In a previous article, Andrew Gideon said:
I've been reading the POH for my club's 182RG, and I find myself surprised. The manual gear extension replies upon the same hydrolic pressure system as the powered mechanism. Isn't that insufficiently redundant? The P32R Lance that I'm currently checking out in uses hydraulic pressure to hold the gear *up* against springs and gravity - lose the hydraulic pressure and the gear goes down. As a matter of fact, sometimes in turbulence you get a gear unsafe light and you have to quickly cycle the gear lever to repressurize the hydraulics. -- Paul Tomblin http://xcski.com/blogs/pt/ "Maybe if your vcr is still blinking 12:00 you shouldn't be using Linux." -- Slashdot poster |
Piper gear PIREP
The nose gear on the Seminole and many other similar Pipers has a coaxial pair of springs. In my case the inner spring failed, jamming the outer spring and resulting in a nose idiot light not coming on. Expecting a collapse, I landed the Seminole like a tail dragger and walked away. The springs are a few dollars. Replace them periodically. My Seminole was on leaseback, I was scheduled between two renters. Better me than them. Old pilots have paid attention to detail. So said one. Blue skies. H. "Paul Tomblin" wrote in message ... In a previous article, Andrew Gideon said: I've been reading the POH for my club's 182RG, and I find myself surprised. The manual gear extension replies upon the same hydrolic pressure system as the powered mechanism. Isn't that insufficiently redundant? The P32R Lance that I'm currently checking out in uses hydraulic pressure to hold the gear *up* against springs and gravity - lose the hydraulic pressure and the gear goes down. As a matter of fact, sometimes in turbulence you get a gear unsafe light and you have to quickly cycle the gear lever to repressurize the hydraulics. -- Paul Tomblin http://xcski.com/blogs/pt/ "Maybe if your vcr is still blinking 12:00 you shouldn't be using Linux." -- Slashdot poster |
(Paul Tomblin) writes:
The P32R Lance that I'm currently checking out in uses hydraulic pressure to hold the gear *up* against springs and gravity - lose the hydraulic pressure and the gear goes down. Cool! So if you lose your engine the plane helps you get back to the ground quickly by extending the air brakes? Is there an override (for those who fly over inhospitable terrain/water)? Is there a placard that says "Do not lose engine power in excess of max. gear extension speed."? --kyler |
"Kyler Laird" wrote in message
... (Paul Tomblin) writes: The P32R Lance that I'm currently checking out in uses hydraulic pressure to hold the gear *up* against springs and gravity - lose the hydraulic pressure and the gear goes down. Cool! So if you lose your engine the plane helps you get back to the ground quickly by extending the air brakes? Is there an override (for those who fly over inhospitable terrain/water)? The hydraulic pressure is probably provided by an electric pump (I don't know for sure, not being familiar with that specific airplane). Furthermore, loss of pressure should only happen if there's a leak in the system somewhere; theoretically, once the system has pressurized with the gear up, the hydraulic pump wouldn't need to operate at all. Even if there was a slightly leaky o-ring or valve somewhere, requiring the occasional operation of the pump, it seems likely that the battery could handle the load for the brief period of time it would take to glide to a landing. Bottom line: there's no reason an engine failure would cause the gear to extend. Is there a placard that says "Do not lose engine power in excess of max. gear extension speed."? There would be no need for such a placard. Pete |
Peter,
You have got to expand your horizons g. In a number of the Piper singles the gear does come down if the engine takes the day off. The automatic extension system, if not disconnected or overridden, will extend the gear if the engine quits. It's why I override the system on takeoff as I have no burning desire for the gear to extend should the engine quit. It's also a fun system when you are descending at high speed through a layer of stratus clouds full of rime ice and the pitot heat decides that it doesn't want to heat the little pitot tube on the left side of the fuselage that provides the input for the automatic gear system, it freezes up and extends the gear suddenly when you are whistling along in the yellow arc. Doesn't do anything to improve your outlook on life at all. All the best, Rick "Peter Duniho" wrote in message ... "Kyler Laird" wrote in message ... (Paul Tomblin) writes: The P32R Lance that I'm currently checking out in uses hydraulic pressure to hold the gear *up* against springs and gravity - lose the hydraulic pressure and the gear goes down. Cool! So if you lose your engine the plane helps you get back to the ground quickly by extending the air brakes? Is there an override (for those who fly over inhospitable terrain/water)? The hydraulic pressure is probably provided by an electric pump (I don't know for sure, not being familiar with that specific airplane). Furthermore, loss of pressure should only happen if there's a leak in the system somewhere; theoretically, once the system has pressurized with the gear up, the hydraulic pump wouldn't need to operate at all. Even if there was a slightly leaky o-ring or valve somewhere, requiring the occasional operation of the pump, it seems likely that the battery could handle the load for the brief period of time it would take to glide to a landing. Bottom line: there's no reason an engine failure would cause the gear to extend. Is there a placard that says "Do not lose engine power in excess of max. gear extension speed."? There would be no need for such a placard. Pete |
"Rick Durden" wrote in message
