On Mon, 12 Jan 2004 23:37:03 -0800 "C J Campbell" wrote:
"R.Hubbell" wrote in message ... | On Sun, 11 Jan 2004 21:13:28 -0800 "C J Campbell" wrote: | | Now, that was cool! | | Mythbusters pressurized an old DC-9 and fired a bullet through the wall to | see if it would cause an explosive decompression. It didn't. Then they fired | a bullet through the window to see if the window would shatter and cause an | explosive decompression. The bullet only made a small hole in the window | because the windows are made of shatter-proof plastic. No explosive | decompression. | | I don't watch much TV but I admit I would have liked to have seen this. | | Can you provide more detail on how they setup the test? They took a derelict DC-9 at an aircraft graveyard and plugged up the holes. They had real trouble with the cockpit because the windows had been removed. They tried to replace the windows with plywood cemented in with foam, but the plywood proved to not be strong enough to allow pressurization of the aircraft. It kept blowing out, sometimes spectacularly. The pistol was mounted on a stand in the cabin and fired by remote control using a servor cannibalized from a vending machine, of all things. The handgun was a 9 mm automatic; it looked like a Glock. The aircraft was pressurized using one of those giant ground starter units designed for 747s, a huffer. They dumped huge sacks full of packing peanuts, scattering them around the cabin to so that the airflow inside the cabin would be visible. The bullet holes disturbed the airflow so little that even the packing peanuts stayed where they were. | | What was the cabin pressure? What was the pressure external to the | DC-9? Did they have a huge pressure chamber? They calculated the pressure differential at 35,000 feet to be 8 lbs psi, so they pressurized the interior to 8 lbs psi. As mentioned, they had trouble doing this. The plywood in the cockpit could only stand about 6 lbs psi. At one point the plywood blew out and ejected a cushion from the pilot seat more than 125 yards. They finally ended up reinforcing it enough to withstand the 8 lbs psi differential. I guess the lesson there is that if you ever lose a cockpit window you can forget about restoring cabin pressure by plugging it up with plywood. | | What about the temperature differentials? There's also a pressure | differential from the flow of air over the fuselage. Correct? | How did they simulate that? The 8 lbs psi differential comes pretty close to the pressure differential for an aircraft pressurized to 6,500 feet flying at 35,000 feet. After all, the total weight of the entire atmosphere is only 15 lbs psi. If anything, they erred on the side of increased pressure differential. A pound of air psi is a pound of air psi, no matter what the source. One thing I found interesting which they did not talk about was watching the skin of the airplane inflate and become taught as the airplane was pressurized. That brings up another question (don't have to answer, just food for thought) How many pressurization cycles did the DC-9 experience over its lifespan? Once they managed to induce an explosive decompression using the shaped charge, the damage was incredible. The whole top of the fuselage was ripped off and big chunks of the wall where the explosion was were missing. It looked like those photos of the Hawaiian Airlines incident, only much worse. I think it might have been possible to continue to fly the aircraft, but it would have been very difficult, depending on how much damage the debris did to wings, tail, engines and control surfaces. Of course, to do that kind of damage a terrorist would have to somehow get a shaped charge the size of a basketball onto the airplane, place it properly up against the wall of the fuselage, and detonate it, all without being noticed. In any event, a bullet will not do that kind of damage, unless the bullet is some kind of anti-tank artillery round. It was obvious that any handgun bullet is too small by several orders of magnitude to do any significant damage. You could have pressurized that plane for space flight and the result would have been the same. Well, no it wouldn't. That much pressure would have started popping windows or something long before they would have had a chance to fire their gun or set off their explosives. But a bullet hole would not have made a measurable difference even then. They did a reasonable job of recreating the environment but we all know how hostile things are at 35,000 and 600 mph and -35 degrees, where air is less dense. So the question is would any of us be willing to head up to 35,000, crank her up to mach .76 and get out the Glock and let loose a few rounds?? Also suppose the bullet hits some wiring or hydraulics or fuel line, etc. Not me. ![]() R. Hubbell |
