Tarver Engineering wrote:
"Peter" wrote in message news:0YUYb.349393$xy6.1743180@attbi_s02... Tarver Engineering wrote: "Peter" wrote in message news:ruUYb.349212$xy6.1742195@attbi_s02... Ron Lee wrote: "Dave" wrote: Unaugmented GPS is accurate to within 7.2 meters longitudinally. Go say that in sci.geo.satellite-nav and see what happens. Probably not a bad number. Only if the usual caveats are added; i.e. 95% of the time and assuming the receiver has good reception conditions. Any attorney trying to discredit GPS evidence will naturally focus on the 5% of the time when the position could be off by more than the nominal accuracy and on obstructions, multi-path reflections, RFI, etc. that can degrade performance, particularly in a covert installation where the antenna is unlikely to be optimally placed for good reception. False. The convergence of the GPS Jacobian does not occur for the conditions you describe. One of the major advantages of GPS over current ground based navigation is the difficulty of spoofing the system. I suggest you read your "GPS World" issues some more. Improvement of integrity monitoring was one of the main reasons for requiring augmentation of GPS. False. The failure to monitor the integrity of the WAAS signal is why the test bit remained set until recently. The integrity issues were WAAS integrity issues with no relevence to GPS. Unaugmented GPS has insufficient integrity monitoring. http://www.cts.cv.ic.ac.uk/html/Rese...p?seminarID=62 : "The assessment results also indicated that the current GPS system cannot meet the RNP in most of the cases and the current integrity monitoring mechanism is inadequate for providing the necessary integrity monitoring capability. Therefore, this study suggests that augmentation systems are needed to support the navigation function for all phases of flight." Jan. 28, 2004, Imperial College, London, Dr. Shaojun. Evidence already presented in this court case also indicates some of the problems cited above which resulted in momentary errors of miles rather than meters. A maomentary error with what equipment? Apparent position errors recorded by the monitoring equipment used in the investigation being discussed. I'm an advocate of GPS navigation but it is not infallible and carries no absolute 7 m accuracy guarantee. So far you are zero for two. The "Standard Positioning Service Performance Standard," Table 3.6 http://www.navcen.uscg.gov/gps/genin...ndardFINAL.pdf gives the post-SA specification for horizontal position as being within 13m 95% of the time assuming the receiver can see all signals from satellites above the horizon. The vertical spec. is 22m, 95% of the time. Actual performance has exceeded these specifications but AFAIK the specification has not been updated. Feel free to cite any GPS specification that guarantees 7 m accuracy 100% of the time regardless of reception conditions. |
On Thu, 19 Feb 2004 03:10:41 GMT, Peter wrote:
Unaugmented GPS has insufficient integrity monitoring. http://www.cts.cv.ic.ac.uk/html/Rese...p?seminarID=62 : "The assessment results also indicated that the current GPS system cannot meet the RNP in most of the cases and the current integrity monitoring mechanism is inadequate for providing the necessary integrity monitoring capability. Therefore, this study suggests that augmentation systems are needed to support the navigation function for all phases of flight." Jan. 28, 2004, Imperial College, London, Dr. Shaojun. I looked at the link you posted. It seems to be a summary of what is intended to be presented at a seminar, with no associated evidence. It is also not clear as to what Shaojun's definition of "inadequate" is. It is not clear to me what method of integrity monitoring is going on in the British airspace to which Shaojun refers, but it seems to be unaugmented RAIM. The summary indicates that his study "route" was London to New York. But my understanding is that trans-oceanic flights have to have multiple navigation systems, only one of which can be GPS. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
