![]() "Neil Gould" wrote in message ink.net... Hi, Recently, Tom Sixkiller posted: "Neil Gould" wrote in message What's the security risk, here? What do you think would happen if someone flew a Cherokee into a plant? Here are some things to consider: * The easiest "target" would be one of the cooling towers. A Cherokee would simply compact itself on the side of the towers and fall off. * The reactor in the plants around here is surrounded by other buildings. It would be *very* difficult to hit the building that contains the reactor. But, the result of doing so with a Cherokee would be similar to the result of the 172 that hit the office building in Fla. You might break a window or two in the building. The fear of danger caused by someone flying a GA plane into a nuclear power plant is simply irrational. There is a *far* greater risk of catastrophe from poor maintenance practices in the every day use of these plants, as can be exemplified by the Davis-Besse fiasco that we're dealing with here in Ohio. Poor maintenance in a government run/regulated facility? The nuclear plants in Ohio are run by private companies, just as other utilities. I suspect that many, if not most plants are owned and operated by private utilities. As for poor regulation... well, that's one of the by-products of relaxed rules and deregulation. _relaxed_ , how? I'd like to know your definition of "deregulation". Remember: The roughly same poeple that regulate the nuclear industry also regulate avaition safety. (shudder!!!) In this particular case, the Davis-Besse plant has been down for the last couple of years because of maintenance and operation problems. The problem that got the most attention was a hole about the size of a football eaten almost all the way through the reactor lid by dripping acid. Had that gone far enough that the operating pressure caused the lid to fracture, a good portion of Northern Ohio would have been in deep trouble. I'd heard something along that line -- do you have a reference with more detail? The point, though, is that we are supposedly under tightened security, so "why wasn't the action deal with more severely"? The fact is, we're under the *illusion* of tightened security, based on being pointlessly harrassed in fairly meaningless ways. And, in areas where we have some *real* problems, we're far too laxadaisical. A Cherokee is just not likely to do any serious damage to a building, much less one built to the standards of a nuclear (or *any*) power plant. Visit one sometime, and imagine yourself in the cockpit trying to do some damage. To present such as scenario as a plausible threat to our safety is one version of terrorist activity, as far as I'm concerned. Oh, I know howthey're built...and you're right -- most of it is meaningless scare tactics. |
FS: N.A.S.A. Astronauts "Autographed" 8x10 Photos | J.R. Sinclair | Aviation Marketplace | 1 | December 14th 04 04:37 PM |
Black is black ! | Dummy | Owning | 0 | September 1st 04 05:19 PM |
Black is black | Dummy | General Aviation | 0 | September 1st 04 05:19 PM |
FS: N.A.S.A. Astronauts "Autographed" 8x10 Photos | J.R. Sinclair | Aviation Marketplace | 0 | January 5th 04 05:44 AM |
Soviet Submarines Losses - WWII | Mike Yared | Military Aviation | 4 | October 30th 03 03:09 AM |