"R.Hubbell" writes:
So the question is would any of us be willing to head up to 35,000, crank her up to mach .76 and get out the Glock and let loose a few rounds?? Also suppose the bullet hits some wiring or hydraulics or fuel line, etc. Not me. ![]() I woudln't do it in a *car* either, though. It comes under the heading of "negligible risk, *zero* gain" -- so why risk it? Shooting through the wall between windows pretty much guarantees I won't hit hydraulics, fuel line, etc. -- David Dyer-Bennet, , http://www.dd-b.net/dd-b/ RKBA: http://noguns-nomoney.com http://www.dd-b.net/carry/ Photos: dd-b.lighthunters.net Snapshots: www.dd-b.net/dd-b/SnapshotAlbum/ Dragaera/Steven Brust: http://dragaera.info/ |
On Tue, 13 Jan 2004 23:42:02 -0600 David Dyer-Bennet wrote:
"R.Hubbell" writes: So the question is would any of us be willing to head up to 35,000, crank her up to mach .76 and get out the Glock and let loose a few rounds?? Also suppose the bullet hits some wiring or hydraulics or fuel line, etc. Not me. ![]() I woudln't do it in a *car* either, though. It comes under the heading of "negligible risk, *zero* gain" -- so why risk it? I think you've missed the point. It was to say to Cambell "how confident are you with mythbsuters conclusion?" "will you bet your life on it?" Shooting through the wall between windows pretty much guarantees I won't hit hydraulics, fuel line, etc. See my other post. R. Hubbell -- David Dyer-Bennet, , http://www.dd-b.net/dd-b/ RKBA: http://noguns-nomoney.com http://www.dd-b.net/carry/ Photos: dd-b.lighthunters.net Snapshots: www.dd-b.net/dd-b/SnapshotAlbum/ Dragaera/Steven Brust: http://dragaera.info/ |
![]() "R.Hubbell" wrote in message | | | They did a reasonable job of recreating the environment but we all know | how hostile things are at 35,000 and 600 mph and -35 degrees, where air is | less dense. | | | So the question is would any of us be willing to head up to 35,000, crank her | up to mach .76 and get out the Glock and let loose a few rounds?? | | Also suppose the bullet hits some wiring or hydraulics or fuel line, etc. The air pressure in an airliner is less than one atmosphere, no matter what. At 35,000 feet you are talking half an atmosphere. Compare that to the tires in your car. The airliner produces all of 8 lbs psi, less than a third of the inflation of an automobile tire. All of this other stuff, 600 mph or slight variations of air pressure along the fuselage, etc., is minuscule. Mythbusters gave the hyperventilating pants wetters a bit of a reality check -- and all they can talk about are minor factors that will not change the results in any significant way. I don't care if you empty the entire magazine into a window, you are not going to suck people out of the airplane, the airplane is not going to go into some kind of dive, people are not going to fly all over the interior of the airplane, the seats are not going to be ripped from the floor, or any other Hollywood bull**** like that. |
![]() "C J Campbell" wrote in message ... "R.Hubbell" wrote in message | | | They did a reasonable job of recreating the environment but we all know | how hostile things are at 35,000 and 600 mph and -35 degrees, where air is | less dense. | | | So the question is would any of us be willing to head up to 35,000, crank her | up to mach .76 and get out the Glock and let loose a few rounds?? | | Also suppose the bullet hits some wiring or hydraulics or fuel line, etc. The air pressure in an airliner is less than one atmosphere, no matter what. At 35,000 feet you are talking half an atmosphere. Compare that to the tires in your car. The airliner produces all of 8 lbs psi, less than a third of the inflation of an automobile tire. All of this other stuff, 600 mph or slight variations of air pressure along the fuselage, etc., is minuscule. Mythbusters gave the hyperventilating pants wetters a bit of a reality check -- and all they can talk about are minor factors that will not change the results in any significant way. I don't care if you empty the entire magazine into a window, you are not going to suck people out of the airplane, the airplane is not going to go into some kind of dive, people are not going to fly all over the interior of the airplane, the seats are not going to be ripped from the floor, or any other Hollywood bull**** like that. Yes, but evidently Hubbel is stuck on his Hollyweird delusions. |
