Tight patterns?
Old January 16th 04, 12:47 AM
Newps
He's flying to a 2 mile final, I learned that the first time I had to
follow him, won't happen again. I'm on downwind behind him. Abeam the
numbers or there abouts I turn base. When he eventually gets on final
I'm already turning crosswind.
lardsoup wrote:
You're kidding, right? How is cutting someone off in the pattern, because
you don't like the way they're flying, safe?
"Newps" wrote. I wouldn't hesitate to
cut somebody off if they flew a huge pattern.
Old January 16th 04, 11:33 AM
Cub Driver
Abeam the
Abeam the numbers?
What is your altitude, and what is your altitude when you turn final,
and how far down the field do you land?
Would you do the same at my home field, which is 2800 feet long?
all the best -- Dan Ford
email:
see the Warbird's Forum at
www.warbirdforum.com
and the Piper Cub Forum at www.pipercubforum.com
Old January 16th 04, 04:45 PM
Newps
Cub Driver wrote:
Abeam the
Abeam the numbers?
Yep, why not? One sweeping constant bank turn to final from downwind.
At paved runways this is what I practice. It's essentially an engine
out manuver.
I don't know, it's all done by sight. You know it when it look right.
I get to midfield downwind at 1000 agl. I always try to be at 1000 agl
at midfield. Speed is 80 mph, flaps 20, power 15 inches. As you turn
base flaps go to 30, turning final they go to 40. No pitch changes that
way. Bank is between 20-30 degrees. You roll wings level as you come
over the numbers or maybe within the first coupla hundred feet at about
50 feet agl, the speed should still be about 75 mph. You know you
nailed it when the bank angle stays constant and you roll out over the
runway.
My home runway is 3800 feet long with a turnoff where another runway
crosses at 2800 feet. I need to add power to get to the turnoff in a
calm wind. If I am landing on a dirt strip I usually practice landing
as short as possible. This means going out to a mile final and slowing
to 55 mph. I aim for the first 50 feet of the runway. With just me and
40 gallons I can get stopped in 450 feet of total runway used in no wind
at a 5000 foot DA. I don't need no stinkin' Cub.
Old January 16th 04, 12:22 PM
lardsoup
What type of air speeds are you talking about? You doing 60kts, they're
doing 100kts? You land and blow a tire, they have to go around? You still
haven't explained how it is safe to cut someone off in the pattern, just
because you don't like the way they are flying?
"Newps" wrote in message
news:ZwGNb.63554$5V2.70987@attbi_s53...
because
Old January 16th 04, 04:49 PM
Newps
It's not cutting anybody off, poor choice of words. I will not follow
you simply because the first time I came into the pattern I got behind
you. Now if there are others in the pattern I may have to follow you,
but if it's just the two of us or the others are no factor I ain't going
out to a two mile final simply because you do. Airspeed? In a normal
situation I slow to 80 mph IAS by the time I get to midfield downwind.
If anybody lands and blows a tire the rest of the people go around.
What's the point?
because
Old January 16th 04, 09:44 PM
lardsoup
I'm thinking maybe it's a good idea you have. Why bother with other
airplanes that bug me. Just do my own thing. There's no law against it,
right? Just wondering how you self announce in the pattern so I get it
right. Is it something like, "ABC traffic, N12123 downwind 32, number 2
behind, ah hell, I'm number one, base 32, ABC"
"Newps" wrote What's the point?
Old January 16th 04, 10:14 PM
Newps
No, I'll ask him. Something to the effect of..."N123 you gonna turn
base at the same place as last time?" He will say yes and then I will
say that I am starting my base now. Never a problem. If he were to say
something like "Nope, this will be a short approach." Then I'll follow.
Just because I have the misfortune to follow you for the first time
around the pattern doesn't mean it has to stay that way for the
remaining landings. They may have a good reason to go out that far.
Most of the time, from my perspective, they don't. Whatever. They have
to do what they are comfortable with. That doesn't mean I have to do it
too.
Old January 17th 04, 02:32 AM
lardsoup
80 kts huh? I like to fly fast. Even in the pattern. Learned that during
the instrument training at BIG airports. You won't mind if I blow past you
at 100kts on the downwind. I mean why should I be stuck behind a slow poke.
Sure, I'll tell you I'm coming. Or maybe not. No reg against not using the
radio. Right?
Old January 18th 04, 04:14 PM
Newps
If you are still behind me when I am on the downwind you'll never catch
me as I usually turn base at the numbers. Or sooner, depending on where
I am parking.
radio. Right?
Old January 26th 04, 08:42 AM
PJ Hunt
"lardsoup" wrote in message
poke.
Absolutely no problem at all. Just be sure to pass on my right where you
belong, because I'll be turning left inside of you.
I don't even care whether or not you use the radio. If you do, that's great.
If you don't, well I can manage ok with that too.
Fly pretty, anyone can fly safe.
PJ
Auto engine bolt patterns Ron Webb Home Built 12 October 20th 04 01:35 PM
Fly tight for tight bomb patterns on the ground. ArtKramr Military Aviation 120 August 30th 04 08:42 AM
Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II) ArtKramr Military Aviation 2 August 27th 03 11:06 AM
Aircraft bomb frag patterns Mike D Military Aviation 6 August 24th 03 05:16 AM
