On Mon, 26 Apr 2004 13:16:54 -0400, "George A. Graham"
wrote: The BSFC of the Mazda wankle can get as good as .42, where the Lycoming is over .5, and the turbo diesel is best at .36 lbs/hp/hr. I am aware that most people should avoid trying to craft their own airplane engine, but if you are so inclined, the Wankle rules! Hey George, good to hear from you. The Lycoming engine can get as low as .38 BSFC when properly set up. Few pilots seem willing to go there though as it requires leaning past peak. See John Deakin and "Mixture Magic" in the AVWeb columns. The GAMI folks demonstrate the above fuel burn routinely on their test stand. Auto engines tend to be at ..42 as you mention. I think lower BSFC with the big bore aircraft engines has to do with large pistons and long stroke, I think, not absolutely sure. I'm getting set to do the ground runs on my engine and intend to run it throughout the summer at high power settings. I don't understand people who just bolt an engine, any engine, to the airframe and then try to go flying without any test runs. Corky Scott |
Ernest Christley wrote:
wrote: I'm getting set to do the ground runs on my engine and intend to run it throughout the summer at high power settings. I don't understand people who just bolt an engine, any engine, to the airframe and then try to go flying without any test runs. Corky Scott And don't just run it on the ground. You've got to instrument that baby. Get a bunch of temperature probes and stick one to everything you can. Add a handful of accelerometers to measure vibration at multiple points if you can get your hands on them. I've read that the biggest advances in aviation power during the second world war came about due to improvements in instrumentation. It makes sense. You won't know what to strengthen or cool if you don't know what's hot or under harmonic vibrations. Someone here mentioned an adjustable strobe light at night to look for harmonics. -- http://www.ernest.isa-geek.org/ "Ignorance is mankinds normal state, alleviated by information and experience." Veeduber Good point. Excellent point, in fact. My engine is a VW. Not a certified aircraft engine. Quite a bit less then $1,000,000 has been spent on detailed engineering, testing, analysis, etc to convert this into a safe aircraft engine. Even though haven't spent much of that million on engineering, I don't seem to have much left for instrumentation ![]() fund). Accelerometers struck out - cost, complexity, and I wouldn't know what to do with them anyway. One thing I would like to instrument is the carburetor temperature. Not a permenant gauge on the panel (I have one - but there's no space). Just a low buck way of monitoring the carb temp in flight for a while to see whazzappenin and see if pulling the carb heat knob is really doing anything. The carb is below the engine (KR2 style intakes manifold from GPAS) where it is not warmed much from engine heat. One of these days I want to make new exhaust pipes with a proper carb heat muff. But for now, I wonder if the air passing thru the cylinder fins would be hot enough (too hot enough?) to work well - or not? Only way to know for sure is to measure it. Isn't there supposed to be a way to do that with a digital multimeter and thermosistor, or thermocouple (what)? Richard PS: thanks for remembering the harmonics thread, Robert. (:it was fun ![]() I remember thinking(back then) that I wanted to take a real good look a the engine installation on the new plane for harmonic reactions. I even asked around and found someone who have an old variable speed disco strobe for the job. But the engine wasn't ready to run back then, and I forgot about it. Until now. Thanks. Richard |
Richard Lamb wrote:
PS: thanks for remembering the harmonics thread, Robert. (:it was fun ![]() I remember thinking(back then) that I wanted to take a real good look a the engine installation on the new plane for harmonic reactions. I even asked around and found someone who have an old variable speed disco strobe for the job. But the engine wasn't ready to run back then, and I forgot about it. Until now. Thanks. Richard Radio Shack has a strobe for about $20. It's cheap, and won't even give an epiletic a fit, but it has variable timing and does flash. You just won't be able to use it in direct sunlight. Wait 'till evening or find an old barn? -- http://www.ernest.isa-geek.org/ "Ignorance is mankinds normal state, alleviated by information and experience." Veeduber |
In article , Ernest Christley wrote:
Another strobe that many people have in their shop is an automotive timing light. You can wind a simple coil of a few dozen turns and put it in the trigger clip. Then, any convenient signal source such as an audio signal generator can be used to produce the timing signals. good luck, tom pettit PS: thanks for remembering the harmonics thread, Robert. (:it was fun ![]() I remember thinking(back then) that I wanted to take a real good look a the engine installation on the new plane for harmonic reactions. I even asked around and found someone who have an old variable speed disco strobe for the job. But the engine wasn't ready to run back then, and I forgot about it. Until now. Thanks. Richard Radio Shack has a strobe for about $20. It's cheap, and won't even give an epiletic a fit, but it has variable timing and does flash. You just won't be able to use it in direct sunlight. Wait 'till evening or find an old barn? |
On Tue, 27 Apr 2004 14:15:28 GMT, wrote: In article , Ernest Christley wrote: Another strobe that many people have in their shop is an automotive timing light. You can wind a simple coil of a few dozen turns and put it in the trigger clip. Then, any convenient signal source such as an audio signal generator can be used to produce the timing signals. good luck, tom pettit But what's a fella to do with the flashing light? What are you checking and what's it all mean? I mean the engine's going to have this 74" diameter prop on it and it's bound to vibrate some. How do you tell what's normal and what isn't? Corky Scott I like that timing light idea. With my laptop and a simple program I can have a lot more range than is possible with the RatShack thing I have. Corky, the strobe will slow down any flexing due to vibrations to the point where you can clearly see it. Sorta makes it slow motion. I would say that if you can clearly distinquish the flexing in a motor mount or other supporting part, then it is way too much, and you should consider a redesign. It may not tell you anything interesting at all, it's just an easy way to see what and where the vibration are and how much they are shaking what. But you are right, just because it's moving doesn't mean it's coming apart. I'll counter that you can decide what is normal for yourself once you see it moving, and I'll bet dollars to donuts that if you do see a lot of movement you'll be an expert on what is normal before the engine leaves the ground 8*) (Yes, that was a long winded way of saying, "I don't rightly know.") -- http://www.ernest.isa-geek.org/ "Ignorance is mankinds normal state, alleviated by information and experience." Veeduber |
Richard,
Check this out... four K-type thermocouples and readout for $100! I have had one for a couple years and it gets used every flight. Omega is a well-respected name in industrial/scientific community. http://www.omega.com/ppt/pptsc.asp?ref=HH501DK Sid Knox Velocity N199RS Starduster N666SK KR2 N24TC W7QJQ One thing I would like to instrument is the carburetor temperature. Not a permenant gauge on the panel (I have one - but there's no space). Just a low buck way of monitoring the carb temp in flight for a while to see whazzappenin and see if pulling the carb heat knob is really doing anything. The carb is below the engine (KR2 style intakes manifold from GPAS) where it is not warmed much from engine heat. One of these days I want to make new exhaust pipes with a proper carb heat muff. But for now, I wonder if the air passing thru the cylinder fins would be hot enough (too hot enough?) to work well - or not? Only way to know for sure is to measure it. Isn't there supposed to be a way to do that with a digital multimeter and thermosistor, or thermocouple (what)? Richard |
Car engine FAA certified for airplane use | Cy Galley | Home Built | 10 | February 6th 04 03:03 PM |
Objective Engine Discussion | Rick Maddy | Home Built | 26 | October 14th 03 04:46 AM |
Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 04:29 AM |
Gasflow of VW engine | Veeduber | Home Built | 4 | July 14th 03 08:06 AM |