m... You have got to expand your horizons g. That's always been true. In a number of the Piper singles the gear does come down if the engine takes the day off. But not because of the failure of the hydraulic system. Kyler's comment clearly was based on an assumption that without engine power, there would be no hydraulic pressure, and that without pressure, the gear would drop (the first assumption being the incorrect one, but the second is incorrect in other airplanes as well). And actually, while I haven't flown the Pipers you're referring to, my understanding is that the gear extension was based on airspeed, not engine power. Your comment about the behavior of such systems in icing conditions would seem to reinforce this understanding. Perhaps you could elaborate on why it is you say that engine failure alone will result in the gear extending. Or perhaps you meant that the drop in airspeed that normally results after an engine failure (to achieve best glide) is enough to cause the gear to extend. In which case I'd argue that it wasn't the engine failure, but the airspeed change that caused the gear to extend (I'd also wonder why the system was designed such that the activation airspeed was at or above best glide...seems pretty non-optimal to me). Pete |
snip
Safety features sometimes spawn new hazards while eliminating old ones. The automatic gear extension system is a good example. "At high density altitudes," relates one owner, "the gear sometimes drops after it has been retracted. This, of course, nullifies any climb!" Indeed, there have been incidents in which the airplane might have been able to climb out safely had the gear not dropped at the wrong moment, causing a stall/mush into the terrain. Then there are Arrow pilots who lose their engines and decide to ditch with the gear up. Unfortunately, some forget to override the automatic extension system. The gear plops out seconds before splash down-sending the Arrow head over heels. Such mishaps are rare-we only counted a few (none fatal) in our five-year survey. But in mid-1987 Piper, then owned by Lear-Siegler, ordered the system deactivated because of concern over liability suits. It sold kits to do so, and told customers it wouldn't provide parts to repair the existing system. Piper sold 1,400 kits. One year later, Piper-then owned by M. Stuart Millar-withdrew its order to deactivate the automatic extension system, provided that pilots "take the necessary actions to assure that any pilot flying these aircraft are fully advised of the system and its proper operation." In part, Piper was responding to the complaints of irate owners who believed the system worked often enough to be desirable. snip *************************************** Throttle coming back to a certain point actuates a microswitch and/or the airspeed dropping to 95 knots drops the gear... There was an override, but you had to remember to actuate it... Every Arrow that I was involved with had the autoextension deactivated, period... Can't have the airplane killing me, I can do a fine job of that all on my own... denny |
In a previous article, "Dennis O'Connor" said:
Then there are Arrow pilots who lose their engines and decide to ditch with the gear up. Unfortunately, some forget to override the automatic extension system. The gear plops out seconds before splash down-sending the Arrow head over heels. First item in the emergency checklist is to put the gear override on. -- Paul Tomblin http://xcski.com/blogs/pt/ Microsoft - Where quality is job 1.0.1 |
In a previous article, "Peter Duniho" said:
And actually, while I haven't flown the Pipers you're referring to, my understanding is that the gear extension was based on airspeed, not engine power. Your comment about the behavior of such systems in icing conditions The POH for the Lance isn't 100% clear on this, but my understanding is that with the emergency gear extension, the gear will come down if you go below a certain manifold pressure at one speed, or will come down regardless of the manifold pressure at a lower speed. The POH says "Some aircraft also incorporate a pressure sensing device in the system which lowers the gear regardless of gear selector position, depending upon airspeed and engine power (propellor slipstream). Gear extension is designed to occur, even if the selector is in the up position, at airspeeds below approximately 103 KIAS with power off. The extension speeds will vary from approximately 91 kts to approximately 103 KIAS depending on power settings and altitude." Actually, reading that again, it's possible that what is happening isn't that it comes on at a lower speed if you have power on, but that the propellor slipstream holds the gear up against the springs if you have power on. Sometimes I learn more answering other people's questions than I do getting answers to my own. -- Paul Tomblin http://xcski.com/blogs/pt/ If you're not part of the solution, you're part of the precipitate. |
... The POH for the Lance isn't 100% clear on this, but my understanding is that with the emergency gear extension, the gear will come down if you go below a certain manifold pressure at one speed, or will come down regardless of the manifold pressure at a lower speed. Well, if it's manifold pressure based, then an engine failure would only cause the gear to come down if the failure was caused by a blocked air intake, or if the pilot later pulled the throttle to idle. Again, an engine failure would not, in and of itself, necessarily cause the gear to extend. [...] Actually, reading that again, it's possible that what is happening isn't that it comes on at a lower speed if you have power on, but that the propellor slipstream holds the gear up against the springs if you have power on. I don't know how the "propeller slipstream" could hold the gear up. The only "propeller slipstream" I'm aware of is the helical movement of the air around the fuselage, and compared to the other forces involved I doubt it's all that strong. I think it's interesting that the POH puts "propeller slipstream" in parentheses after "engine power", because to me it's not at all clear what they mean. The two aren't exactly equivalent, so it's odd they would use them as if they were. The parenthetical comment ought to add information, but to me it just confuses things. Pete |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 1 | November 24th 03 02:46 PM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 2 | November 24th 03 05:23 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 0 | November 24th 03 03:52 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart D. Hull | Home Built | 0 | November 22nd 03 06:24 AM |
Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance | [email protected] | Owning | 5 | July 22nd 03 12:35 AM |
