Approach speeds for ILS
Old January 22nd 04, 09:37 PM
Gary Drescher
"Capt.Doug" wrote in message
My charts do not list a time for the final approach segment for 60 knots.
What time do you use if the glideslope craps out?
Twice the time listed for 120 knots.
--Gary
  #62
Old January 22nd 04, 10:39 PM
Tom Sixkiller
"C J Campbell"wrote in message I have no problem with
flying the ILS at 90 or 100 knots if the ceiling is well above
minimums, but it seems to me that if the ceiling is 200 feet
overcast you ought to be flying the approach slowly enough
that you can land at that speed. You don't need to configure for
a short field landing, but you are not going to slow from 90
knots to 60 in a Skyhawk in only 200 feet of altitude, especially
if you can't risk ballooning back up into the soup.
If you have to go around, wouldn't you want speed built up ahead of time?
  #63
Old January 23rd 04, 08:40 AM
Thomas Borchert
C,
As Bob and others have said: you don't need to start the slow down at
breakout. Why not start slowing down at the middle marker - and land
long? The combination of the two makes fast approaches absolutely
possible.
I believe John Deakin has a column on this at Avweb. I know he likes to
fly 150 knots approaches in his Bo - he likes to hear "Bonanza xxx,
slow down, you're gaining on the 737 in front of you" g.
Thomas Borchert (EDDH)
  #64
Old January 23rd 04, 02:44 PM
Mick Ruthven
GUMPS at DH
You don't mean a GUMPs check at decision height, do you? I want everything
checked well before decision height so there's nothing to do at decision
height except either land or go missed.
"Roy Smith" wrote in message
In article OSzPb.98715$5V2.327271@attbi_s53,
"John R Weiss" wrote:
I s'pose. But you really shouldn't be playing with the throttle
constantly either. Somewhere along the line I picked up adding "DFWTP"
to my ILS checklist. DFWTP at GS intercept, GUMPS at DH. It stands for
"Don't F*** With The Power".
  #65
Old January 23rd 04, 04:11 PM
Roy Smith
"Mick Ruthven" wrote:
GUMPS at DH
Well, OK, maybe not at DH per-se, but it certainly gets done just before
I land. That doesn't mean it wasn't all set up correctly before, but
the habit of doing GUMPS on short final isn't a bad habit.
  #66
Old January 24th 04, 07:54 PM
Tarver Engineering
"Roy Smith" wrote...
Since the only reconfiguring you should have to do, if any,
is final flaps, you have plenty of time!
Pulling the power back to idle might be nice too :-)
I consider that part of the 'stick and throttle' part of flying that is
done
constantly, not "reconfiguring," which is done a couple times per
flight.
I s'pose.
Autothrottle does all that in Weiss' airplane and he slept through it.
  #67
Old March 2nd 04, 05:36 PM
Ray Andraka
Hmm, I was taught to use the throttle to stay on glideslope, not the elevator.
I find using the throttle results in more controllability.
--Ray Andraka, P.E.
President, the Andraka Consulting Group, Inc.
401/884-7930 Fax 401/884-7950
email
http://www.andraka.com
"They that give up essential liberty to obtain a little
temporary safety deserve neither liberty nor safety."
-Benjamin Franklin, 1759
  #68
Old March 2nd 04, 06:01 PM
Peter Duniho
"Ray Andraka" wrote in message
elevator.
A little late to the thread, aren't you? That was over a month ago.
Anyway...
Your comment points to a classic debate, of course. Likely that no person
on one side will be convinced to change their methods. However, suffice to
say there are plenty of us that find that elevator is a more responsive and
useful way to adjust glideslope during an instrument approach. You're above
L/Dmax (so pitch changes do "what you expect"), and the result of a pitch
change is somewhat more uniform from airplane to airplane (power changes can
produce radically different results from airplane to airplane, depending on
drag, weight, and type of powerplant).
Either throttle or pitch can be used for the same purpose, with
approximately the same effect.
All that said, IMHO if you're going to say something like "I find using the
throttle results in more controllability", you ought to define what
"controllability" means. Making glideslope changes with pitch instead
certainly doesn't cause the airplane to go out of control, so it's not
really clear what difference you're talking about.
Pete
  #69
Old March 2nd 04, 08:28 PM
Roger Tracy
It's certainly a matter of perception and everyone thinks about
it differently. My feeling is it's a combination of both. I start
with slight pitch changes and adjust the throttle accordingly.
If you're timing your ILS approaches you'd want to maintain
a constant speed.
elevator.
--Ray Andraka, P.E.
email
  #70
Old March 2nd 04, 09:44 PM
Ray Andraka
I used to do it with elevator, till an instructor on one of the refresher
courses I took showed me how much better power worked for my airplane (a
cherokee six). I can keep the needle centered much better with small changes in
power than I can with the elevator. SO what I mean by controllability, is the
ability to keep the needle pegged.
Peter Duniho wrote:--
--Ray Andraka, P.E.
email
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 05:03 AM
F-18 Approach and touchdown speeds on runways? Paul Michael Brown Naval Aviation 5 August 25th 04 04:56 PM
Canadian holding procedures Derrick Early Instrument Flight Rules 24 July 22nd 04 04:03 PM
Approach speeds for ILS C J Campbell Instrument Flight Rules 73 March 2nd 04 11:20 PM
