On Tue, 6 Jan 2004 22:48:11 -0800, "R. Hubbell"
wrote in Message-Id: : On Wed, 07 Jan 2004 05:13:14 GMT Larry Dighera wrote: On Tue, 6 Jan 2004 20:18:54 -0800, "R. Hubbell" wrote in Message-Id: pMLKb.102181$pY.83466@fed1read04: http://ntsb.gov/ntsb/brief.asp?ev_id=20031231X02110 That link only produced an error message, but this one seems to be functional: http://www.ntsb.gov/ntsb/brief.asp?ev_id=20031231X02110 This midair collision of two Long Beach Flying Club & Flight Academy aircraft appears to be the same operation (but obviously different flight instructor) as the AVX failure to climb on the missed approach accident you mention above: http://www.ntsb.gov/ntsb/brief.asp?e...28X00524&key=1 http://www.ntsb.gov/ntsb/brief.asp?e...28X00524&key=2 Well the planes are all from the Flying Club. I remember the midair, very sad as well. It was not only sad, but it points out the flaw in the FAA's airspace strategy. When the majority of aircraft are forced to remain outside the majority of available airspace (for lack of a Class B clearance, etc), they are crowded into the resulting congested bits of airspace remaining where it is significantly more likely that a MAC may occur. As the size of the Class B keeps increasing over time, I would expect MACs to increase also. Strange that the occupants of the 172 were not recovered until 73 days later. Yes. It would be interesting to hear the explanation for that. With regard to the AVX mishap, given the radar information disclosed in the NTSB preliminary report, it's pretty evident that the instructor failed to assure that the student complied with climb associated with the Missed Approach Procedure if indeed the student was controlling the aircraft at the time. While most instrument approaches in the Los Angeles area are flown with ATC monitoring the flight on radar, as I recall, radar coverage isn't available for the VOR/NDB-B approach to AVX, so the instructor may not have realized it was _solely_ his responsibility and duty to assure the safety of the flight. With AVX UNICOM reporting "ceiling 100 feet overcast; and visibility 1.25 statute miles" and the charted MDA of about 1,000' above the runway elevation, the instructor should have known immediately that he would be executing the Missed Approach Procedure, and had time to review it while the student flew the descent. But after the fact analysis fails to include the unknowable actual circumstances of the flight (who was at the controls, the mechanical state of the equipment, ...), so it is necessarily flawed. However, there is no mistake that 9 fatalities and loss of three aircraft within 3 years by the same flying club is truly tragic. It would be interesting to read firsthand reports of pilots familiar with the decorum and professionalism within the Long Beach Flying Club & Flight Academy: http://ourworld.compuserve.com/homepages/lbflyingclub/ As a Part 141 flying school, their prices are about the lowest I've seen: http://ourworld.compuserve.com/homep...ub/source4.htm The only other interesting information I could find on their web site was contained in their monthly bulletin: http://ourworld.compuserve.com/homep...b/bulletin.htm [newsgroup rec.aviation.ifr added] |
On Wed, 07 Jan 2004 15:18:23 GMT Larry Dighera wrote:
On Tue, 6 Jan 2004 22:48:11 -0800, "R. Hubbell" wrote in Message-Id: : On Wed, 07 Jan 2004 05:13:14 GMT Larry Dighera wrote: On Tue, 6 Jan 2004 20:18:54 -0800, "R. Hubbell" wrote in Message-Id: pMLKb.102181$pY.83466@fed1read04: http://ntsb.gov/ntsb/brief.asp?ev_id=20031231X02110 That link only produced an error message, but this one seems to be functional: http://www.ntsb.gov/ntsb/brief.asp?ev_id=20031231X02110 This midair collision of two Long Beach Flying Club & Flight Academy aircraft appears to be the same operation (but obviously different flight instructor) as the AVX failure to climb on the missed approach accident you mention above: http://www.ntsb.gov/ntsb/brief.asp?e...28X00524&key=1 http://www.ntsb.gov/ntsb/brief.asp?e...28X00524&key=2 Well the planes are all from the Flying Club. I remember the midair, very sad as well. It was not only sad, but it points out the flaw in the FAA's airspace strategy. When the majority of aircraft are forced to remain outside the majority of available airspace (for lack of a Class B clearance, etc), they are crowded into the resulting congested bits of airspace remaining where it is significantly more likely that a MAC may occur. As the size of the Class B keeps increasing over time, I would expect MACs to increase also. Hopefully the problem can be solved with technology. Maybe more accurate xponders or the like. The class bravo is pretty messy and getting dangerous. I wonder if someday all traffic will be under ATC control in that airspace. Strange that the occupants of the 172 were not recovered until 73 days later. Yes. It would be interesting to hear the explanation for that. Maybe weather and money?? If they were famous of course no problem. With regard to the AVX mishap, given the radar information disclosed in the NTSB preliminary report, it's pretty evident that the instructor failed to assure that the student complied with climb associated with the Missed Approach Procedure if indeed the student was controlling the aircraft at the time. While most instrument approaches in the Los Angeles area are flown with ATC monitoring the flight on radar, as I recall, radar coverage isn't available for the VOR/NDB-B approach to AVX, so the instructor may not have realized it was _solely_ his responsibility and duty to assure the safety of the flight. But it always is the instructor that's in charge and responsible. I suppose it's still possible that he didn't realize it at the time. R. Hubbell With AVX UNICOM reporting "ceiling 100 feet overcast; and visibility 1.25 statute miles" and the charted MDA of about 1,000' above the runway elevation, the instructor should have known immediately that he would be executing the Missed Approach Procedure, and had time to review it while the student flew the descent. But after the fact analysis fails to include the unknowable actual circumstances of the flight (who was at the controls, the mechanical state of the equipment, ...), so it is necessarily flawed. However, there is no mistake that 9 fatalities and loss of three aircraft within 3 years by the same flying club is truly tragic. It would be interesting to read firsthand reports of pilots familiar with the decorum and professionalism within the Long Beach Flying Club & Flight Academy: http://ourworld.compuserve.com/homepages/lbflyingclub/ As a Part 141 flying school, their prices are about the lowest I've seen: http://ourworld.compuserve.com/homep...ub/source4.htm The only other interesting information I could find on their web site was contained in their monthly bulletin: http://ourworld.compuserve.com/homep...b/bulletin.htm [newsgroup rec.aviation.ifr added] |
Seneca V vs. Navajo operating costs | Jarema | Owning | 1 | February 12th 05 10:30 PM |
Insuring a C310 vs. Piper Seneca | Dave | Owning | 17 | October 27th 04 03:29 PM |
Want to purchase PA34-200 Seneca | Grasshopper | General Aviation | 11 | July 7th 04 05:09 PM |
Seneca down at Avalon | Larry Dighera | Instrument Flight Rules | 2 | January 8th 04 02:10 PM |
I am going to do it again! A Piper Seneca? | Michelle P | Owning | 5 | August 20th 03 01:59 AM |
