So, just how would the emergency exits get opened when the aircraft is on
the ground and needs to be evacuated, if the cabin pressure is significantly higher than the outside pressure? I'm guessing that the pressure differential at ground level isn't enough to prevent the exits from opening, but that this differential is (logically) much higher at altitude, and thus would prevent the exits from opening in flight. But I could be wrong. And yes, sadly the whole newsgroup thing is a never-ending disappointment. The most humorous recent example came from the "gun loons" thread, where I suspect that 5 or 6 people are STILL arguing about the difference between a "box cutter" and a "carpet knife". |
![]() "Geoffrey Barnes" wrote in message link.net... I'm guessing that the pressure differential at ground level isn't enough to prevent the exits from opening, but that this differential is (logically) much higher at altitude, and thus would prevent the exits from opening in flight. But I could be wrong. The pressure differential wouldn't have to be that great to create a considerable force holding the exit in place. I don't know what the surface area of an exit is, but a square twenty inches on a side has an area of 400 square inches. It would take 200 pounds of force to overcome a 1/2 psi pressure differential. |
So, just how would the emergency exits get opened when the aircraft is on the ground and needs to be evacuated, if the cabin pressure is significantly higher than the outside pressure? I'm sure that every aircraft has some differences, but the Boeing B-707 and B-727 that I flew worked as follows: It is desireable to have "some" pressurization differential at takeoff for passenger comfort. This prevents the outflow valves from slamming shut at liftoff with the engines at takeoff thrust causing a discomforting pressure "bump". For obvious reasons, it is also desireable to have the cabin de-pressurize after landing. To accomplish these two goals, the pressurization controller has a switch labeled "takeoff" and "landing". Normally left in the "landing" position, the outflow valves are electrically driven open. Just before takeoff, the switch is placed in the "takeoff" position and the automatic features of the controller closes the valves somewhat to cause no more than a .125 psi differential. This pressure limit is an FAA aircraft certification limit and is sometimes stated as "no more than 250 ft below field elevation". The reason for the limit is obvious....to permit an emergency evacuation. Sometime during flight, the controller switch is placed in the landing mode and upon touchdown, the "squat switch" on the landing gear signals the controller to open the outflow valves. At a maximum of .125 psi differential, the air load on an average emergency exit would be less than 100 lbs. Bob Moore ATP B-707 B-727 PanAm (retired) |
Robert Moore wrote in message .6...
Just before takeoff, the switch is placed in the "takeoff" position and the automatic features of the controller closes the valves somewhat to cause no more than a .125 psi differential. This pressure limit is an FAA aircraft certification limit and is sometimes stated as "no more than 250 ft below field elevation". The Thanks for the excellent explanation, Bob. Back when I had the misfortune of having to fly commercially, I used to notice that my altimeter watch would drop about 200 ft. as we taxied away from the gate. I always wondered how that would impact getting the door open in case of emergency. John Galban=====N4BQ (PA28-180) |
GNS 480 means no GNS 430 upgrade ? | Scott Moore | Instrument Flight Rules | 17 | September 4th 04 04:05 AM |
"Comrade's casualty abroad means grim duty at home" | Mike | Military Aviation | 0 | June 1st 04 09:21 PM |
Did the Germans have the Norden bombsight? | Cub Driver | Military Aviation | 106 | May 12th 04 07:18 AM |
Air Vice Marshal Tony Dudgeon | Keith Willshaw | Military Aviation | 0 | January 9th 04 12:43 PM |
"Stand Alone" Boxes (Garmin 430) - Sole means of navigation - legal? | Richard | Instrument Flight Rules | 20 | September 30th 03 02:13 PM |
