I've heard of guys making bowls and spinners by rolling metal into a
form that's turning on a lathe. I gather they use some kind of roller against the metel to force it in as the lathe turns, but beyond that I don't understand the process. I don't, for instance, understand how the metal is held in place while being forced into the mold. The mold, if I'm recalling correctly, was simply a wood block with the proper depression cut into it. Perhaps I should ask "Tinman". Corky Scott |
![]() Date: 4/15/2004 9:57 AM Central Daylight Time I've heard of guys making bowls and spinners by rolling metal into a form that's turning on a lathe. I gather they use some kind of roller against the metel to force it in as the lathe turns, but beyond that I don't understand the process. I don't, for instance, understand how the metal is held in place while being forced into the mold. The mold, if I'm recalling correctly, was simply a wood block with the proper depression cut into it. Perhaps I should ask "Tinman". Corky Scott There's a guy who sells a book about that on e-bay. I have bought some of his books and he seems quite handy. Dan, U.S. Air Force, retired |
It is called spinning and is really not too hard to do on annealed materials. You do of course have to have a pretty
large throw available on the lathe... -- Dan D. .. wrote in message ... I've heard of guys making bowls and spinners by rolling metal into a form that's turning on a lathe. I gather they use some kind of roller against the metel to force it in as the lathe turns, but beyond that I don't understand the process. I don't, for instance, understand how the metal is held in place while being forced into the mold. The mold, if I'm recalling correctly, was simply a wood block with the proper depression cut into it. Perhaps I should ask "Tinman". Corky Scott |
Guys,
Here's all you need to know about making spinners http://prl.stanford.edu/documents/pdf/spinning.pdf , now just do it. Stan Kapushinski "Blueskies" wrote in message . .. It is called spinning and is really not too hard to do on annealed materials. You do of course have to have a pretty large throw available on the lathe... -- Dan D. . wrote in message ... I've heard of guys making bowls and spinners by rolling metal into a form that's turning on a lathe. I gather they use some kind of roller against the metel to force it in as the lathe turns, but beyond that I don't understand the process. I don't, for instance, understand how the metal is held in place while being forced into the mold. The mold, if I'm recalling correctly, was simply a wood block with the proper depression cut into it. Perhaps I should ask "Tinman". Corky Scott |
spinner fab | Dick | Home Built | 2 | April 14th 04 12:21 AM |
