![]() "Peter Duniho" wrote in message ... A leak on the pressurized side of the system would allow the hand-pump (or the electric pump) to pump all the fluid out of the system. You don't need to spring a leak at the bottom of the sump to lose all your fluid. It actually does not pump it all out, as the intake for the pump is high enough to leave a small reservoir to be used by the emergency extension lever. |
"C J Campbell" wrote in message
... It actually does not pump it all out, as the intake for the pump is high enough to leave a small reservoir to be used by the emergency extension lever. Fine. However, as soon as you start using the manual pump, you will still wind up pumping the fluid out. My main point is that it is not necessary to have a leak at the bottom of the sump in order to lose all the hydraulic fluid. Pete |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 1 | November 24th 03 02:46 PM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 2 | November 24th 03 05:23 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 0 | November 24th 03 03:52 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart D. Hull | Home Built | 0 | November 22nd 03 06:24 AM |
Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance | [email protected] | Owning | 5 | July 22nd 03 12:35 AM |
