#11
In article om,
"John T" wrote: "Jonathan Goodish" wrote in message The bottom line is that if the small fields don't get a grip on REASONABLE security, one of these days something bad is going to hb_men and there is going to be UNREASONABLE over-reaction. Can you define "reasonable security" for us? Reasonable security would include airport ID badges for those who have a reason to be on the field, perimeter fencing that is tall enough and sealed well enough to be a deterrent, gates that work, and some type of continuous airport surveillence. Those are common sense things that, in most cases, are SUPPOSED to be done anyway at most of these airports, and actually serve to protect the aircraft owners based at the field from theft and vandalism (it's happened around here). My home field has perimeter fencing on only 3 sides and most of the fencing isn't much more than waist high. Despite that, they put in gates with key-codes that have been installed for quite a while but have never been activated. "Reasonable" means that if you're supposed to be on the field and can prove it then you won't be hassled. "Unreasonable" is when they start forcing you to go through the "secure" terminal and have to ride you to your airplane or hangar in an airport vehicle, watch you extract your airplane and lock the hangar, and depart... and I'm sure that wouldn't be the worst of it. Bottom line is that if something bad happens and some news crew goes out to the local airport and finds missing fence and gates that are wide open, the situation is going to get overblown. Oh, yeah, and enforce the terms of the lease that exists, in most cases, for those who are using an airplane hangar as a U-Store by throwing them out. One guy around here was actually bold enough to routinely drive an 18 wheeler through the gate, down the taxiways, and up to his T-hangar so that he could load and unload things. None of those things were ever aviation-related as far as I could tell, and if he ever had an airplane in the hangar it certainly wasn't visible to the naked eye. JKG |
"G.R. Patterson III" wrote in message ...
"Peter R." wrote: Controllers at Philadelphia International Airport made radio contact with the pilot and offered to clear him to land, but 'instead of landing, he flew elsewhere,' Peters said. ------------- end quote -------------------------------- The couple of times I overheard someone bust class B airspace, the controllers weren't in such a generous mood. CNN just did a little creative translation. It probably went more like "To the idiot in the spam can over PHL, get your but down here immediately! And call the tower." George Patterson Great discoveries are not announced with "Eureka!". What's usually said is "Hummmmm... That's interesting...." Where the hell is gravity when sociaty needs it most to weed out the Darwin award winners ?? Ben Haas N801BH |
There is a lot of talk in the article about charging him DWI for driving
drunk on the highway. But there is no mention of the 0.04 and 8 hours bottle-to-throttle rule. Is the FAA not planning to charge him with flying drunk? David Gunter wrote in news:m-ydnYFe9bJxeJrdRVn- : Ugh! -david http://www.cnn.com/2004/US/Northeast/01/16/erratic.plane/index.html or http://snipurl.com/3v8l (I prefer snipurl to other short-URL providers since one is never directed to an advertisement but rather straight to the original link.) |
![]() "Jonathan Goodish" wrote in message ... In article om, "John T" wrote: "Jonathan Goodish" wrote in message The bottom line is that if the small fields don't get a grip on REASONABLE security, one of these days something bad is going to hb_men and there is going to be UNREASONABLE over-reaction. Can you define "reasonable security" for us? Reasonable security would include airport ID badges for those who have a reason to be on the field, perimeter fencing that is tall enough and sealed well enough to be a deterrent, gates that work, and some type of continuous airport surveillence. Those are common sense things that, in most cases, are SUPPOSED to be done anyway at most of these airports, and actually serve to protect the aircraft owners based at the field from theft and vandalism (it's happened around here). My home field has perimeter fencing on only 3 sides and most of the fencing isn't much more than waist high. Despite that, they put in gates with key-codes that have been installed for quite a while but have never been activated. "Reasonable" means that if you're supposed to be on the field and can prove it then you won't be hassled. Your reasonable is totally UNreasonable in my book. For what reason are you creating a prison like facility? What actual problems are you trying to solve? I don't need an ID badge to drive my car why should I need one to fly my plane? My garage does not have continuous surveillence why should airports? I don't have a fence around my garage why should GA airports? Can you provide a reference to support your statement that what you suggest is SUPPOSED to be done at airports? |
![]() "Judah" wrote in message ... | There is a lot of talk in the article about charging him DWI for driving | drunk on the highway. But there is no mention of the 0.04 and 8 hours | bottle-to-throttle rule. Is the FAA not planning to charge him with flying | drunk? | Of course they will, as well as for violating class B airspace, refusing to comply with ATC instructions, and reckless and dangerous operation of an aircraft. The FAA does not move very rapidly, though, so it may be nearly six months before the pilot gets a letter. The FAA may also propose an emergency revocation of the pilot's medical certificate. I suspect that the FAA may wait to see if the pilot reports his DWI within the mandatory time limit. If he does not, then they will get him for that, too. |
![]() "G.R. Patterson III" wrote in message ... Jonathan Goodish wrote: In article , ospam (Rosspilot) wrote: Nice job, CNN. Hasn't hit Fox yet--they are still riveted to Michael Jackson :-) Just hit Fox--they performed true-to-form. "he even flew next to a nuclear power plant" Did he fly next to a nuclear power plant? He had to. His airport is located right next door to one. Which one is that? Palo Verde Nuclear Plant, out here, has been restricted airspace for years. |
![]() Jonathan Goodish wrote: In article , ospam (Rosspilot) wrote: Nice job, CNN. Hasn't hit Fox yet--they are still riveted to Michael Jackson :-) Just hit Fox--they performed true-to-form. "he even flew next to a nuclear power plant" Did he fly next to a nuclear power plant? He had to. His airport is located right next door to one. George Patterson Great discoveries are not announced with "Eureka!". What's usually said is "Hummmmm... That's interesting...." |
![]() Jonathan Goodish wrote: Reasonable security would include .... A whole bunch of things that are wildly UNreasonable, expensive, and useless. George Patterson Great discoveries are not announced with "Eureka!". What's usually said is "Hummmmm... That's interesting...." |
![]() "G.R. Patterson III" wrote in message ... Tom Sixkiller wrote: He had to. His airport is located right next door to one. Which one is that? Palo Verde Nuclear Plant, out here, has been restricted airspace for years. Pottstown, PA. Is that the nuke plant in the upper left of the picture? http://www.airnav.com/airport/KPTW |
OK. The article said the FAA was going to cite him for busting the Class B
and that was it. Seemed to imply that there is no DWI limits on Pilot's License. "C J Campbell" wrote in : "Judah" wrote in message ... | There is a lot of talk in the article about charging him DWI for | driving drunk on the highway. But there is no mention of the 0.04 and | 8 hours bottle-to-throttle rule. Is the FAA not planning to charge him | with flying drunk? | Of course they will, as well as for violating class B airspace, refusing to comply with ATC instructions, and reckless and dangerous operation of an aircraft. The FAA does not move very rapidly, though, so it may be nearly six months before the pilot gets a letter. The FAA may also propose an emergency revocation of the pilot's medical certificate. I suspect that the FAA may wait to see if the pilot reports his DWI within the mandatory time limit. If he does not, then they will get him for that, too. |
Former pilot to win seat as MP | Ben Hoover | Military Aviation | 0 | May 29th 04 01:03 AM |
Catastrophic Decompression; Small Place Solo | Aviation | Piloting | 193 | January 13th 04 08:52 PM |
Effect of Light Sport on General Aviation | Gilan | Home Built | 17 | September 24th 03 06:11 AM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
