Heat is usually the big one. How you get rid of it is critical, of course.
Dave Driskoll (DH) can probably tell us all more about this. One of the things that is really cool about the DeltaHawk engines is that they are designed to be run continuously at max (pretty sure about this.....Dave, are you there?). That's a lot of full-time horses. "Jay" wrote in message om... Hi Pete, What factors dictate the difference between max and continuous rated power? The main one I can think of is the ability to remove waste heat. And of course a diesel produces less waste heat per unit HP than a spark ignition engine. |
Pete Schaefer wrote:
Heat is usually the big one. How you get rid of it is critical, of course. Dave Driskoll (DH) can probably tell us all more about this. One of the things that is really cool about the DeltaHawk engines is that they are designed to be run continuously at max (pretty sure about this.....Dave, are you there?). That's a lot of full-time horses. That't what it takes for aircraft ops. |
Richard Lamb wrote:
Pete Schaefer wrote: Heat is usually the big one. How you get rid of it is critical, of course. Dave Driskoll (DH) can probably tell us all more about this. One of the things that is really cool about the DeltaHawk engines is that they are designed to be run continuously at max (pretty sure about this.....Dave, are you there?). That's a lot of full-time horses. That't what it takes for aircraft ops. Pete is quite correct, dumping heat is major hurdle to continuous power operations and unfortunately it is generally not as simple as adding larger radiators or oil coolers. Extracting BTU's from the oil or coolant is really the simple part of the problem. Getting BTU's from the combustion chamber, through the cylinder sleeves, piston crowns, and fire plates without cooking the coolant, your bearings, or any of the aforementioned parts can be quite challenging. As a simple example, the VW TDI uses an oil squirter to spray cooling oil on the bottom of the piston. That system is designed to remove a BTU's at a certain rate and remain in equilibrium, IE stable oil temperature at a certain HP (this would be the maximum continuous HP). If we decide to increase the max. HP we now have to remove more BTU's with the oil to maintain a stable temperature, this means more oil needs to be sprayed. Ok put a bigger orifice on the oil jet. Unfortunately putting on a larger jet reduces oil pressure which is bad for the main bearings, so in addition to the larger jet, we now need to put a larger oil pump on the engine to give us the required oil pressure. Oops that bigger pump uses some of the additional HP that you thought you were going to get and now we repeat the process with a larger jet and oil pump so we net out the HP we are really after. Ok now that we've go that solved, we notice that all the extra oil flinging around in the crank case is too much for our current ring pack and we need a new design there for better oil control. This new ring pack will of course mean more friction, less net HP, etc., etc., etc. (bang head here)...... As Pete commented, the DeltaHawk is rated for continuos duty throughout its HP range (as are most aircraft engines), most automotive engines are not. While there certainly have been a number of very successful automotive conversions, all of the successful ones have been the result of a significant engineering and test efforts (a program which I suspect is probably not unlike developing an aviation diesel from scratch). Dave Driscoll DeltaHawk LLC |
On Tue, 27 Apr 2004 10:48:31 -0500, Dave Driscoll
wrote: As Pete commented, the DeltaHawk is rated for continuos duty throughout its HP range (as are most aircraft engines), most automotive engines are not. While there certainly have been a number of very successful automotive conversions, all of the successful ones have been the result of a significant engineering and test efforts (a program which I suspect is probably not unlike developing an aviation diesel from scratch). Mostly really interesting information Dave, but your remark about auto engines not being rated at continuous maximum power prompts me to ask if it's time to repost that article I have that was written by an auto engineer who ran the engine test cells at (not sure which major manufacturer he worked for but it's in the article). To synopsize, they beat those engines up pretty well, trying to blow them. They plan to sell not just hundreds, or thousands of engines, but millions of them. Selling an engine that turns out to have an endemic problem would be catastrophic for sales. So they run them literally for hundreds of hours at full throttle and peak rpm. That's just one test. None of the auto manufacturers can afford to neglect this kind of engine development so every single one does these types of destructive tests to make sure the engine can stand it. So while the typical auto engine may not be designed to produce maximum continuous power, they sure can do it. Corky Scott PS, I will repost the article if there is enough interest. I get requests to do so about once a year. |
I would like to see the article.
