Cessna 180 vs. 182 vs. 185
Old January 17th 04, 10:16 PM
G.R. Patterson III
Marc Lattoni wrote:
How do the 182 and 185 differ?
The 185 has conventional gear, has either 260 or 300 hp, depending on the year,
seats 6, can haul over 1600 pounds, and cruises at a bit over 165 mph.
The 182 is a trike, has 230 hp, seats 4, can haul about 1300 pounds, and cruises
at a bit over 155 mph.
Fill the tanks, and the 185 still hauls over a quarter ton. Great bush plane.
George Patterson
Great discoveries are not announced with "Eureka!". What's usually said is
"Hummmmm... That's interesting...."
Old January 19th 04, 04:15 PM
Paul Sengupta
"G.R. Patterson III" wrote in message
year,
cruises
Isn't the 185 the predecessor of the 206?
Just done a search...
http://www.skydivestandrews.co.uk/ht...s/facility.htm
says
"The Cessna 185 aircraft is effectively the 'tail dragger' equivalent of a
Cessna 206, and should not be confused with the entirely different Cessna
182."
Paul
Old January 19th 04, 05:36 PM
Newps
The 180 came first. Narrow body, 230 HP, tail wheel. Then in '56 came
the 182. It was just the 180 with a nosewheel. In '61 the 185 was
born. It was the same as the 180 with a 260 HP IO-470 engine. Some
structural beef up was included. In '62 the 182 was widened 4 inches.
In '63 the 205 was introduced, it was the 210 with fixed gear, although
at the time it was called the Super Skylane. In '64 Cessna beefed up
the 205 and created the 206. In '65 the 205 was dropped. In '66 the
185 got the 520 for 285 HP as an option, standard in '67.
Old January 19th 04, 07:24 PM
Paul Sengupta
"Newps" wrote in message
news:wAUOb.100295$I06.444117@attbi_s01...
Bleargh!
So was the 185 ever widened? When did it get 6 seats, or did it always
have 6 seats in certain guises? In the same size plane as a 180? Or as a
later 182? 'eck!
Paul
Old January 19th 04, 07:38 PM
G.R. Patterson III
No.
When did it get 6 seats, or did it always have 6 seats in certain guises?
It always had 6. The 180 had 6 after 1963.
Yep.
Or as a later 182?
The 182 is longer and taller, but has the same wingspan.
George Patterson
Old January 20th 04, 01:21 AM
Dan Thomas
The 185's rear seats are basically kid seats. It's pretty tight in the
back, not like a 206. 206 is more popular with guys hauling people or
freight off average strips. The 185 is better for unimproved strips.
And the 185 is for real pilots.
Dan
"G.R. Patterson III" wrote in message ...
No.
Yep.
Or as a later 182?
George Patterson
Old January 20th 04, 01:26 AM
Doug
For all things 180/185 check out
http://www.skywagon.com/skywagons.html
click on the "model changes"
Both the 180 and 185 have narrower cabins than the 182. Neither the
180 or 185 have a rear full height cargo door (something the 206 has).
But the 206 doesn't have a copilot door. Both the 180 and 185 have the
"jack screw" trim (on the floor) as opposed to a "trim tab". Both the
180 and 185 have manual flaps. The models evolved over the years,
bigger better engines, slightly differnt wings and modern (basic six)
panels.
Early Cessna 182's were narrower than the later models, and the early
182's had the "jack screw" trim and manual flaps. The early 182's were
a nosewheel version of the 180, but after they changed the 182 to the
modern config, it got a wider cabin, different trim and electric flaps
so the differences grew over time.
The 206 is larger and will hold large cargo. It is substantially
easier to load and unload. It has a nosewheel of course. If fitted
with the STC's copilot door, it is the most desirable small
charter/freight airplane up north.
Old January 20th 04, 05:54 AM
Newps
The P206 does. The U206 does not.
Old January 19th 04, 08:02 PM
Newps
Bleargh!
No.
Never.
or did it always
Well, like the 182 it had an option for those jokes they call childs seats.
later 182? 'eck!
The 180 and the 185 always were and are the same size. Now, they do
have some pretty nice extended baggage areas that can be installed. As
a matter of fact Selkirk Aviation just got an extended baggage for the
wide body 182's STC'd. I'll be doing that to mine, it goes back from
the current rear bulkhead 34 inches.
Old January 20th 04, 01:18 AM
Dale
In article TJWOb.101010$xy6.181841@attbi_s02,
Never.
Huh? 185 has 6 seats...and the rear seats are big enough for a 6"2"
175lb person.
Dale L. Falk
There is nothing - absolutely nothing - half so much worth doing
as simply messing around with airplanes.
http://home.gci.net/~sncdfalk/flying.html
1/72 Cessna 300, 400 series scale models Ale Owning 3 October 22nd 13 03:40 PM
FORSALE: HARD TO FIND CESSNA PARTS! Enea Grande Aviation Marketplace 1 November 4th 03 12:57 AM
FORSALE: HARD TO FIND CESSNA PARTS! Enea Grande Owning 1 November 4th 03 12:57 AM
FORSALE: HARD TO FIND CESSNA PARTS! Enea Grande Piloting 1 November 4th 03 12:57 AM
