On Tue, 24 Feb 2004 13:58:35 GMT, "Gary Drescher"
wrote: Can a commercial pilot be hired to rent a plane and fly a journalist on a local flight for aerial photography, without meeting any operator requirements? Or does that count as a sightseeing flight, invoking the part 135 drug-testing rules? It's not clear to me that the drug testing of Part 135 applies to sightseeing tours for little airplanes. Part 119 exempts little airplane sightseeing from Part 135; the implication to me is that the sightseeing flights in Part 135 must be only for big airplanes. I could find no letters of interp for this. |
"Greg Esres" wrote in message
... On Tue, 24 Feb 2004 13:58:35 GMT, "Gary Drescher" wrote: Can a commercial pilot be hired to rent a plane and fly a journalist on a local flight for aerial photography, without meeting any operator requirements? Or does that count as a sightseeing flight, invoking the part 135 drug-testing rules? It's not clear to me that the drug testing of Part 135 applies to sightseeing tours for little airplanes. Part 119 exempts little airplane sightseeing from Part 135; the implication to me is that the sightseeing flights in Part 135 must be only for big airplanes. I could find no letters of interp for this. It's true that 119.1e2 exempts small-plane local sightseeing flights from part 119, but I don't see how it exempts them from part 135. It does exempt them from 135.1a1, which refers back to part 119. But part 135's scope also includes 135.1a5, which applies specifically to local sightseeing, with no mention of part 119. --Gary |
On Wed, 25 Feb 2004 16:37:20 GMT, "Gary Drescher"
wrote: It's true that 119.1e2 exempts small-plane local sightseeing flights from part 119, but I don't see how it exempts them from part 135. It does exempt them from 135.1a1, which refers back to part 119. But part 135's scope also includes 135.1a5, which applies specifically to local sightseeing, with no mention of part 119. My vague understanding is that Part 119's purpose is to determine the applicability of Part 135/121 to flights. So being exempted from Part 119 is to be exempted from Part 135/121. |
... On Wed, 25 Feb 2004 16:37:20 GMT, "Gary Drescher" wrote: It's true that 119.1e2 exempts small-plane local sightseeing flights from part 119, but I don't see how it exempts them from part 135. It does exempt them from 135.1a1, which refers back to part 119. But part 135's scope also includes 135.1a5, which applies specifically to local sightseeing, with no mention of part 119. My vague understanding is that Part 119's purpose is to determine the applicability of Part 135/121 to flights. Right, and that's reflected by 135.1a1, which explicitly brings part 135 to bear on flights covered by part 119. So being exempted from Part119 is to be exempted from Part 135/121. Pretty much, but 135.1a5 is an exception. It brings a little of part 135 (just the drug-testing) to bear on sightseeing flights, irrespective of part 119. The key point is that the criteria enumerated in a1 through a7 needn't apply all at once (or else, for instance, only mail-delivery flights would be covered by part 135, as per a3). The listed criteria are distinct ways for 135 to be applicable. So being covered by part 119 is one way for part 135 to be applicable (as per a1); but being a local sight-seeing flight is another way (as per a5). At least, that's how it's written. I have no clue how it works in practice. ![]() --Gary |
part 135 (just the drug-testing) to bear on sightseeing flights, irrespective of part 119. Do you have any evidence that this is true? I don't buy it. Flight instructors often take people for sight seeing tours, which is permitted in Part 119. What sort of free lance flight instructor would have a alcohol testing policy? Doesn't make sense. If this were truly the case, the 119 exemption should be removed, and 135.1a5 would limit applicability to the drug testing stuff, and the result would be the same. |
... Pretty much, but 135.1a5 is an exception. It brings a little of part 135 (just the drug-testing) to bear on sightseeing flights, irrespective of part 119. Do you have any evidence that this is true? I don't buy it. Flight instructors often take people for sight seeing tours, which is permitted in Part 119. What sort of free lance flight instructor would have a alcohol testing policy? Doesn't make sense. If you mean evidence as to what's done in practice, then no, I don't have any. As I said, I'm only addressing what the regs say, not how the FAA actually behaves, which I have little knowledge of. FAR 135.1a5, unlike 1a1, does not assert any contingency on part 119; that's my only point here. Come to think of it, though, I do have one piece of anecdotal evidence, for whatever it's worth. I've been told by a local flight school that the reason the flight schools in the area all offer "introductory lessons", but none offer sightseeing flights, is precisely to circumvent that part of the regulations that would otherwise impose a drug-testing requirement. If this were truly the case, the 119 exemption should be removed, and 135.1a5 would limit applicability to the drug testing stuff, and the result would be the same. It would be the same result only if there's no other consequence to falling under part 119. I don't know if that's the case. --Gary |
I did some scanning of the 14 CFR Preambles, which make it clear that
you're right on this. An excerpt: -----------snip---------------- The FAA does not agree that some or all commercial sightseeing flights in airplanes or rotorcraft should be excluded from application of the rule. Commercial sightseeing operations usually involve members of the general public who have paid for a ride in an airplane or rotorcraft. For purposes of the antidrug rule, the FAA has determined that the safety implications of such operations are comparable to that of other operations that routinely involve carriage of passengers. These passengers should be given the protection inherent in other passenger-carrying operations for compensation or hire that have an approved antidrug program, without regard to size or scope of the operations or the number of flights per year a particular operator might conduct. -----------snip---------------- |
![]() "Greg Esres" wrote in message ... On Tue, 24 Feb 2004 13:58:35 GMT, "Gary Drescher" wrote: Can a commercial pilot be hired to rent a plane and fly a journalist on a local flight for aerial photography, without meeting any operator requirements? Or does that count as a sightseeing flight, invoking the part 135 drug-testing rules? It's not clear to me that the drug testing of Part 135 applies to sightseeing tours for little airplanes. Part 135 declares itself as having jurisdiction over sightseeing flights. It does not need permission from part 119 to do that. Flight instructors and everybody else who gives sightseeing flights get drug testing if they are doing it legally. It is not a big deal. Most flight schools sign up with a consortium that does the testing on a random basis among all its members. The cost is fairly minimal and so is the paperwork. That is about to change, though. More FSDOs are demanding control of the drug testing program themselves. Seattle FSDO recently told all the flight schools that they will now be running drug testing for everybody. |
Commercial polar routes? | General Aviation | 6 | January 28th 05 08:03 PM | |
Best Option for Private Pilot to Multi Commercial Instrument Ratings | Hudson Valley Amusement | Instrument Flight Rules | 34 | December 17th 04 09:25 PM |
The Doctor Says: Flying and Homebuilding Are Privileges, NOT Rights | jls | Home Built | 3 | August 23rd 04 04:49 AM |
Commercial dual crosscountry definition | David Brooks | Piloting | 20 | February 6th 04 06:23 PM |
good and cheap commercial flying school | hananc | Piloting | 1 | October 23rd 03 04:13 PM |
