Turbo 182: correct mixture for final approach at high altitude?
Old January 12th 04, 06:26 AM
Yes. The mixture was too rich.
This is a common problem with big-bore engines when operated
above 3000 MSL.
What we teach at Colorado Pilots Association is to set the
mixture to 15 GPH as you enter the pattern at (near) cruise
power. That way the engine continues to run on the ground. :-)
Of course, if you do a balked landing, you MUST push the mixture
full in after you increase the power for the go around.
Barry Klein wrote:
We took a newer 182 turbo to a 7000' elevation airport yesterday and
the engine quit at the end of the landing roll. I'm sure the mixture
was way too rich. It restarted without incident, glad we were on the
ground! We had the mixture set about 100 deg rich of peak TIT for
cruise at 9500. How should we have found the correct mixture setting
for power-off final approach, when the turbo is basically adding no
boost and we are at high density altitude? This is not addressed in
the POH. It does say full rich on takoff regardless of airport
elevation. Later that day, when taxiing for takoff, we set 1200 rpm
and leaned for peak rpm, mixture knob was out 1.5-2 inches to achieve
this.
When we returned home to 800' elevation, we checked the idle speed at
full rich, it was about 500 rpm, is this too low?
Thanks,
Barry
Best regards,
Jer/ "Flight instruction and mountain flying are my vocation!" Eberhard
Jer/ (Slash) Eberhard, Mountain Flying Aviation, LTD, Ft Collins, CO
CELL 970 231-6325 EMAIL jer'at'frii.com WEB http://www.frii.net/~jer
C-206 N9513G, CFII Airplane&Glider, FAA-DEN Aviation Safety Counselor
CAP-CO Mission&Aircraft CheckPilot, BM218 HAM N0FZD, 197 Young Eagles!
Old January 12th 04, 07:16 PM
Jeff
maybe a stupid question, but if its going to quit on you when you go full
rich on landing, then dont it also risk the chance of quitting if you go
full rich on a go around?
unless its just the high power that keeps it running and idle is what
kills it.
above 3000 MSL.
this.
Thanks,
Barry
Best regards,
Old January 12th 04, 11:17 PM
EDR
In article , Jeff
kills it.
Go around on approach (depending on height AGL), you will still have
some air under you and it is amazing how fast your hand will push that
mixture lever forward.
Old January 13th 04, 02:19 AM
kills it.
Your guesstimation is correct! The higher power can deal with the
enrichened mixture, and your balked landing (go around) will succeed.
Notice that I said below to increase the power, then the mixtu
Best regards,
Jer/
above 3000 MSL.
the POH. It does say full rich on takeoff regardless of airport
elevation. Later that day, when taxiing for takeoff, we set 1200 rpm
this.
Thanks,
Barry
Best regards,
Old January 13th 04, 09:16 AM
Jeff
you would think that since its a turbo airplane, cessna would expect it to be
used at high altitude airports so they would have made it so it would not cut
out on landing.
kills it.
Best regards,
Jer/
above 3000 MSL.
this.
Thanks,
Barry
Best regards,
Old January 14th 04, 07:25 AM
Peter Duniho
"Jeff" wrote in message
be
cut
out on landing.
And yet, this is a common enough issue, with many different makes and models
of turbocharged aircraft.
Why single Cessna out? There's all sorts of inconveniences related to the
technologies used in "modern" aircraft. One of them happens to be the
likelihood of engine stoppage if the mixture is set to full-rich at high
density altitudes. This isn't unique to Cessna, and it seems to me it's
along the lines of "Doc, it hurts when I do this..." joke. Since it "hurts"
when one does that, one just doesn't do that.
Simple enough, IMHO. The main problem is that, for some reason, pilots who
are introduced to turbocharged aircraft are often not told about the need to
avoid full-rich mixture settings at high density altitudes. This was true
of me (I found out myself the hard way...only took two high altitude
landings for me to figure it out though ), and it's apparently true of
other pilots as well.
Pete
Old January 14th 04, 01:22 PM
EDR
In article , Peter Duniho
The real problem is, most pilots are flat-landers.
There just is not the opportunity to train pilots in the real world
environment until they actually get there.
Old January 15th 04, 03:25 AM
Peter Duniho
"EDR" wrote in message
One need not witness the engine stopping to learn to not land with the
mixture full rich at high density altitudes. If I had been taught, when I
got checked out in my first turbocharged airplane, to not land with mixture
full rich at high density altitudes, I'm sure it would have only taken ONE
engine stoppage for me to figure out what was wrong. I might have avoided
it altogether.
My point is that it doesn't sound like anyone is even bothering to mention
this. It's not just a matter of poor retention due to lack of first-hand
experience.
Pete
Old January 14th 04, 07:03 PM
John Galban
"Peter Duniho" wrote in message ...
This is not isolated to pilots of turbocharged aircraft. Every
summer I see flatland pilots in the high country blindly following a
"mixture - rich" item on a landing checklist and killing the engine on
rollout. A go-around attempt will usually result in a belch of black
smoke and a close encounter with pine trees if they're lucky, bent
metal if they're not.
Old January 14th 04, 08:03 PM
Jeff
I am glad this isnt an issue with the turbo arrows.
Pete
GPS approach question Matt Whiting Instrument Flight Rules 30 August 29th 08 03:54 AM
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 05:03 AM
Canadian holding procedures Derrick Early Instrument Flight Rules 24 July 22nd 04 04:03 PM
IR checkride story! Guy Elden Jr. Instrument Flight Rules 16 August 1st 03 09:03 PM
