correct in that at towered airports you'll log more Hobbs time than tach time, but those have been the breaks for me. I know of no planes around here that use the tach for anything beyond maintenance. Out of curiosity, why are you trying to figure the ratio anyhow? It varies at each airport depending on how far from the hangar to the ramp or runway you are, how long you warm it up, etc. Based on your website, are you planning on getting back into flying, or is your site just not updated, kinda like how I do mine? |
In article . net,
Matthew P. Cummings wrote: On Sat, 03 Jan 2004 22:41:13 +0000, Ben Jackson wrote: I assume you mean maintenance since that's about all done with tach time, Scheduled maintenance (100hr inspections, possible 50hr inspections), oil changes, oil consumption, fuel consumption, engine life, airframe life, etc all scale with tach time. If you then charge by Hobbs time there's a 'slop' factor in there because Hobbs Tach. My question is: what is that factor? I was hoping someone who had been involved in renting airplanes had an estimate. For example, let's say it costs exactly $45/hr wet Tach to operate a Cessna 152. If you charge $45/hr wet Hobbs and the ratio is 1:1, you will never break even (pay your fixed costs of insurance, storage, and interest on the loan above and beyond hourly expenses). However if the ratio is .85 Tach hours per Hobbs hour, then you will get about $8/hr towards your fixed expenses. In that case you might break even around 600 hours, assuming about $5000/yr fixed expenses. Since the margins are small, the factor makes a big difference. Based on your website, are you planning on getting back into flying, or is your site just not updated, kinda like how I do mine? Oh, I just never update my website. I bought a 1965 Comanche 260 last August and I'm about 2/3rds of the way to my instrument rating (checkride on Feb 7 if the weather lets up enough to get the rest of my hours). -- Ben Jackson http://www.ben.com/ |
![]() Ben Jackson wrote: If you then charge by Hobbs time there's a 'slop' factor in there because Hobbs Tach. My question is: what is that factor? I was hoping someone who had been involved in renting airplanes had an estimate. The FBO at the uncontrolled field at which I got my PPC used to use a factor of 1.2 times the tach in a Cessna 150. The aircraft had Hobbs meters, and we usually paid according to the Hobbs, but sometimes one of the meters went TU. George Patterson Great discoveries are not announced with "Eureka!". What's usually said is "Hummmmm... That's interesting...." |
On Sun, 04 Jan 2004 00:22:11 +0000, Ben Jackson wrote:
For example, let's say it costs exactly $45/hr wet Tach to operate a Cessna 152. If you charge $45/hr wet Hobbs and the ratio is 1:1, you will never break even (pay your fixed costs of insurance, storage, and interest on the loan above and beyond hourly expenses). However if the ratio is .85 Tach hours per Hobbs hour, then you will get about $8/hr Others have said this and it's true, it varies depending on your location and can only be determined accurately for your situation. However, in my plane the difference is more like .1 per hour since my hangar is not that far from the runway and I don't spend time screwing around. In other words I'm not like a Bonanza guy I saw recently who spent 30 minutes warming up his engine prior to flight, I'll not comment beyond saying his ratio is going to be much larger than mine as will his operating expenses. Looking at the logs prior to my getting the plane, and it used to be based at a big airport the time difference was closer to .4 difference. He must have either spent a long time in line or had a long taxi. But, you're going about it the wrong way. If you have a hobbs meter you charge hobbs time and don't worry about the fact it will not be quite accurate because you'll make more money on it. Don't feel like you're cheating the renter, he can log the time the hobbs says as long as he intends to fly the plane. You couldn't log it for example if you just spent an hour driving around the ramp... What you do is first figure out what it costs to fly based on tach time, figure what it'll take to make enough money to keep it going, and then charge based on Hobbs. The hobbs will of course show more time than the tach unless you've got a dishonest renter. If you insist on making exactly $? per hour on your rental then you will need to figure the hobbs/tach ratio for YOUR usage. If you want to guess, use .2 as it's close enough as .8 tach is pretty close to 1.0 hobbs at many airports. I give you the above based on my usage of a plane as a renter, and as an owner. I know what my plane does now, and I know what it did before I got it, thanks to good logs. What is the ratio in your plane? I forgot to add one more thing, the Hobbs ratio can change in the Winter due to cold and the mechanical nature of the meter. In a Cessna it's a very cheap clock mechanism that gums up a bit over time and slows down during cold weather due to that fact. I've been asked to log tach time for paying for flights in the Winter. |
Tachometer or Tach Cable | Rich | Owning | 14 | October 14th 04 02:54 AM |
Tach Vs. Hobbs Time | John Roncallo | Owning | 33 | January 7th 04 12:42 AM |
