P-51 Mustang Parts on display
Old January 16th 04, 11:21 PM
Jay Honeck
Default P-51 Mustang Parts on display
Finally got the parts that Vlado Lenoch donated for our new Mustang Suite
mounted on a big ol' oak plank, and hung on the wall.
Check 'em out at http://www.alexisparkinn.com/the_mustang_suite.htm (Pix
are at the bottom of the page.)
My personal favorite is the "Circuit Destroyer" that originally contained an
explosive charge, used for destroying the electronics on board if the pilot
thought capture was imminent! (Wouldn't want to hit THAT button by
accident... ;-)
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old January 17th 04, 07:20 PM
john smith
wow!!! Those really did clean up well!
Old January 18th 04, 05:20 AM
Big John
Jay
FYI
If I remember right the explosive charge was only in the IFF to
destroy it and prevent the design/coding from falling into enemy
hands.
The VHF radio was the SCR-522, a four channel (A,B,C,D) set that used
a 832 tube in the output. Channel 'A' was air to ground (tower).
Channel 'B' was air to air. Channel 'C' was an aux channel (fighter to
bomber ,etc) and 'D' was emergency channel (121.5 Mc). These channels
were crystal controlled and if mission called for other frequencies,
the Mechs had to change the crystals prior to take off.
There was also a little low frequency receiver, 4 inches by 4 inches
by 6 5/8 inches that sat on the floor (retrofit) just in front of the
seat behind the left heel and off set from stick, and made by Detrola.
It was called the 'Detrola' and not by it's Model Number. Was used to
tune in radio ranges (200-400 kc). Had a short antenna and very
limited range.
Just some more errata for your file Jay.
Big John
Pilot ROCAF
On Fri, 16 Jan 2004 23:21:40 GMT, "Jay Honeck"
accident... ;-)
Old January 18th 04, 05:48 AM
Don Tuite
On Sat, 17 Jan 2004 23:20:45 -0600, Big John
The SCR522 (and 524) became the standard for a lot or ham radio
2-meter work in the 1950s.
Don
(NR7X)
Old January 18th 04, 01:39 PM
Jay Honeck
hands.
Thanks, Big John.
Can you tell me anything about the design of the circuit destroyer itself?
It's a strange device, with a removable (it unscrews) clear plastic cap,
underneath which sits some sort of an inertial thing-a-ma-bob. It swings in
an arc, suspended like a pendulum, but cannot hang straight down, by design.
I know that doesn't make any sense, but perhaps you'll know what I'm talking
about?
Thanks,
Jay Honeck
Iowa City, IA
Pathfinder N56993
"Big John" wrote in message
Jay
FYI
limited range.
Big John
Pilot ROCAF
(Pix
an
pilot
accident... ;-)
Old January 18th 04, 11:35 PM
Big John
Don
Yep. Had several of them.
Big John
Pilot ROCAF
On Sun, 18 Jan 2004 05:48:00 GMT, Don Tuite
Don
(NR7X)
Old January 19th 04, 02:26 AM
Big John
Jay
Can't help you there Jay. Never saw the part. Just remember they had a
destruct element in system.
Maybe someone reading the Thread can help with details ?
It's possible one of the individuals who has copied the manuals of
WWII equipment might be able to give some data or if he has the manual
copied you might be able to buy from him?
I'll continue looking but probably won't find any detailed data????
Extracted from the Internet. Not a lot but a little more FYI.
"Pilots, who were not familiar with radar, did not appreciate the
importance of switching on the IFF. Alongside the switch to turn on
the unit was the IFF destruct switch to prevent its capture by the
enemy. Many a pilot chose the wrong switch and blew up his IFF unit.
The thud of a contained explosion and the acrid smell of burning
insulation in the cockpit did not deter many pilots from destroying
IFF units time and time again. Eventually, the self destruct switch
was secured by a thin wire to prevent its accidental use. During World
War II, both metric and centimetric radars proliferated on ships of
the major navies. Search radars were joined by fire control sets and
ultimately, a ship could locate and destroy air or surface targets in
conditions of zero visibility. It therefore became important to be
able to identify the targets, or at least distinguish friend from
enemy."
Big John
Pilot ROCAF
On Sun, 18 Jan 2004 13:39:26 GMT, "Jay Honeck"
hands.
Thanks, Big John.
about?
Thanks,
Old January 19th 04, 10:53 PM
Jay Honeck
Fascinating stuff.
Thanks, Big John!
Jay Honeck
Iowa City, IA
Pathfinder N56993
Jay
enemy."
Big John
Pilot ROCAF
hands.
Thanks, Big John.
itself?
in
design.
talking
about?
Thanks,
A-6 Redar Display? Mike Kanze Naval Aviation 0 September 28th 04 01:34 AM
The Mustang Suite is done! Jay Honeck Owning 8 January 12th 04 03:48 PM
Info on a P-51 mustang called "Spare Parts" eg Home Built 3 October 28th 03 02:02 AM
Info on a P-51 mustang called "Spare Parts" eg Military Aviation 1 October 28th 03 01:49 AM
Navion Parts Availability Margy Natalie Owning 12 August 15th 03 03:47 AM