![]() "Ron Rosenfeld" wrote in message ... On Thu, 19 Feb 2004 03:10:41 GMT, Peter wrote: Unaugmented GPS has insufficient integrity monitoring. http://www.cts.cv.ic.ac.uk/html/Rese...ls.asp?seminar ID=62 : "The assessment results also indicated that the current GPS system cannot meet the RNP in most of the cases and the current integrity monitoring mechanism is inadequate for providing the necessary integrity monitoring capability. Therefore, this study suggests that augmentation systems are needed to support the navigation function for all phases of flight." Jan. 28, 2004, Imperial College, London, Dr. Shaojun. I looked at the link you posted. It seems to be a summary of what is intended to be presented at a seminar, with no associated evidence. It is also not clear as to what Shaojun's definition of "inadequate" is. What is clear is that Peter has a tad more ego than knowledge. |
![]() "Peter" wrote in message news:ROVYb.217372$U%5.1284734@attbi_s03... Tarver Engineering wrote: "Peter" wrote in message news:0YUYb.349393$xy6.1743180@attbi_s02... Tarver Engineering wrote: "Peter" wrote in message news:ruUYb.349212$xy6.1742195@attbi_s02... Ron Lee wrote: "Dave" wrote: Unaugmented GPS is accurate to within 7.2 meters longitudinally. Go say that in sci.geo.satellite-nav and see what happens. Probably not a bad number. Only if the usual caveats are added; i.e. 95% of the time and assuming the receiver has good reception conditions. Any attorney trying to discredit GPS evidence will naturally focus on the 5% of the time when the position could be off by more than the nominal accuracy and on obstructions, multi-path reflections, RFI, etc. that can degrade performance, particularly in a covert installation where the antenna is unlikely to be optimally placed for good reception. False. The convergence of the GPS Jacobian does not occur for the conditions you describe. One of the major advantages of GPS over current ground based navigation is the difficulty of spoofing the system. I suggest you read your "GPS World" issues some more. Improvement of integrity monitoring was one of the main reasons for requiring augmentation of GPS. False. The failure to monitor the integrity of the WAAS signal is why the test bit remained set until recently. The integrity issues were WAAS integrity issues with no relevence to GPS. Unaugmented GPS has insufficient integrity monitoring. See the CNX-80. Buy a vowel, get a clue, call your mommy. |
"Peter" wrote in message news:ROVYb.217372$U%5.1284734@attbi_s03... Tarver Engineering wrote: The failure to monitor the integrity of the WAAS signal is why the test bit remained set until recently. The integrity issues were WAAS integrity issues with no relevence to GPS. Unaugmented GPS has insufficient integrity monitoring. See the CNX-80. Buy a vowel, get a clue, call your mommy. http://www.avionicsplace.com/ApolloCNX80.htm : "The FAA’s new Wide Area Augmentation System or WAAS dramatically improves the accuracy, integrity, and availability of GPS. The CNX80 incorporates a new 15-channel WAAS receiver designed by UPS Aviation Technologies specifically for airborne applications." |
![]() "Peter" wrote in message news:305Zb.345746$I06.3635492@attbi_s01... Tarver Engineering wrote: "Peter" wrote in message news:ROVYb.217372$U%5.1284734@attbi_s03... Tarver Engineering wrote: The failure to monitor the integrity of the WAAS signal is why the test bit remained set until recently. The integrity issues were WAAS integrity issues with no relevence to GPS. Unaugmented GPS has insufficient integrity monitoring. See the CNX-80. Buy a vowel, get a clue, call your mommy. http://www.avionicsplace.com/ApolloCNX80.htm : "The FAA’s new Wide Area Augmentation System or WAAS dramatically improves the accuracy, integrity, and availability of GPS. Nope, but a salseman needs to sell. If you look at the difference in minimums for the VNAV, you will note that WAAS gives the operator little to nothing in increased capabilities. WAAS was a scam run on aviation to remove tens of $billions from the aviation trust fund; from that perspective WAAS is a tremendous success. WAAS is the reason sci.geo.satellite-nav is a discredited and dishonest newsgroup. Ron Lee being a possible exception. |
Stupid Americans! -- Stupid... Stupid... STUPID!!! __________-+__ ihuvpe | Chris | Instrument Flight Rules | 43 | December 19th 04 09:40 PM |
Stupid Americans! -- Stupid... Stupid... STUPID!!! _____________---_ unakm | Aardvark J. Bandersnatch, MP | General Aviation | 2 | December 17th 04 11:37 PM |
Stupid Americans! -- Stupid... Stupid... STUPID!!! __________==___ gitqexec | OtisWinslow | Owning | 9 | November 12th 04 06:34 PM |
Stupid Americans! -- Stupid... Stupid... STUPID!!! _____________ efamf | Keith Willshaw | Naval Aviation | 4 | November 11th 04 01:51 AM |
Stupid Americans! -- Stupid... Stupid... STUPID!!! __________-+__ihuvpe | john smith | Instrument Flight Rules | 1 | November 9th 04 03:50 AM |
