Maybe the real test is for all these hotshot gun toting stuff the 45
degree entry pilots to take the practical test again fly their normal way and see whether they would get a pink slip. Please don't use the Private Pilot Test Standards as the basis of your argument as some of us were trained beyond them. A pattern entry should be based on judgment, not herd mentality. One size does not fit all. Base your approach on terrain, traffic, your airplane and any other factors that may be present. Hopefully, anyone who has earned a PP has the ability to merge his or her airplane into a pattern full of traffic in a seamless manner using an entry that helps the flow. I think the root of this debate is that most pilots today are not taught to control their airplanes in the pattern. They can't fly slow, and they don't know to look first and talk later. Deb -- 1946 Luscombe 8A (His) 1948 Luscombe 8E (Hers) 1954 Cessna 195B, restoring (Ours) Jasper, Ga. (JZP) |
"Henry and Debbie McFarland" wrote in message link.net...
Maybe the real test is for all these hotshot gun toting stuff the 45 degree entry pilots to take the practical test again fly their normal way and see whether they would get a pink slip. Please don't use the Private Pilot Test Standards as the basis of your argument as some of us were trained beyond them. A pattern entry should be based on judgment, not herd mentality. One size does not fit all. Base your approach on terrain, traffic, your airplane and any other factors that may be present. Hopefully, anyone who has earned a PP has the ability to merge his or her airplane into a pattern full of traffic in a seamless manner using an entry that helps the flow. I thought that's what the 45 degree entry is about and why the FAA whose role is safety advise it. Mind you I realise that some of you in this newsgroup posess more wisdom that the collected experience of all the NTSB investigators all the flight safety specialists, all the FAA inspectors and all of the examiners put together. I am truely lucky to be a witness to your wisdom. I humbly apologise for following the herd, for wanting to be part of an orderly pattern where pilots behave consistantly. I stand corrected. No, I realise that it is better for some pilots to do as they please, communicating their intentions at their discretion. I am really lucky to be learning so much from this newgroup. At the end of my first lesson on this topic I have discovered that so many people are capable of talking out of their assholes. HOWEVER, I suspect this will turn out to be an issue of flying the pattern. http://www.bradenton.com/mld/bradenton/7735795.htm |
Jeb wrote:
HOWEVER, I suspect this will turn out to be an issue of flying the pattern. http://www.bradenton.com/mld/bradenton/7735795.htm Actually, my first instinct was this is not "flying the pattern issue" but typical high wing vs low wing blind spots. From the artical, both planes were on downwind. Sounds from the artical, that the two planes intermingled on downwind, and just didn't see each other due to the blindspot created by wings. Allen |
VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 05:03 AM |
Front louvers for Cherokee/Archer overhead vents? | Bob Chilcoat | Owning | 10 | February 3rd 04 10:19 PM |
Legal question - Pilot liability and possible involvement with a crime | John | Piloting | 5 | November 20th 03 09:40 PM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
