Barry Klein wrote:
How should we have found the correct mixture setting for power-off final approach, when the turbo is basically adding no boost and we are at high density altitude? Did you enrichen the mixture between cruise and landing? There should have been no reason to. As you reduce altitude and MP, the mixture will enrichen with decrease in altitude. Had you need to do a go around, the cruise mixture would have been sufficient for a full power go-around. |
Are you sure about this? I always have to enrichen the mixture as I decrease
altitude. Michael "john smith" wrote in message ... Barry Klein wrote: How should we have found the correct mixture setting for power-off final approach, when the turbo is basically adding no boost and we are at high density altitude? Did you enrichen the mixture between cruise and landing? There should have been no reason to. As you reduce altitude and MP, the mixture will enrichen with decrease in altitude. Had you need to do a go around, the cruise mixture would have been sufficient for a full power go-around. |
Michael,
What do you experience that causes you to have to enrichen your mixture as you descend on your airplane? Are you descending while carrying a very high power setting? I'm asking because I've flown T182s and TR182s and have never run into a situation that required enrichening the mixture during descent unless I leveled off at some intermediate altitude and went to a relatively high power setting. Otherwise, the only reason to enrichen the mixture during descent is if the engine actually begins to run roughly. (See the POH which only recommends enrichening if you experience engine roughness.) Most people descend at 65% power or less, which means that it is impossible to detonate the engine due to lack of heat and pressure, so it's impossible to run it too lean (it will simply start to run rough and then quit if you get it too lean, you won't hurt anything). Keeping it leaned during descent helps avoid overcooling (if you believe in shock cooling), helps keep the plugs from fouling and doesn't waste fuel. In general, once you lean the engine for cruise on a T182 you needn't touch the mixture control until you pull it to idle cutoff after landing, or to go to full rich on a go around. All the best, Rick "Michael 182" wrote in message news:KXjMb.26563$5V2.40699@attbi_s53... Are you sure about this? I always have to enrichen the mixture as I decrease altitude. Michael "john smith" wrote in message ... Barry Klein wrote: How should we have found the correct mixture setting for power-off final approach, when the turbo is basically adding no boost and we are at high density altitude? Did you enrichen the mixture between cruise and landing? There should have been no reason to. As you reduce altitude and MP, the mixture will enrichen with decrease in altitude. Had you need to do a go around, the cruise mixture would have been sufficient for a full power go-around. |
Rick Durden wrote:
Otherwise, the only reason to enrichen the mixture during descent is if the engine actually begins to run roughly. (See the POH which only recommends enrichening if you experience engine roughness.) Most people descend at 65% power or less, which means that it is impossible to detonate the engine due to lack of heat and pressure, so it's impossible to run it too lean (it will simply start to run rough and then quit if you get it too lean, you won't hurt anything). Keeping it leaned during descent helps avoid overcooling (if you believe in shock cooling), helps keep the plugs from fouling and doesn't waste fuel. In general, once you lean the engine for cruise on a T182 you needn't touch the mixture control until you pull it to idle cutoff after landing, or to go to full rich on a go around. All the best, Rick The POH for my TB-21 (turbocharged Trinidad) with a Lycoming TIO-540 calls for putting the mixture full rich prior to landing. Is that different from what most people do with this engine? -- David Rind |
"David Rind" wrote in message
... The POH for my TB-21 (turbocharged Trinidad) with a Lycoming TIO-540 calls for putting the mixture full rich prior to landing. Is that different from what most people do with this engine? What actual model engine does the TB-21 have? Just knowing that it's a TIO-540 doesn't give us enough information to compare with our own engines. The engine in my plane, a TIO-540-AA1AD, cannot stay running at full rich at idle at high density altitudes, as I mentioned in another post. I put the mixture to full rich before landing only when landing below 3000' or so (and then only so that I am more prepared for a go-around...operationally, I wind up leaning again after leaving the runway so that the plugs don't foul). Pete |
David,
I believe your POH does call for full rich prior to landing (but not in the descent) in preparation for a possible go around. Otherwise, there is no reason to enrichen it. At very high altitude airports, landing with full rich mixture may cause a rough idle or the engine may actually quit at the end of rollout, but that depends on the idle mixture adjustment on your engine. If your engine runs fine at full rich at low power settings on the ground, then there is no problem with going to full rich on final in preparation for a go around. However, you may want to lean it while taxiing (lean it a long ways so that it will simply quit should you try to take off prior to going to full rich and it will remind you) so as to help avoid plug fouling. All the best, Rick David Rind wrote in message ... Rick Durden wrote: Otherwise, the only reason to enrichen the mixture during descent is if the engine actually begins to run roughly. (See the POH which only recommends enrichening if you experience engine roughness.) Most people descend at 65% power or less, which means that it is impossible to detonate the engine due to lack of heat and pressure, so it's impossible to run it too lean (it will simply start to run rough and then quit if you get it too lean, you won't hurt anything). Keeping it leaned during descent helps avoid overcooling (if you believe in shock cooling), helps keep the plugs from fouling and doesn't waste fuel. In general, once you lean the engine for cruise on a T182 you needn't touch the mixture control until you pull it to idle cutoff after landing, or to go to full rich on a go around. All the best, Rick The POH for my TB-21 (turbocharged Trinidad) with a Lycoming TIO-540 calls for putting the mixture full rich prior to landing. Is that different from what most people do with this engine? |
Rick Durden wrote:
David, I believe your POH does call for full rich prior to landing (but not in the descent) in preparation for a possible go around. Otherwise, there is no reason to enrichen it. At very high altitude airports, landing with full rich mixture may cause a rough idle or the engine may actually quit at the end of rollout, but that depends on the idle mixture adjustment on your engine. If your engine runs fine at full rich at low power settings on the ground, then there is no problem with going to full rich on final in preparation for a go around. However, you may want to lean it while taxiing (lean it a long ways so that it will simply quit should you try to take off prior to going to full rich and it will remind you) so as to help avoid plug fouling. All the best, Rick Thanks! So then if I think I'm capable of remembering to push in the mixture on a go around there is really no need to enrich the mixture prior to landing. FWIW, I'm good about aggressively leaning once I'm off the runway. -- David Rind |
I'll check my POH - I tend to enrichen somewhat by the fuel flow on the
Shadin - maybe this is a bad habit. I'm sure I'm not over 65% on the descent. Michael "Rick Durden" wrote in message m... Michael, What do you experience that causes you to have to enrichen your mixture as you descend on your airplane? Are you descending while carrying a very high power setting? I'm asking because I've flown T182s and TR182s and have never run into a situation that required enrichening the mixture during descent unless I leveled off at some intermediate altitude and went to a relatively high power setting. Otherwise, the only reason to enrichen the mixture during descent is if the engine actually begins to run roughly. (See the POH which only recommends enrichening if you experience engine roughness.) |
... [...] Had you need to do a go around, the cruise mixture would have been sufficient for a full power go-around. You do understand that he's talking about a turbocharged engine, right? Generally speaking, full rich is the correct mixture setting for a turbocharged piston engine, for full-power takeoffs regardless of altitude. Pete |
GPS approach question | Matt Whiting | Instrument Flight Rules | 30 | August 29th 08 03:54 AM |
VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 05:03 AM |
Canadian holding procedures | Derrick Early | Instrument Flight Rules | 24 | July 22nd 04 04:03 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
IR checkride story! | Guy Elden Jr. | Instrument Flight Rules | 16 | August 1st 03 09:03 PM |