So while the typical auto engine may not be designed to produce maximum continuous power, they sure can do it. Corky Scott PS, I will repost the article if there is enough interest. I get requests to do so about once a year. --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.663 / Virus Database: 426 - Release Date: 4/20/2004 |
On Tue, 27 Apr 2004 10:09:59 -0700, "Bryan"
wrote: I would like to see the article. As you wish. Please note, the article below was published in Contact! Magazine some several years ago when Mick Myal was the publisher. He's retired from the magazine now but was at the head at the time of the article so I left that part in. I've made some editorial comments here and there in the text. Corky Max Freeman is the engineer in charge of GM's Premium Engine programs and has written an article for Mick Myal in the latest "Contact!" magazine regarding the development and testing of their new PV6 aluminum 90° bank angle V-6. It's a lot of technical stuff about why they chose this configuration or mechanical design over that, which is why I like it. He also wrote about the kind of developmental testing done on the engine to make sure that customers get an engine they can depend on, and I'd very much like to quote that section in full because it should lay to rest the question of whether auto engines can take the kind of power settings aircraft engines routinely manage. "PERFORMANCE The engine in production form for 1999 develops 215 HP at 5600 RPM and 230 foot pounds of torque at 4400 rpm. As a routine part of an engine development program we tested the engine at full power, maximum RPM. We ran it at 6000 RPM, pulling 215 HP at wide open throttle, for 265 hours. That's a continuous 265 hours of wide open throttle, far worse than autobahn driving, because even on the German Autobahn, you wouldn't be at 6000 RPM. THAT IS A STANDARD DURABILITY TEST. (emphasis mine) We run many engines through this test as a matter of course. Specific development focus is on the crank, pistons, rods, block structure, timing drive wear; we get a lot of full load cycles in a hurry. It isn't necessarily designed to replicate customer driving but to get development answers. Wear and fatigue are accelerated. The test is particularly applicable in proving out dampers and their effectiveness. If the damper is not properly tuned to the engine the crankshaft will inevitably break in that time period. (note, this is evidence you should not discard the stock damper when using the auto engine for aircraft power) A number of other engine tests are utilized. We use a variety of specific tests to accelerate engine wear and to look at fatigue failures. The cyclic endurance test is now called PTED (power train endurance). It closely approximates cyclic durability. The engine is cycled from its torque peak to its horsepower peak, at wide open throttle, then down to idle, then accelerates up to shift points, then back down to the torque peak and then horsepower peak. This test is run for 400 hours. Once again, it's a wide open throttle test for 400 hours. The RPM for this engine, ranged between 4400 and 6000 RPM, back and forth in about a 5 minute cycle. The dyno computer will occasionally bring the engine down to idle, up to 6500 RPM shift points, and then back to the 4400 - 6000 RPM 5 minute cycle. Thermal cycle tests are run to define engine capability under cold weather condition. We run the engine at full throttle at 4000 RPM, bring it down to idle, stop it, switch the coolant valves to drain the hot coolant, pump the chilled coolant from the chiller until the metal temperature stabilizes at 0 degrees F. Frost forms on the outside of the block, as the cold coolant rushes into the engine. When it stabilizes at 0 F, we motor the engine, start it, come to full throttle at 4400 RPM, the valves switch and the coolant temperature starts to climb. It climbs back up to 260 degrees F. It takes 10 -11 minutes to complete one cycle. The engine must pass 600 cycles without any sign of failure. We typically run 1200 cycles and a probe test will run 1600 cycles. That's a (sic) excellent gasket killer test. Head gaskets are the first to fail because of the rapid expansion and contraction. A powertrain endurance test simulates in-vehicle operation. The Ypsilanti plant uses it for testing transmission. We, of course, use it to look at engine performance. The equipment consists of an engine/transmission combination, which sits on a dyno with large steel inertia wheels. The inertia wheels are being driven by the transmission output shaft, just like in a car. They cycle is brutal; the engine is at idle in gear. The engine accelerates wide open to 6200 RPM, upshift occurs, 6200 RPM is reached, upshift occurs to 3rd, 6200 RPM is reached, upshift occurs to 4th, the wheels turn up to 135 MPH depending on the application. The second half of the cycle calls for a closed throttle down to 70 MPH, then wide open throttle with a downshift to 2nd, the engine goes back up to top speed, coasts down so that the transmission selects down to a lower range. The engine is in an overrun condition all the way down to idle; i.e., the engine is being used for braking. That's one cycle. One transmission life cycle is typically 12K - 13K cycles of the above test. We will run an engine through 4 or 5 transmissions. This is a very harsh schedule for the engine, particularly because of the overrun braking. Cylinders and rings suffer the most on this test. We run some idle tests to verify low speed operation. The engine is run at idle for about 2000 hours to make sure of adequate oil flow at idle. We use all those engine tests in addition to fleet tests and extensive vehicle road testing. The customer can be assured that the PV6 engine is a thoroughly tested advanced design that matches or exceeds competing offerings." I don't believe engine testing for aircraft certification approaches this intensity, duration or severity. My thanks to Mick Myal for his continued excellence in publishing his magazine. Corky Scott |
On Tue, 27 Apr 2004 14:10:09 -0500, Dave Driscoll
wrote: The thrust of my point was not to imply that automotive engines cannot be successfully modified for use in aircraft, they quite conclusively can, but rather to demonstrate some of the challenges that can be encountered in making any required modifications and what those modifications might be. I understand. The engine I'm attempting to use is the Ford 3.8L V6. This engine was originally modified by David Blanton back in the early 70's. I hesitate to mention his name because he got mired in controversy towards the end of his life claiming really exhorbitant horsepower for the engine as used in the airframe. The 3.8 needs a different cam in order to develop the power it should. You can also install Wiseco pistons which create a 9 to 1 compression ratio. Some guys haven't changed the pistons and managed to fly anyway. My understanding is that the new V6, the 4.2, is capable of being used as is, without any modifications, which means not changing the cam. I don't know that for a fact, it was stated to me by Jerry Schweitzer, who has built a number of Ford engines and flew behind the 4.2 in his RV4. He knows more about the engines than I do. The intake manifold needs some modification and the carburator should have the McNeilly leaning block installed so you can lean out the mixture as you climb. Some guys use the original fuel injection and electronic ignition. No one engine is modified in the same manner, it's part of the problem of knowing what to do. One thing that is or should be common is safety wiring all external and some internal bolts so that they cannot back out. Not everyone does this. Corky Scott |
"Dave Driscoll" wrote in message ...
