rope "gives" when jerked... chains don't give..
a little slack in chains can cause the wing to jerk when the chain looses the slack which can damage where the tie down attaches to the wing ropes give a little, like a bungee hitting the limit.. depending on how the tie down is attached to the wing.. don't trust Cessna slots that slip into the strut and hide when flying.. BT "Roger Bartholomee" wrote in message ... I just read the AOPA ePilot Flight Training Edition -- Vol. 4, Issue 4 from January and under Training Tips and they reference "The Tiedowns that Bind" from the October 2000 AOPA Flight Training. See: http://www.aopa.org/members/ftmag/ar...m?article=3811 The author says "It's important to leave a little slack in each line, especially if you are expecting gusty wind conditions. Slack will allow the airplane to move a little. Without any slack, a strong gust could damage the airframe." I have always kept mine tight so the plane can't move around. My feeling is the slack will allow the plane to move and then jerk to a stop. Does anyone know the proper method and the reason? Roger @ MD43 C150E |
BTIZ wrote:
. don't trust Cessna slots that slip into the strut and hide when flying.. Why? Have there been owners you know who experienced failures of these types of slots? -- Peter ----== Posted via Newsfeed.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeed.com The #1 Newsgroup Service in the World! 100,000 Newsgroups ---= 19 East/West-Coast Specialized Servers - Total Privacy via Encryption =--- |
Lets just say I've seen more than one Cessna flipped onto its back when tie
downs failed in high winds.. But Pipers seem to stay upright. 3 of the 5 I recall right now had at least one wing tie down fail, and they were the type that are spring loaded and slip into the wing strut like the C-177 type. It is recommended by many, that when high winds are expected, to bring the rope up over the strut, around and through the tie down eye, back around the top of the strut again and the tie the rope with proper "truckers hitch" or hurricane hitches. Continue the free end down the rope and secure it to prevent it from flailing against the aircraft. BT "Peter R." wrote in message ... BTIZ wrote: . don't trust Cessna slots that slip into the strut and hide when flying.. Why? Have there been owners you know who experienced failures of these types of slots? -- Peter ----== Posted via Newsfeed.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeed.com The #1 Newsgroup Service in the World! 100,000 Newsgroups ---= 19 East/West-Coast Specialized Servers - Total Privacy via Encryption =--- |
BTIZ wrote:
Lets just say I've seen more than one Cessna flipped onto its back when tie downs failed in high winds.. But Pipers seem to stay upright. I wondered about this. I found that taxing a low wing is much easier to handle in high winds situation. Is it because the CG is lower to the ground? After all, the weight of the fuel is lower to the ground over the wheels, thus harder to tip over? Allen |
Allen
Lets just say I've seen more than one Cessna flipped onto its back when tie downs failed in high winds.. But Pipers seem to stay upright. I wondered about this. I found that taxing a low wing is much easier to handle in high winds situation. Is it because the CG is lower to the ground? After all, the weight of the fuel is lower to the ground over the wheels, thus harder to tip over? A little too simplified. Low wing airplanes get blown over in high winds as do high wing airplanes. Dihedral, direction and force of the wing, width of the landing gear all play a role. When taxiing, holding appropriate aileron and elevator deflection makes a big difference. Doing it wrong on an extremely windy or gusty day, combined with misue of the brakes which gets the airplane rocking, can ruin things for you in almost any light airplane. All the best, Rick |
Plus the wind is less the closerit is to the ground because of friction.
Roger @ MD43 C150E "Rick Durden" wrote in message m... Allen Lets just say I've seen more than one Cessna flipped onto its back when tie downs failed in high winds.. But Pipers seem to stay upright. I wondered about this. I found that taxing a low wing is much easier to handle in high winds situation. Is it because the CG is lower to the ground? After all, the weight of the fuel is lower to the ground over the wheels, thus harder to tip over? A little too simplified. Low wing airplanes get blown over in high winds as do high wing airplanes. Dihedral, direction and force of the wing, width of the landing gear all play a role. When taxiing, holding appropriate aileron and elevator deflection makes a big difference. Doing it wrong on an extremely windy or gusty day, combined with misue of the brakes which gets the airplane rocking, can ruin things for you in almost any light airplane. All the best, Rick |
I agree. Low wings ought to be taxed out of existence.
{;-) Jim (manly high winger) that's MANLY, not mainly. - Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
A Lieberman wrote in message ...
I found that taxing a low wing is much easier to handle in high winds situation. Is it because the CG is lower to the ground? After all, the weight of the fuel is lower to the ground over the wheels, thus harder to tip over? Lower CG is part of it. The weight of not only the fuel, but the wing spar and internal structure significantly contributes to the lower CG. The other part is that the gear stance is usually wider on a low wing, since it is often attached to the wing spar instead of the fuselage. The triangle formed by the nose, left and right wheel is wider and less prone to tip to one side or the other. John Galban=====N4BQ (PA28-180) |
![]() "John Galban" wrote in message om... A Lieberman wrote in message ... I found that taxing a low wing is much easier to handle in high winds situation. Is it because the CG is lower to the ground? After all, the weight of the fuel is lower to the ground over the wheels, thus harder to tip over? Lower CG is part of it. The weight of not only the fuel, but the wing spar and internal structure significantly contributes to the lower CG. The other part is that the gear stance is usually wider on a low wing, since it is often attached to the wing spar instead of the fuselage. The triangle formed by the nose, left and right wheel is wider and less prone to tip to one side or the other. For a low center of gravity, consider the Rockwell JetProp (now Twin Commander) when the bottom of the fusalage is only nine inches off the pavement. This can make the body act like an air dam for crosswind taxiing. |
Although all planes differ, the general answer is... yes.
Lot of factors here, but the wing being lower, helps..center of gravity is lower, and the main gear stance is wider , not being confined to mounting on the fuselage. I remember a landing a Comanche in a X-wind..(no cross rny- BTW, landings are mandatory) that would have sent our Cessna end over end. 3rd attempt, right foot in the firewall.. I would have been plain dumb to try this with a 182.. I have some time on a Warrior, - short, sturdy wide spaced gear.. Worked well in x-winds, but the rudder on the Comanche seemed to be more effective in the slip... Cheers! Dave on the On Sat, 21 Feb 2004 07:51:29 -0800, A Lieberman wrote: BTIZ wrote: Lets just say I've seen more than one Cessna flipped onto its back when tie downs failed in high winds.. But Pipers seem to stay upright. I wondered about this. I found that taxing a low wing is much easier to handle in high winds situation. Is it because the CG is lower to the ground? After all, the weight of the fuel is lower to the ground over the wheels, thus harder to tip over? Allen |
Flight training recommendations for Dubai | Roland | General Aviation | 0 | August 9th 04 01:25 PM |
Sim time loggable? | [email protected] | Instrument Flight Rules | 12 | December 6th 03 07:47 AM |
new AOPA flight planner? | aaronw | Piloting | 18 | November 7th 03 09:46 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
