... [...] Hope some of this helps Sure, thanks. Nice to hear the full description, so we can finally stop guessing. ![]() |
![]() "Paul Tomblin" wrote in message ... In a previous article, "Peter Duniho" said: And actually, while I haven't flown the Pipers you're referring to, my understanding is that the gear extension was based on airspeed, not engine power. Your comment about the behavior of such systems in icing conditions The POH for the Lance isn't 100% clear on this, but my understanding is that with the emergency gear extension, the gear will come down if you go below a certain manifold pressure at one speed, or will come down regardless of the manifold pressure at a lower speed. The Arrow auto extend is simply a mechanical belows on the second pitot (just behind the clear prop window) that dumps hydraulic pressure when you get slow. |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 1 | November 24th 03 02:46 PM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 2 | November 24th 03 05:23 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 0 | November 24th 03 03:52 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart D. Hull | Home Built | 0 | November 22nd 03 06:24 AM |
Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance | [email protected] | Owning | 5 | July 22nd 03 12:35 AM |
