Simulated Engine Outs
Old February 14th 04, 06:51 PM
Andrew Sarangan
You can simulate a engine out approach by adding just enough drag to
offset the engine rpm. In the Canadian PTS, this was specifically
mentioned as an acceptable practice. However, as others have pointed
out there is no clear evidence to support the shock cooling theory in
small aircraft. Some believe it exists, and some don't.
You have to do whatever you feel is necessary to safely simulate an
engine out approach. There is nothing wrong with leaving 1500 RPM and
using flaps. Even if you pull the power back completely, one can argue
that frequently clearing the engine unrealistically increases the
glide range. The effect of power on glide performance is not all that
different than the effects of wind. There are too many variables to
claim that one way is better than another. It all comes down to what
the pilot is comfortable with.
"BTIZ" wrote in message news:nl_Wb.15852$IF1.7345@fed1read01...
you don't get much of an "engine out" at 1500RPM
sort of builds a false sense of security of the seemingly good glide ratio
BT
"BoDEAN" wrote in message
In small high wing planes (Ie 172, 152, 150) do you do/teach pulling
throttle all the back to idel? I've been told bring it to 1500 RPM, 1
notch of flaps. Not as hard on the engine
ROP masking of engine problems Roger Long Owning 4 September 27th 04 07:36 PM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 06:42 PM
What if the germans... Charles Gray Military Aviation 119 January 26th 04 11:20 PM
Real stats on engine failures? Captain Wubba Piloting 127 December 8th 03 04:09 PM