![]() "C J Campbell" wrote in message ... "R.Hubbell" wrote in message | | | They did a reasonable job of recreating the environment but we all know | how hostile things are at 35,000 and 600 mph and -35 degrees, where air is | less dense. | | | So the question is would any of us be willing to head up to 35,000, crank her | up to mach .76 and get out the Glock and let loose a few rounds?? | | Also suppose the bullet hits some wiring or hydraulics or fuel line, etc. The air pressure in an airliner is less than one atmosphere, no matter what. At 35,000 feet you are talking half an atmosphere. Compare that to the tires in your car. The airliner produces all of 8 lbs psi, less than a third of the inflation of an automobile tire. All of this other stuff, 600 mph or slight variations of air pressure along the fuselage, etc., is minuscule. Mythbusters gave the hyperventilating pants wetters a bit of a reality check -- and all they can talk about are minor factors that will not change the results in any significant way. I don't care if you empty the entire magazine into a window, you are not going to suck people out of the airplane, the airplane is not going to go into some kind of dive, people are not going to fly all over the interior of the airplane, the seats are not going to be ripped from the floor, or any other Hollywood bull**** like that. How much more clearly can things be explained...to a troll? |
On Wed, 14 Jan 2004 06:24:34 -0700 "Tom Sixkiller" wrote:
"C J Campbell" wrote in message ... "R.Hubbell" wrote in message | | | They did a reasonable job of recreating the environment but we all know | how hostile things are at 35,000 and 600 mph and -35 degrees, where air is | less dense. | | | So the question is would any of us be willing to head up to 35,000, crank her | up to mach .76 and get out the Glock and let loose a few rounds?? | | Also suppose the bullet hits some wiring or hydraulics or fuel line, etc. The air pressure in an airliner is less than one atmosphere, no matter what. At 35,000 feet you are talking half an atmosphere. Compare that to the tires in your car. The airliner produces all of 8 lbs psi, less than a third of the inflation of an automobile tire. All of this other stuff, 600 mph or slight variations of air pressure along the fuselage, etc., is minuscule. Mythbusters gave the hyperventilating pants wetters a bit of a reality check -- and all they can talk about are minor factors that will not change the results in any significant way. I don't care if you empty the entire magazine into a window, you are not going to suck people out of the airplane, the airplane is not going to go into some kind of dive, people are not going to fly all over the interior of the airplane, the seats are not going to be ripped from the floor, or any other Hollywood bull**** like that. How much more clearly can things be explained...to a troll? You know Sixkiler there's some really good research that shows how a positive mental attitude can bolster the immune system. And also that a negative one can have adverse effects. Try to lighten up and enjoy life and concentrate on good things not bad. Yes I am serious. ![]() Don't knock it until you try it. R. Hubbell |
On Wed, 14 Jan 2004 01:46:31 -0800 "C J Campbell" wrote:
"R.Hubbell" wrote in message | | | They did a reasonable job of recreating the environment but we all know | how hostile things are at 35,000 and 600 mph and -35 degrees, where air is | less dense. | | | So the question is would any of us be willing to head up to 35,000, crank her | up to mach .76 and get out the Glock and let loose a few rounds?? | | Also suppose the bullet hits some wiring or hydraulics or fuel line, etc. The air pressure in an airliner is less than one atmosphere, no matter what. At 35,000 feet you are talking half an atmosphere. Compare that to the tires in your car. The airliner produces all of 8 lbs psi, less than a third of the inflation of an automobile tire. All of this other stuff, 600 mph or slight variations of air pressure along the fuselage, etc., is minuscule. Mythbusters gave the hyperventilating pants wetters a bit of a reality check -- and all they can talk about are minor factors that will not change the results in any significant way. I don't care if you empty the entire magazine into a window, you are not