Mark Hickey wrote:
"Yosimite Sam" wrote: I have an acquaintance with a 582 powered kitfox that had this same problem...It turned out that the prop was very slightly changing pitch....I remember it took a lot of time before this was found out. There was wear in the hub area. It was fixed by adding a shim. It seems like (I'm trying to remember here) the prop hub was slightly distorted where it clamped together. It seems to me that the prop would be much more likely to go to a flatter pitch and produce MORE RPM if the blade(s) slipped. Am I missing something? Mark Hickey I guess it would depend on the rigidity of the blade and where it wants to twist. A cambered airfoil should produce a pitching moment in such a way as to reduce the angle of attack. BTW: I did try the WarpDrive prop and the problem went away. I then put the original prop back on to make sure that was indeed the cause, and was unable to reproduce the problem anymore. So I don't know what's going on at this point. :P |
Rotax 503 won't stop running | Tracy | Home Built | 2 | March 28th 04 04:56 PM |
Car engine FAA certified for airplane use | Cy Galley | Home Built | 10 | February 6th 04 03:03 PM |
Objective Engine Discussion | Rick Maddy | Home Built | 26 | October 14th 03 04:46 AM |
Using 100LL in a Rotax 912 Engine | Yosimite Sam | Home Built | 3 | August 16th 03 04:00 PM |
Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 04:29 AM |
