Does anyone know of any adapters or such that would allow hooking up
an audio recorder to record all cockpit communications? ie, both transmissions to ATC and conversations to other passengers. Thanks, Glenn |
"Glenn Westfall" wrote in message
Does anyone know of any adapters or such that would allow hooking up an audio recorder to record all cockpit communications? ie, both transmissions to ATC and conversations to other passengers. Assuming your aircraft has an intercom, you can make a direct-connect cable using Gene Whitt's directions found he http://tinyurl.com/36x3c I typically use a portable intercom that has an audio out jack. I use a patch cord to connect that to either my voice recorder or my video recorder. Having the portable intercom handy also provides a battery-powered backup for the plane's intercom (actually used in that capacity once). -- John T http://tknowlogy.com/TknoFlyer http://www.pocketgear.com/products_s...veloperid=4415 ____________________ |
![]() "Glenn Westfall" wrote in message ... Does anyone know of any adapters or such that would allow hooking up an audio recorder to record all cockpit communications? ie, both transmissions to ATC and conversations to other passengers. Thanks, Glenn Glenn, Not an answer to your question, but are you in Ft. Worth? |
aircraftpatchcord.com I think is where I got my cord, but then to get it to
work I had to replace one of the resistors in it with one of the size that Gene Whitt used. I use a cheap Panasonic voice activated tape recorder that will record at 1/3 speed so I can get well over 2 hours on one side of a 90 minute cassette. -- Jim Burns III Remove "nospam" to reply "Glenn Westfall" wrote in message ... Does anyone know of any adapters or such that would allow hooking up an audio recorder to record all cockpit communications? ie, both transmissions to ATC and conversations to other passengers. Thanks, Glenn |
cable using Gene Whitt's directions found he http://tinyurl.com/36x3c I've made one of these cables, and they work good. I don't mess with tapes, though. I bought an Olympus DM-1 digital recorder.. With the included 64MB Smart Media, it will record for 10 hours on best quality. Double that if you get a 128MB card. (Which is the max you can use). It also plays back MP3/WMA format music files too. Here's a small .wav clip from one of my recordings: http://tinyurl.com/2ycds -- Ben C-172 - N13258 @ 87Y |
![]() "Glenn Westfall" wrote in message ... Does anyone know of any adapters or such that would allow hooking up an audio recorder to record all cockpit communications? ie, both transmissions to ATC and conversations to other passengers. Get a small microphone from radio snack. Plug it in to the tape recorder and stuff the other end into the ear cup of your headset. |
"Ben Smith" wrote in message ...
Assuming your aircraft has an intercom, you can make a direct-connect cable using Gene Whitt's directions found he http://tinyurl.com/36x3c I've made one of these cables, and they work good. I don't mess with tapes, though. I bought an Olympus DM-1 digital recorder.. With the included 64MB Smart Media, it will record for 10 hours on best quality. Double that if you get a 128MB card. (Which is the max you can use). It also plays back MP3/WMA format music files too. Here's a small .wav clip from one of my recordings: http://tinyurl.com/2ycds I record all my flights with students using a tiny digital recorder. I have a very simple system that works wonderfully. You don't have to tap into the intercom system. It is so simple that I record every single flight, whether it is useful or not. I have written an article about the setup on my website. http://www.geocities.com/asarangan/aviation (and click on Cockpit Voice Recorders). |
"Andrew Sarangan" wrote in message
om... I record all my flights with students using a tiny digital recorder. I have a very simple system that works wonderfully. You don't have to tap into the intercom system. It is so simple that I record every single flight, whether it is useful or not. I have written an article about the setup on my website. http://www.geocities.com/asarangan/aviation (and click on Cockpit Voice Recorders). That's pretty cool. Even more straightforwardly, if you have a spare headset and intercom station, you can just give the recorder its own headset, pressing the two ear pieces together with the recorder in between. I think I'll try that next time I fly. --Gary |
On Thu, 22 Jan 2004 13:17:58 GMT, "Chuck"
wrote: "Glenn Westfall" wrote in message .. . Does anyone know of any adapters or such that would allow hooking up an audio recorder to record all cockpit communications? ie, both transmissions to ATC and conversations to other passengers. Thanks, Glenn Glenn, Not an answer to your question, but are you in Ft. Worth? No...I am in Okinawa at the moment. I am from Southern CA. |
backup cockpit lighting | Josef Burger | Instrument Flight Rules | 35 | January 2nd 05 01:23 AM |
Antonov vs Galaxy cockpit | Emilio | Military Aviation | 13 | July 2nd 04 06:15 AM |
Survey - 3 blade prop conversion- Cockpit vibration, happy or not | Fly | Owning | 20 | June 30th 04 05:32 PM |
What are you guys using for cockpit lights these days? | Stealth Pilot | Home Built | 6 | December 9th 03 09:14 AM |
FS DeHavilland Open Cockpit Chipmunk | [email protected] | Aviation Marketplace | 0 | October 14th 03 11:10 AM |
