How long before the card comes?
Old January 9th 04, 08:45 PM
Skyking
"MRQB" wrote in message ...
Seems like they are stuck on october 25th
It looks like they just got off of it.
We are currently processing permanent Airmen Certificates with an
approximate issue date of October 31st, 2003 .
Good luck,
Skyking
  #34
Old January 11th 04, 08:27 PM
My name
"ross watson" wrote in
Mine came just before the temp certificate expired so they apparently
like to press the envelope a little.
92 Days for my latest (Added IFR).
  #35
Old January 14th 04, 12:49 AM
seanoj
Takes two weeks longer than your patience. Call them and they will
tell you what "issue" date they are processing. That will give you an
idea how long it will be. They say they are doing 31st OCT 2003 now
Took me almost 90 days. Your temporary is good for 120.
From the FAA FAQ
Normally, it takes FAA about six to eight weeks to process and send a
permanent license(certificate). You can check on-line at
http://registry.faa.gov/airmen.asp to see which dates we are currently
processing. If we are currently processing certificates we issued
later than yours, submit an inquiry through
http://registry.faa.gov/amfeed.asp. You can also call the FAA's Airmen
Registry at 405-954-3261.
For further question about this topic please contact the Civil
Aviation Registry by email at
  #36
Old January 14th 04, 04:47 PM
MRQB
I know the DE gave me copies of all my info i asked him what for he said
incase something gets lost! Said if you don't receive it in 105 days call
him and he will reissue me a temp and see whats taking so long.
"BTIZ" wrote in message
news:xiYIb.45016$m83.27338@fed1read01...
you mean the DE did not give you a copy of all the paperwork?
And you did not keep a pencil copy of the 8710 you filed out?
That DE should give you your money back..
BT
"James M. Knox" wrote in message
"MRQB" wrote in
Your log book should have your check ride date and examiners signature
It does. And I still have the original (well, the copy they give to the
applicant) temporary certificate. But it's not that the FAA doesn't
believe me (well, actually, they don't - or at least they don't care).
They require a full data package, including application for certificate,
original (from the DE) of the temporary, original of the knowledge test,
etc.
None of that exists anymore, of course.
Current plan is for me to reconstitute the 8710 form for back when I
took the checkride, try to get a new "original" of the knowledge test
certificate (which has expired), and the other paperwork. Take that to
my my CFI and get him to sign another copy. Then fly over to east Texas
(about 250 nm each way) to get the DE to sign everything. Then if I am
lucky we can mail it all back to OKC.
No, I'm not worried about it all --- YET! But a friend assures me they
know someone this happened to, and she had to take her checkride over
again.
Guess I'll wait a few days before I start practicing those Chandelles
again. Sigh...
BTW, the FSDO suggestion. Turns out my local (75 miles away) FSDO
isn't involved. It's the one 200 miles away that is involved. And they
aren't even taking requests for scheduling visits (no walk-ins, period)
until the alert level goes back down.
James M. Knox
TriSoft ph 512-385-0316
1109-A Shady Lane fax 512-366-4331
Austin, Tx 78721
SWRFI Pirep.. (long) Dave S Home Built 20 May 21st 04 03:02 PM
How long dose it take to get the registration card? MRQB Owning 8 April 2nd 04 02:05 AM
IFR Long X/C and the Specter of Expectations David B. Cole Instrument Flight Rules 0 February 24th 04 07:51 PM
Long Range Spitfires??? ArtKramr Military Aviation 3 September 9th 03 10:05 PM
How I got to Oshkosh (long) Doug Owning 2 August 18th 03 12:05 AM
