"C J Campbell" wrote in message
... Hydraulic pressure is used to hold the gear up. The pump runs every few minutes to maintain hydraulic pressure. Assuming the 172RG gear system is similar to the 182RG and 177RG systems, if the pump is running on a regular basis, you have a leak somewhere. Not necessarily one venting fluid, but one allowing fluid from the pressurized side of the system to the non-pressurized side. (The pressurized side changes, of course, depending on whether you're raising or lowering the gear) The manual system is just another pump, only it is only capable of lowering the gear. If you lose hydraulic pressure the manual system will provide enough pressure to lower the gear and lock it in place if there is any fluid in the system at all. You would have to spring a leak at the bottom of the sump to lose all your hydraulic fluid. A leak on the pressurized side of the system would allow the hand-pump (or the electric pump) to pump all the fluid out of the system. You don't need to spring a leak at the bottom of the sump to lose all your fluid. [...] The landing gear system is not all that critical anyway. If more redundancy is required, the weight penalty is better applied to other systems. True without a doubt! Pete |
![]() "Peter Duniho" wrote in message ... A leak on the pressurized side of the system would allow the hand-pump (or the electric pump) to pump all the fluid out of the system. You don't need to spring a leak at the bottom of the sump to lose all your fluid. It actually does not pump it all out, as the intake for the pump is high enough to leave a small reservoir to be used by the emergency extension lever. |
... It actually does not pump it all out, as the intake for the pump is high enough to leave a small reservoir to be used by the emergency extension lever. Fine. However, as soon as you start using the manual pump, you will still wind up pumping the fluid out. My main point is that it is not necessary to have a leak at the bottom of the sump in order to lose all the hydraulic fluid. Pete |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 1 | November 24th 03 02:46 PM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 2 | November 24th 03 05:23 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 0 | November 24th 03 03:52 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart D. Hull | Home Built | 0 | November 22nd 03 06:24 AM |
Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance | [email protected] | Owning | 5 | July 22nd 03 12:35 AM |
