![]() But for sure I lost 2000' (I couldn't believe it when I looked at the altimeter after recovering the plane... [...] I don't know whether this was "severe turbulence" according to the definition. [...] I did keep the plane under control - my main concern being to avoid hitting Vne. Unless you intended to lose 2000 feet, I'd say the plane was not under control. The wings may have been level, but two thousand uncommanded feet of altitude loss qualifies to me as severe turbulence. And whether it was smooth or not is irrelevant - bumpy air is "chop", altitude deviations are "turbulence". Sort of. Jose -- (for Email, make the obvious changes in my address) |
Well, I was about to start descending, and it was quite handy to lose
2000', but I certainly wasn't planning to lose it THAT quickly! In any case I reported it as severe turbulence at the time. I forgot to mention that I had a 25kt tailwind - nothing remarkable - at 9500'. It sped up to 40kt or so over the ridge, I was briefly showing ground speed over 200kt. John "Teacherjh" wrote in message ... But for sure I lost 2000' (I couldn't believe it when I looked at the altimeter after recovering the plane... [...] I don't know whether this was "severe turbulence" according to the definition. [...] I did keep the plane under control - my main concern being to avoid hitting Vne. Unless you intended to lose 2000 feet, I'd say the plane was not under control. The wings may have been level, but two thousand uncommanded feet of altitude loss qualifies to me as severe turbulence. And whether it was smooth or not is irrelevant - bumpy air is "chop", altitude deviations are "turbulence". Sort of. Jose -- (for Email, make the obvious changes in my address) |
Smooth air does not consitute turbulence, nor does an altitude
excursion in smooth air. Mountain wave often causes uncommanded altitude excursions of substantial magnitude but the air is absolutely smooth. That is not turbulence. The airplane is under control, it is just in an air mass that is rising or descending faster than the airplane has the performance to overcome. In general turbulence is defined as the force you feel as you are thrown against the seat belt. So, it isn't even light until you are being tossed against the belt. Severe is where control of the airplane is in doubt and there may well be some question as to whether the airplane will hold together. It is truly no fun at all when you get into a condition where you cannot cause the airplane to return to wings level flight due to the frequency and violence of the displacements that are occurring. You also may face the risk of being rendered unconscious due to striking the ceiling of the cabin. Fortunately, it is rare. If I recall correctly, a severe turbulence encounter in a transport category aircraft requires a full airframe inspection. It's a good idea in an FAR 23/CAR 3 airplane as well as a good friend bent the wings of his Meridian last summer while avoiding thunderstorms when he encountered severe turbulence. All the best, Rick (Teacherjh) wrote in message ... But for sure I lost 2000' (I couldn't believe it when I looked at the altimeter after recovering the plane... [...] I don't know whether this was "severe turbulence" according to the definition. [...] I did keep the plane under control - my main concern being to avoid hitting Vne. Unless you intended to lose 2000 feet, I'd say the plane was not under control. The wings may have been level, but two thousand uncommanded feet of altitude loss qualifies to me as severe turbulence. And whether it was smooth or not is irrelevant - bumpy air is "chop", altitude deviations are "turbulence". Sort of. Jose |
Common Myths About the Purple Heart Medal | Otis Willie | Military Aviation | 0 | August 25th 04 08:40 PM |
OT but good..the death of Mr Common | BllFs6 | Home Built | 0 | August 25th 04 03:01 AM |
My First Time In Severe Turbulence (Long) | David B. Cole | Instrument Flight Rules | 6 | March 10th 04 10:21 PM |
Wake turbulence avoidance and ATC | Peter R. | Piloting | 24 | December 20th 03 11:40 AM |
How much turbulence is too much? | Marty Ross | Instrument Flight Rules | 8 | August 21st 03 05:30 PM |
