******Doesn't it have a float on a wire? Not the same******
Exactly the same.You really should go have a look. No wire. Just a sight gauge with a red colored cork floating. I spent my pilot youth ferrying these fine airplanes from Lock Haven to Washington. Oregon, Alaska. The float on a wire is on a J3, Taylorcraft, Aeronca, usually on a forward fuselage tank. Super Cub tanks are in the wings. Karl |
![]() Ok. I give up. How did it fail? The cork stick to the tube or what kept the gas from draining through the bottom of the guage? In article , "karl" wrote: ******Doesn't it have a float on a wire? Not the same****** Exactly the same.You really should go have a look. No wire. Just a sight gauge with a red colored cork floating. I spent my pilot youth ferrying these fine airplanes from Lock Haven to Washington. Oregon, Alaska. The float on a wire is on a J3, Taylorcraft, Aeronca, usually on a forward fuselage tank. Super Cub tanks are in the wings. Karl |
Is taking off on single mag bad for engine | flyer | Home Built | 10 | September 21st 03 09:43 PM |
WANTED: partnership, rental or club with fast single or light twin in San Diego | Jim McGarvie | Aviation Marketplace | 0 | September 13th 03 03:55 PM |