(snipped) Corky, I'm pretty sure I've read the article that you are describing in the past and absolutely agree that testing in the automotive world is quite severe. (snipped) Given that the original poster in this thread was asking about the converting an automotive diesel its perhaps appropriate to examine the modifications that were made to the Thielert Centurion. (snipped) Personally, potential commercial competition aside, I'd love to see the original poster successfully convert a 10 cylinder VW diesel for aviation. I think it would be a really cool project. I'd also do my best as a citizen of the homebuilding community to help him do it safely and successfully. That said, I've been down the path you're on regarding your static test installation. If you're interested, shoot me your e-mail with your number, I think I can save you some grief on that project. Dave Driscoll DeltaHawk Engines LLC ------------------------------------------------------------------------------ Truer words were never spoken. This is an admirable attitude that all manufacturers should adopt. Thank you Mr. Driscoll. If it were not for the cost, the DeltaHawk engine would be my first choice too. With its increased ground clearance, inverted in a Cozy MK-IV, it would be the ideal engine. Its price, however, even though justified, compared to Lycoming and Continetal offerings, would represent half a year's income for me, making it esentially unreachable. As potential alternatives I regard the new common-rail, double or variable geometry turbo-diesels that have recently appeared on the world market. The Isuzu 3.0 liter V6 176 HP, the Ford-Jaguar-Peugeot 2.7 liter V6 207 HP and weighing 202 kg, the VW 2.5 or 3.0 liters V6 TDI 180 - 225 HP 220 kg diesels would all be viable options with their HP to weight ratio of 1/1. Just a quick search on mobile.de for low-mileage, intact motor, accident total write-offs yields several potential donor vehicles for under EUR 5.000. You buy the donor vehicle, remove engine and electronics and sell off the rest to recover some of the initial cost. The cost of the engine alone would be one to two thousand EUR. Then of course, as others in this thread have mentioned, comes the hard part. The Isuzu 3.0 liters V6 with its 177 HP would definitely require a redrive, the Jaguar with its 207 HP and the VW 3.0 liters V6 with its 225 HP and massive torque maybe not. "Die Qual der Wahl". The good thing is that since the airframe won't be ready for another 2-3 years, by that time there will be a reliable track record for these engines. After configuring the engine package there comes the testing. I would never fly behind (er... I mean in front) of an untested junker engine. My test-bed for the next one hundred or more hours, with diligent collection of all pertinent data on my laptop, would be a bayou style air-boat, built on the basis of my little catamaran. If the engine plus redrive plus propeller package survives this ordeal, then it's time for taxiing, eventually flying. Useful links: 1) Isuzu 3.0 liters V6: http://www.isuzu.co.jp/world/corpora...ne/lineup.html 2) Ford-Jaguar-Peugeot 2.7 liters V6: http://www.histomobile.com/histomob/tech/2/112.htm 3) VW Audi 2.5 - 3.0 liters V6 TDI: english: http://www.auto123.com/en/info/news/...tid=22231&pg=5 german: http://www.auto-motor-und-sport.de/d/48696 4) And because these are really "schöne Motoren": http://homepage.ruhr-uni-bochum.de/r...r/motoren.shtm Thank you for reading my ramblings. Kumaros It's all Greek to me |
Car engine FAA certified for airplane use | Cy Galley | Home Built | 10 | February 6th 04 03:03 PM |
Objective Engine Discussion | Rick Maddy | Home Built | 26 | October 14th 03 04:46 AM |
Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 04:29 AM |
Gasflow of VW engine | Veeduber | Home Built | 4 | July 14th 03 08:06 AM |
