KJKimball wrote:
Corky ad Richard, I have experience with this double covering method. I have done it a few times. It does not match the polyfiber manual but it worked very well on high power and acro airplanes. Feel free to email me directly if you would like more info on how it is done. If you look at the cover of the new June Issue of Kitplanes, 2 of the 4 model 12s on the cover are finished in this method. Kevin Kimball Thanks Kevin. Were we even close? Richard |
Any idea of what the weight penalty would be in dope and fabric vs. reduced
drag? And is this method more or less expensive than pinked tape? Just wondering, Harry Shellac dope would have added 76 lbs. to the weight of a Wright 1902 glider, and almost 155lbs. to the 1903 "Flyer." ...Based on tests made with my 1899 kite, August 2001 |
Corky, Richard and Harry,
Corky was pretty close to having the method down that we used. I have heard of those who have used polybrush for the bonding of the 2 layers. We don't. The example of the tri pacer mentioned is interesting in that if the airplane is still in standard catagory, the recoverer must have gotten a special field approval for using the method. We have not used it on certified airplanes. Only experimental. Jim Younkin did use the double cover method on 3 staggerwings he converted from D models to G models a few years ago. He got the covering included in the long list of field approvals for those 3 airplanes only. No STC for it. Double cover is not standard on staggerwings from the factory. The double covering we have done is based on the techniques used on these 3 airplanes. We made some changes in how the coatings are applied and have had great luck thus far. I would be more than happy to discuss the way we have done it with you directly. It is a bit too invloved to fully list here. If you are wanting a bare minumum finish and gloss or slickness is not important, don't double cover. If you have a low powered non acro airplane, don't use this method. This is a method that is not only intended for a slick finish but is more valuable as a tougher, stiffer, higher durability system for big engines, big props, and hard acro. The Staggerwing and pitts model 12 are good examples of airplanes that can benefit from such a covering system. It is not approved of by Polyfiber nor is covering wings and not using some form of mechanical fastener like stitches or screws. There are airplanes out there that simply glue the fabric to the ribs and have success because of the type of airplane it is ad the design of the structure. Double covering is not the norm but rather is a special use fix for a problem of losing tapes in the prop wash on big engine acro airplanes. The weight difference is always a question. I can only give example from the airplanes we have done which are pitts model 12s, 4 of them and the McCullocoupe. We have a standard finish we like to see which is good enough to place well at flyins. We use urethane top coat colors on all the airplanes we build. So, if we want the same finish on a model 12, we have to fill the 3.4oz heavy duty fabric with a few additional coats of polyspray, sand more, and possibly sand the color to get a satisfactory gloss out of the course fabric. This is by no menas a bury the tapes finish. The tapes will still be fully proud above the base fabric. Still, with all that effort, the weave is still strong through the paint and we have to use 4" tapes on the ribs to keep them from blowing off the wings. When we double cover, we end up with no tapes to blow off, 5.1 oz per square yard of fabric weight, a fine weave fabric to fill that takes far less coatings to do so and a finished fabric/coatings weight that is within 1 or 2 pounds of single cover on a model 12. A model 12 and a staggerwing have ribs that are very close together. When you use 4" wide tapes over the ribs, you have double covered the wing 70-80% with just very small strips of base fabric being exposed. The process is not for the first time cover job. You need to know your way around the fabric system before trying it. We advise our builders to go the standard way unless they have experience and are willing to go it alone without tech support from the covering supplier. Labor time is about equal to the standard method. Base fabric install is the same labor either way. Second layer can tape more time than taping would. But, sanding is faster. In terms of material cost, you can price 3.4 oz and 1.7 oz fabric for the size airplane you are covering. Then price tapes. Coatings cost will be basically the same. Kevin |
Fabric repair | D.A.L | Home Built | 0 | April 27th 04 07:17 PM |
Replace fabric with glass | Ernest Christley | Home Built | 38 | April 17th 04 11:37 AM |
Questions on covering | Ed | Home Built | 3 | March 16th 04 06:18 PM |
Fabric covering processes | Jerry Guy | Home Built | 2 | January 29th 04 06:49 PM |
Fabric Covered Dreams | Jim Austin | Home Built | 4 | August 13th 03 03:32 PM |