going to suck people out of the airplane, the airplane is not going to go into some kind of dive, people are not going to fly all over the interior of the airplane, the seats are not going to be ripped from the floor, or any other Hollywood bull**** like that. You still didn't answer the question though. Will you take a plane up to mach .76, get out your Glock and fire some rounds off through the cabin floor, walls, ceiling or any other random place? If a skymarshal is wrestling someone hell bent on getting his gun the bullets would firing at all angles in all directions. There are simply too many factors that mythbusters didn't replicate to convince me that it's safe to fire 9mm rounds through a fuselage of an aircraft traveling mach .76 at 35,000 ft. where it's -35 degrees. There's something else that comes to mind as well. I was reading a report on the HA (Hawai'i Airlines) accident and they talked about the concussive force that caused the large hole to open up. What happens is similar to water-hammer in water supply lines. The hole has air rushing out thru it at some very high rate then some object from the aircraft plugs the hole. Suddenly all the air destined for the hole backs up behind that object and that generates an extreme and instantaneous amount of force on just that spot. Guess what happens next? A bigger hole appears and if it's not big enough it will get blocked again and we have a repeat of the previous concussive event. Until the hole is bigger than all loose objects. I can't find that site, someone posted it here a while back. R. Hubbell |
![]() "R.Hubbell" wrote in message ... | | | There are simply too many factors that mythbusters didn't replicate | to convince me that it's safe to fire 9mm rounds through a fuselage | of an aircraft traveling mach .76 at 35,000 ft. where it's -35 degrees. | No, it is much safer to pander to unreasoning fear of firearms and instead allow terrorists to gain control of airplanes. I doubt that any test would convince you otherwise. | There's something else that comes to mind as well. I was reading a report | on the HA (Hawai'i Airlines) accident and they talked about the concussive | force that caused the large hole to open up. So what? How many people on that flight died? |
C.J.
You wrote with multi syllable words. You need to go back and rewrite in all one syllable ones so those at the end of the food chain will understand G Big John Pilot ROCAF On Wed, 14 Jan 2004 01:46:31 -0800, "C J Campbell" wrote: "R.Hubbell" wrote in message | | | They did a reasonable job of recreating the environment but we all know | how hostile things are at 35,000 and 600 mph and -35 degrees, where air is | less dense. | | | So the question is would any of us be willing to head up to 35,000, crank her | up to mach .76 and get out the Glock and let loose a few rounds?? | | Also suppose the bullet hits some wiring or hydraulics or fuel line, etc. The air pressure in an airliner is less than one atmosphere, no matter what. At 35,000 feet you are talking half an atmosphere. Compare that to the tires in your car. The airliner produces all of 8 lbs psi, less than a third of the inflation of an automobile tire. All of this other stuff, 600 mph or slight variations of air pressure along the fuselage, etc., is minuscule. Mythbusters gave the hyperventilating pants wetters a bit of a reality check -- and all they can talk about are minor factors that will not change the results in any significant way. I don't care if you empty the entire magazine into a window, you are not going to suck people out of the airplane, the airplane is not going to go into some kind of dive, people are not going to fly all over the interior of the airplane, the seats are not going to be ripped from the floor, or any other Hollywood bull**** like that. |
Can you say: Payne Stewart ? - Explosive Decompression? Try it yourself, numbnuts. | B2431 | Military Aviation | 17 | January 20th 04 11:13 PM |
Can you say: Payne Stewart ? - Explosive Decompression? Try ityourself, numbnuts. | G.R. Patterson III | Military Aviation | 0 | January 14th 04 11:36 PM |
Can you say: Payne Stewart ? - Explosive Decompression? Try ityourself, numbnuts. | G.R. Patterson III | General Aviation | 0 | January 14th 04 11:36 PM |
Can you say: Payne Stewart ? - Explosive Decompression? Try it yourself, numbnuts. | S Narayan | General Aviation | 2 | January 14th 04 10:22 PM |
Explosive decompression by the book | Bob Gardner | Piloting | 4 | January 3rd 04 05:13 AM |
