Leaving all engines running at the gate
Old February 4th 04, 02:09 PM
aptim
"John" wrote in message
snowy squirrel wrote:
John wrote:
Recently at SJU I saw an IB A340-600 arrive from Madrid that left all
four engines running during the 2 hours that it was at the gate before
continuing to Santo Domingo.
If you could see the engines turning, it means that they were shut off
and
just slowly turning due to wind.
It would be very hard for maintenance personel to get near the aircraft
with
all 4 engines running. And I suspect extremely hazardous (if not illegal)
to
refuel while engines are running.
It is far more likely that what you saw were just engines turning slowly
due
to wind.
There are situations where engines on one side are left running in
extreme
cold arctic conditions, and all passenger, cargo, fuel is handled from
other side. This is to ensure that at least one engine is available to
generate sufficient power to restart the second engine.
Nope, those four fans were running at a pretty good clip. No wind
involved there. Besides, with the size of those things, it would take
a hurricane to keep them turning for two hours.
Was the rotating beacon on? If not the engines were most likely
windmilling.
It would be to dangerous to leave one engine running at the gate. Let
alone four. Too many people and equipment in the area. Turbo fan engines
have a tendency of sucking anything that gets to close. Paper or a plastic
bag or plastic wrap that is use to wrap cargo. That's including people
too. There is just to much crape around the gate just waiting to get suck
in. It doesn't take much to damage one of those fan blades. At 20-30,000
dollars per fan blade (For a RB-211. American Airlines 757 ). I don't
think they will leave them running unless they want to be changing fan
blades more often on the A340.
aptim A&P
Old February 5th 04, 03:46 AM
Capt.Doug
"John" wrote in message Nope, those four fans were running at a pretty
good clip. No wind
Iberia usually parks at gate 27 where the prevailing wind blows up the
tailpipes. A 4 knot wind is sufficient for spinning a fan disk. If you could
see the blades, the engines weren't running.
D.
Old February 4th 04, 02:29 AM
Robert M. Gary
The fans you saw were probably being turned by the wind. The noise you
heard was probably the APU running in the back. Its not unusual for a
plane to sit at the gate with the APU running in the tail of the
plane. Its a jet too and sounds like one.
John wrote in message . ..
continuing to Santo Domingo. After all the passengers got off the
entire crew, both cabin AND cockpit crew got off and went to the
transit lounge for about an hour before returning to board for the SDQ
leg. All this time the engines were left running. In fact, they
never stopped running the whole time they were at SJU. I have never
seen an airliner do this before and was wondering if something was
wrong with this particular aircraft or if this is some kind of new
"windmilling" feature on the new A346 or something. Perhaps related,
I've heard that IB have had a horrible experience with their new A346s
and this particular aircraft, EC-INO (Gaudi), the first one they
received, is said to have given then more headaches than all the
others.
What circumcstances would make an airline leave a plane guzzling gas
for such a long time on the ground?
NS Norfolk Gate 2 NATOPS - All Hands Memorize Immediately! Yofuri Naval Aviation 0 December 17th 04 05:38 AM
Book Review: Converting Auto Engines for Experimental Aircraft , Finch Paul Home Built 0 October 18th 04 10:14 PM
P-3C Ditches with Four Engines Out, All Survive! Scet Military Aviation 6 September 27th 04 01:09 AM
Report Leaving Assigned Altitude? John Clonts Instrument Flight Rules 81 March 20th 04 02:34 PM
What if the germans... Charles Gray Military Aviation 119 January 26th 04 11:20 PM
